From mow to snow.
   / From mow to snow. #11
Now I try make sure Kubota in winter mold...and it is,about 4-5 years ago just over foot snow fall on Halloween. :rolleyes:
   / From mow to snow. #12
How much damage can, or do, chains cause to an asphalt driveway?
Considerable damage especially if the chains are cleated. I put sheets of OSB on my garage floor to keep the concrete from getting chewed up.
   / From mow to snow. #13
   / From mow to snow. #14
I just finished servicing the tractor and rear PTO snow blower for the season. Greased up, adjusted tolerances, ready to go!
I have chains on the RTV tires (it has a Vplow on it), and yes I put down plywood in the garage to pull over. No reason to chip up a good surface.
   / From mow to snow. #15
I usually leave the mower on for ballast until the first snow and then swap it for the cinder spreader. Dropping the bucket and putting on the FEL plow only takes a couple of minutes.
I can get away with chains on just the front tires. If I loose traction, lifting the plow a bit to add more weight makes the cleated chains dig in better.
That's a nice setup. Some day I should by a spreader. We usually have very cold dry winters, but last two years we have gotten lots of wet snow and freezing rain and I ended up having to "sand" (only had 7/8's crushed gravel here) by sprinkling with the loader bucket.
   / From mow to snow. #16
One of my more usefull purchases was my first sander, had to do a lot of work to that one before the second season with it.
New wear sheet in the floor, new apron chain and rebuild the the rear drive hoop (actually just made a new one).
When it was heading for major work again I could afford a new stainless steel unit.
Loading some coal ash into the new one, the sandpile is under the tarp.
The current setup, the old truck was just getting too unreliable
I get a tandem or triaxle load of salted sand every two-three years, time this year for a load
   / From mow to snow. #17
I saw the chained tire in your first picture, and thought “that tire is huge!”…….then I focused a bit better….
Yea, I did the same thing.
   / From mow to snow. #18
My blower is still in the barn, hoping I don't need to use it for another month or so at least. Will take the box blade off, lower the skid shoes on the blower to get a good base for the first couple snowfalls, and then up the skid shoes. I'm still hoping to get a few more hours on it before the ground freezes.
I did groove my tires though so I am looking to try those out this winter.
   / From mow to snow. #19
All set here with our equipment. Just waitin on the snow. Tractor and diesel tanks are filled and treated. Just a matter of time, it will come, we will be ready.
Up there west of us in Buffalo NY, man did they get hammered! I heard 77 inches! We`re down in the lower southern tier fingerlakes area, so we didnt get any snow.
Everybody be safe out there!
   / From mow to snow. #20
On can do serious damage to asphalt (even concrete) with chains.
I use HD 2 link twist ladder chains which cause little damage assuminig common sense.
V-bar and other aggressive chain types can do real damage in short order.
2020 MACK P164T (A58214)
2020 MACK P164T...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2184 (A58376)
2184 (A58376)
JCB 2145 (A47477)
JCB 2145 (A47477)
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
