From mow to snow.
/ From mow to snow. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
I'm done mowing for the year. I love it for a while, but it becomes a chore half way through summer.
Today I converted the BX2680 to a snow warrior.
Dropped the mower, put on the chains, wheel weights, rops, and the plow.
This too will become a chore sooner than later.
/ From mow to snow. #2
I just went from hoe to snow, LOL Took the backhoe off and did the service, put my winter rims and tires on, but didn't hitch the snow blower yet. Might use the box blade until I get a base froze in.
Now just have to get RTV ready on my next days off.
Hopefully by us doing this it will not snow now! LOL
/ From mow to snow. #3
I'm still in mowing mode. Snow is rare enough here; you can't even buy snow tools. Just had some rain a few days ago and the grass loves it. I'll probably be mowing Tuesday or Wednesday.
I certainly don't miss the North Coast snow belt. :cool:
/ From mow to snow. #5
View attachment 768484View attachment 768485
I remove/service mowers from all of my tractors once each fall before servicing the tractors and installing FELs.
The B1750 gets a back blade and F & R chains. The B3350 gets a front blade, ballast box and sometimes F & R chains. M9960 and L6060 get FELs only. Cast iron stays on year-around. Fords are hobby tractors these days.
Chains are counterproductive with a good front blade on paved surfaces as traction is much better on cleared paved surfaces without chains.
/ From mow to snow. #6
I would say that depends a lot on your individual conditions. Really nice pavement, no packed snow or ice, scraping the pavement completely clean
it could be.
Heavy wet snow, snow that has been driven on, uneven and potholed roads and then start throwing in unpaved roads and hills those chains become very productive and safe.
/ From mow to snow. #7
I'll mow one more time this week, I finished brush hogging last week. I'll put the winch on and do some logging begore switching over to the snow blower and chains in early Dec. I'm hoping for a late and mild winter. This nice fall weather has allowed me to catch up on my summer chores. I don't know how I ever had time to work full time.....
/ From mow to snow. #8
I usually leave the mower on for ballast until the first snow and then swap it for the cinder spreader. Dropping the bucket and putting on the FEL plow only takes a couple of minutes.
I can get away with chains on just the front tires. If I loose traction, lifting the plow a bit to add more weight makes the cleated chains dig in better.
/ From mow to snow. #9
How much damage can, or do, chains cause to an asphalt driveway?
/ From mow to snow. #10
Oops, sorry didn't notice this thread was posted in the kubota section
That's what I get for always going to new posts.
post deleted
/ From mow to snow. #11
Now I try make sure Kubota in winter mold...and it is,about 4-5 years ago just over foot snow fall on Halloween. :rolleyes:
/ From mow to snow. #12
Considerable damage especially if the chains are cleated. I put sheets of OSB on my garage floor to keep the concrete from getting chewed up.
/ From mow to snow. #13
/ From mow to snow. #14
I just finished servicing the tractor and rear PTO snow blower for the season. Greased up, adjusted tolerances, ready to go!
I have chains on the RTV tires (it has a Vplow on it), and yes I put down plywood in the garage to pull over. No reason to chip up a good surface.
/ From mow to snow. #15
That's a nice setup. Some day I should by a spreader. We usually have very cold dry winters, but last two years we have gotten lots of wet snow and freezing rain and I ended up having to "sand" (only had 7/8's crushed gravel here) by sprinkling with the loader bucket.
/ From mow to snow. #16
One of my more usefull purchases was my first sander, had to do a lot of work to that one before the second season with it.
New wear sheet in the floor, new apron chain and rebuild the the rear drive hoop (actually just made a new one).
When it was heading for major work again I could afford a new stainless steel unit.
Loading some coal ash into the new one, the sandpile is under the tarp.
The current setup, the old truck was just getting too unreliable
I get a tandem or triaxle load of salted sand every two-three years, time this year for a load
/ From mow to snow. #18
My blower is still in the barn, hoping I don't need to use it for another month or so at least. Will take the box blade off, lower the skid shoes on the blower to get a good base for the first couple snowfalls, and then up the skid shoes. I'm still hoping to get a few more hours on it before the ground freezes.
I did groove my tires though so I am looking to try those out this winter.
/ From mow to snow. #19
All set here with our equipment. Just waitin on the snow. Tractor and diesel tanks are filled and treated. Just a matter of time, it will come, we will be ready.
Up there west of us in Buffalo NY, man did they get hammered! I heard 77 inches! We`re down in the lower southern tier fingerlakes area, so we didnt get any snow.
Everybody be safe out there!
/ From mow to snow. #20
On can do serious damage to asphalt (even concrete) with chains.
I use HD 2 link twist ladder chains which cause little damage assuminig common sense.
V-bar and other aggressive chain types can do real damage in short order.
Bush Hog 3008 Pull Type Rotary Cutter (A64047)
Bush Hog 3008 Pull...
John Deere 6140R Tractor (A64047)
John Deere 6140R...
New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
New Holland...
2016 PETERBILT 365 DAYCAB (A63569)
2016 PETERBILT 365...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
RoadTec RP190 (A63118)
