Found a great use for pallet forks
/ Found a great use for pallet forks #21
Great for logs. Add a log grapple and you got a weapon.
/ Found a great use for pallet forks #22
I have only had a set of pallet forks for a short time. I keep finding more and more uses for them. I even move pallets with them sometimes as well.
/ Found a great use for pallet forks #23
I have SSQA forks from my Bobcat that fit the MX5200 I would love to put a grapple claw on this as I have a Caterpillar forklift for most fork jobs. Does anybody sell a claw that can be added to a set of forks?
/ Found a great use for pallet forks #24
Some true pallet fork enthusiasts in here, lol!
My forks are on the SSQA around 50% of the time too. I take them off to park in my garage to save space, though. So most days I fire up the tractor and get to decide what to flip the levers on. Sometimes it's nothing at all.
/ Found a great use for pallet forks #25
/ Found a great use for pallet forks #26
The other day when I was driving home, I saw a couple of stumps on my place from the road that have been sitting there for over a year. I tried to pick them up with my grapple, but couldn't ever get a good grip on them. Too round, too big, and too heavy. So I got to wondering if the pallet forks would slide under them and pick them up. They did!!!!!
You can also dig out stumps with forks if you're careful.
/ Found a great use for pallet forks #27
Careful is the key word. You will hate yourself if you ever bend a fork :cry:
Had a worker do that on a rental once. The bill was ugly.
/ Found a great use for pallet forks #28
Pallet forks with a basic thumb grapple can perform most of the tasks full clam shell grapples can without the added expense of a full grapple...
Pine, this isn't directed at you, but I've been saying that in here for years, and all I would get is an argument! lol I knew the day would come when more folks would realize I was right.
Everyone who buys a tractor becomes an expert the "next day", and those of us that been doing this stuff for many years don't know anything...
Pallet forks with a grapple is by far more useful than the big grapples folks in here buy, but we gotta impress our neighbors, don't we. lol
SR
/ Found a great use for pallet forks #30
SR
Isn't this full of truth!
I see the weld on claw for pallet forks... My thoughts go to a removable claw, that would be the BEST. Best of both worlds
Would this work? https://www.palletforks.com/fork-mo...rBvJYc5-ts7Hhv7CZhb56Pqyf1wWmGwRoCPAYQAvD_BwE
/ Found a great use for pallet forks #31
Here's a little better price (though it's gone up a lot from last I checked!) on a re-mountable thumb grapple for forks or buckets.
I want to have one of these on my forks too, but my forks are super light duty (2100 lbs for compact tractors) and the frame wouldn't hold up. My 54" MTL grapple does the trick for moving logs just fine, and was only $1200 shipped.
/ Found a great use for pallet forks #32
I prefer this type,
If you want, you can slide it right off just like the adjustable forks come off. It's made by ALO, but it's probably on the heavy side for a small tractor.
SR
/ Found a great use for pallet forks #33
I ended choosing a SSQA grapple without forks for $999 from Titan. I have a set of 42" forks laying around from a previous lift that got 48" forks years ago. This will work immediately with the 773 Bobcat and I will have to know look into putting a 3rd function on the LA1065 loader. Thanks for the information. My application is pretty light duty compared to the pictures posted. I'll be moving mostly brush and limbs.
https://www.palletforks.com/skid-steers/grapples/fork-grapples/pallet-fork-grapple-v2/FRGP.html
/ Found a great use for pallet forks #34
I don't think my machine could pick up that grapple, let alone that log. :ROFLMAO:
But yes, I'd like a grapple on my forks. It would be very handy to have one that could go down between the forks to pinch stuff of varying size, as well as grabbing a brush pile.
/ Found a great use for pallet forks #35
IMO a basic thumb grapple is one of the easiest DIY (hydraulic) projects...and also one of the most useful...
/ Found a great use for pallet forks #36
/ Found a great use for pallet forks #37
HLA
/ Found a great use for pallet forks #39
/ Found a great use for pallet forks #40
I don't know what you call very low pressure. I keep 10# in my rear tires quite often in muddy areas for more traction but if I put 10# in my front tires with a load like that and took a sharp turn, the tire would come loose from the rim.
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
1605 (A57192)
1605 (A57192)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
