The solution, and I've have a winch on my trailer, 20+ years, and I haul junk. Use a 50' cable and double line it. That way, it's full power. Good battery. Use chain from pulley to tractor. That way you can shorten or adjust as needed. Works best if you use a short chain hooked on tractor in a loop around front axle. Then other long chain loops through axle chain and eye or hook on pulley. Those winch blocks at hobo frate are sold right beside the winches. And it helps greatly to have chain to tie tractor off when you're in the middle of winching, in case you need to let winch off and re-adjust your situation. Say you're almost to the top of ramps. I carry a 3 ton lever hoist just in case. It will load a tractor without any wheels on it, but I break out in a sweat every time I glance at it. So I keep it hidden. I have come alonged a two ton army truck with flats all around, up on a trailer. It was WW2 truck parked in mid 60's, and grown up in the jungle down here, and was complete.
HF winches are fine, they'll hang with the others. 5,000 double lined, should be fine with a rolling load. I've had a 5,000 and it did fine. Like I said, a shorter cable and a pulley will maximize everything. When you pull and front wheels break over the ramps, you can re adjust and connect pulley to short chain and pull onto trailer.
Keep some wheel chock blocks too. In case your trailer is facing down hill, and I always try to winch that way if I can. This is Arkansas and I don't live in the flat part. Just throw one in front of a wheel because tractor may roll up and hit the front, and you don't want that. Or your load may be too far forward, and you'll have to get it back rearward. So tie pulley at rear of tractor and single line to front of tractor and pull it back some. You can un load it that way also, if your trailer is down hill at your unload location.
I have three trucks with pto winches, flat beds with gin poles and rolling tail boards. Two 2 - 1/2 tons with cranes that you can set trusses on a house with. One 4wd 4 wheel steer rough terrain crane, 30,000 lb lift. A few service trucks with cranes. Its all just old things that still works. But, with a double line pulley, chains, and blocks, you should be just fine.
It's was a dangerous life growing up in the south. As a young boy, I prayed. I didn't pray for a wife, and I don't have one. I didn't pray for children, and I don't have any. I did pray to be old and die with all my fingers and toes, and I still have all of them. So I'll be the first to tell you, prayer has worked for me. See, I figured if I had my fingers and toes, I would have everything in between.
