YM2000D Motor oil Capacity
/ YM2000D Motor oil Capacity #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
This is a 4wd YM2000D not to be confused with the YM2000 2 cylinder.
This is a 3 cylider engine and I'm trying to help an elderly friend do an oil change and can't find anything on the net.
/ YM2000D Motor oil Capacity #2
I don't know the capacity, would guess between 4-1/2 and 5 quarts. If 3 cylinder you are talking about a YMG2000. YM2000 is two cylinder.
Apparently the engine or hood decals were replaced at sometime in the past becuase it's definitely a 3 cylinder engine.
/ YM2000D Motor oil Capacity #5
Apparently the engine or hood decals were replaced at sometime in the past because it's definitely a 3 cylinder engine.
A YMG2000 is a far better machine over the YM2000. I hope his machine is the G with the more modern setup.
Thanks, That's his machine. His also has a bucket and it's 4WD.
Going to start with 4 quarts check the oil level and adjust accordingly.
Im estimating it's going to take a little over 5 quarts to fill her up.
/ YM2000D Motor oil Capacity #7
You are a good friend to be helping out. Good luck!
All the best, Peter
/ YM2000D Motor oil Capacity #8
I've not added this yet to the Yanmar Model Cover Pages. Here is the Parts Manual for the YMG machines attached PDF. :)
Page 5 tells you how much oil the engine takes. 4.5L (5-qts)
Compliments of the Yanmar Tractor Owners Group on GroupsIO.
This is the English summary of a 3T80 engine. Its the OPS PDF attached page 83.
The JD850 is very close to the YMG2000 for engine info.
  • YANMAR YMG1800 YMG2000 PARTS MANUAL NPC-1340.pdf
  • OMR68993-H8---ENGLISHodf.pdf
Thanks for all the info.
For the record it took a little over 5 quarts.
/ YM2000D Motor oil Capacity #10
Yes, 5qts engine and a little more for the filter. ;)
The machine has the same hydraulic capacity as my YM2610 with the 3T80. It will be 19 to 21 quarts to change out with J20C Hy-Gard or TF500A. Both work.
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2017 Ford Explorer (A61569)
2017 Ford Explorer...
2009 Menzi Muck A91E 4x4 Spider Walking Mobile Hydraulic Excavator (A61567)
2009 Menzi Muck...
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
