YM2000D Motor oil Capacity
   / YM2000D Motor oil Capacity #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
This is a 4wd YM2000D not to be confused with the YM2000 2 cylinder.
This is a 3 cylider engine and I'm trying to help an elderly friend do an oil change and can't find anything on the net.
   / YM2000D Motor oil Capacity #2
I don't know the capacity, would guess between 4-1/2 and 5 quarts. If 3 cylinder you are talking about a YMG2000. YM2000 is two cylinder.
Apparently the engine or hood decals were replaced at sometime in the past becuase it's definitely a 3 cylinder engine.
   / YM2000D Motor oil Capacity #5
Apparently the engine or hood decals were replaced at sometime in the past because it's definitely a 3 cylinder engine.
A YMG2000 is a far better machine over the YM2000. I hope his machine is the G with the more modern setup.
Thanks, That's his machine. His also has a bucket and it's 4WD.
Going to start with 4 quarts check the oil level and adjust accordingly.
Im estimating it's going to take a little over 5 quarts to fill her up.
   / YM2000D Motor oil Capacity #7
You are a good friend to be helping out. Good luck!
All the best, Peter
   / YM2000D Motor oil Capacity #8
I've not added this yet to the Yanmar Model Cover Pages. Here is the Parts Manual for the YMG machines attached PDF. :)
Page 5 tells you how much oil the engine takes. 4.5L (5-qts)
Compliments of the Yanmar Tractor Owners Group on GroupsIO.
This is the English summary of a 3T80 engine. Its the OPS PDF attached page 83.
The JD850 is very close to the YMG2000 for engine info.
  • YANMAR YMG1800 YMG2000 PARTS MANUAL NPC-1340.pdf
  • OMR68993-H8---ENGLISHodf.pdf
Thanks for all the info.
For the record it took a little over 5 quarts.
   / YM2000D Motor oil Capacity #10
Yes, 5qts engine and a little more for the filter. ;)
The machine has the same hydraulic capacity as my YM2610 with the 3T80. It will be 19 to 21 quarts to change out with J20C Hy-Gard or TF500A. Both work.
Booster Cables (A59230)
Booster Cables...
Forklift (A59228)
Forklift (A59228)
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A59575)
2006 MAC TRI AXLE...
