/ Harbor Freight Tools that don't suck #15,261
rangerfredbob, Where did your friends find/buy the Husky boxes? Home Depot or Lowes? I'll go look at some if so. Thanks.
Husky is Home Depot, Kobalt and Craftsman s Lowes
Very true, I'm not saying their welders are the best but I'm not the average user, resale value doesn't enter into my equation anywhere and I'm pretty crafty so scabbing on another lead doesn't scare me too bad... my statements aren't for everyone, I know, just sharing my experiences with what I have, my MIG 170 has several thousand road miles on it now and has been fed some dirty power and thrown around in dusty conditions and keeps working, haven't tried running it over with a forklift but don't think that's a recommended test for many things :). Name brand welders aren't always in the cards for everyone, sure I'd prefer a $1500 welder... then again name brand welders are getting cheaper too...
/ Harbor Freight Tools that don't suck #15,262
Well I view it this way and I'm not just implying welders, but if you learned to become a decent welder on a cheap HF welder you can most likely weld profeciently with any welder out there.
/ Harbor Freight Tools that don't suck #15,265
Yee, the gun and lead are somewhat consumables really (or should be considered that I'm pretty sure...), they at least now offer replacement liners that aren't too bad, the trigger switch on the 100A deal is cheezy and has shorted out a few times on me causing some issues, even had to make a new rectifier and change a fuse at one point on that dang thing...
In order to make my buddies welder whole again I remember I had to order more than what was needed cause HF only sold it in one piece at the time. I fixed it for him on my dime cause I jacked it up, with him knowing if he needed help welding something ever again he'd have to take it to my place and I'll use my stuff.
/ Harbor Freight Tools that don't suck #15,266
Craftsman is also sold by True Value hardware stores, maybe others as well.
Isn't/wasn't Husky also sold by Tractor Supply? Could've sworn I bought something there once of that brand.
/ Harbor Freight Tools that don't suck #15,267
another TBN member recommended this, has a 95 percent 5 star rating. Not a cheap tool but clearly a good one.
/ Harbor Freight Tools that don't suck #15,268
Myself, I use the Braun magnetic base rechargeable (via USB) trouble light. It throws plenty of light to see with and is much less expensive to boot.
/ Harbor Freight Tools that don't suck #15,269
Btw when I melted my friends lead in two the replacement lead for the cheap harbor freight welders was almost as much as the hf welder itself. If I remember correctly the lead and gun were integral one piece. Probably part of the reason why I'm so against cheap hf welders.
Understandable. You get what you pay for and cheap equates to cheap no matter where you buy it.
/ Harbor Freight Tools that don't suck #15,270
Any place that sells Stanley Black & Decker or Dewalt tools will probably sell Craftsman. They own the name.
/ Harbor Freight Tools that don't suck #15,271
I did a search for the best grinder. Without spending a fortune ( because you can) I wound up at HF. I got this little gem withvarable speed, a light, and shields. I put it on a small table next to my 30 yr old HF 4" belt and side disc sander. Neither one of these will disappoint. View attachment 771449
Really like the variable speed option at that price point, you know if that has an induction motor?
/ Harbor Freight Tools that don't suck #15,273
Here's a 200 amp $hitbox??
3 in 1 for less than $200 on Amazon with prime.
my son had me order a Hit box 250
I tested the amp output on 240 Volts AC had trouble getting 160 amps out of it.
It welds OK on "Short" MIG beads but had a weird problem of cutting out mid long bead. Like the Voltage drops out mid weld I thought it was me. Nope.
I Bought myself an HTP Pro Pulse MTS 220 and absolutely No comparison on the way it welds.
Not in the same price range but it was well worth the extra money to me every time I weld with it
If I ever need another welder it will likely be an HTP
/ Harbor Freight Tools that don't suck #15,275
Hit box needs to change there logo they place in front of the name lol, is HTP Italian made?
/ Harbor Freight Tools that don't suck #15,276
I'll stick with either Lincoln or Hobart
Yep I still have a soft spot for my Idealarc TIG 300 300 over 800lbs of pure Awesomeness :)
/ Harbor Freight Tools that don't suck #15,277
I'll stick with either Lincoln or Hobart.
A friend of mine swears by miller. He's retired and welded professionally as his career for 40 yrs.
/ Harbor Freight Tools that don't suck #15,278
Yes basically Stel
/ Harbor Freight Tools that don't suck #15,279
When I was a lot more serious of getting a multiprocess machine miller seemed the way to go, that was 5 yrs ago.
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A60736)
2020 TROXELL...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
Bobcat MT85 (A60462)
