2440 Hydraulic Woes
/ 2440 Hydraulic Woes #1
Skier8251
Member
Jax FL
JD 2440
Annnd I am back... Ok got some strange things afoot with the 2440...When the PTO is disengaged, center lever down, I am having hydraulic issues. The Power steering will only work intermittently with High RPM's, and the rock shaft will do the same it may or may not go up with the higher RPMS...
If I engage the PTO everything seems to run fine, although I am hearing some strange (hydraulic) noises that I dont recall the tractor making before.
Also dont know if this is related or not but the brake pedal sinks to floor all positions, and I have to pump it up to get the brakes to work. I haven't tried bleeding them yet, but just thought I would add this fun fact.
Thanks in advance for the help.
/ 2440 Hydraulic Woes #2
Sounds as if hyd pto brake circuit is leaking. This could be a crack in brake circuit oil supply tube or control valve or brake band operating piston. Photo below is of brake band but operating piston has avoided my parts search. I continue my parts catalog search. Is your tractors serial # below or above 341,000? Brake reservoir is supplied oil via trans pump that also operates pto brake circuit.
/ 2440 Hydraulic Woes #3
Brake tube is item 1
/ 2440 Hydraulic Woes #4
When was the last time you serviced the hydraulic system, change oil, filter and clean the suction screen? It sounds like the hydraulic pumps are flow restricted, that will also restrict the output flow volume and pressure.
/ 2440 Hydraulic Woes #5
Speaking from 13 yrs experience that I served as a hands on JD dealer service manager I think when JD closed center hyd system operates fine with hyd pto engaged but has strange noise which is probably chattering when hyd pto brake is engaged I seriously doubt changing hyd filter & cleaning suction screen will solve the creation of the noise.
I'm not advocating not performing those tasks I just doubt that those tasks will solve this tractors hyd noise
Tractor filters were replaced recently as well as Drain and fill...
Based of what TX is saying I am going towards a Split to figure out what Chaos is going on inside the tractor.
Unfortunately I dont have the facilities to do this at my place so I am screwed for now.
Serial 255006
Thank you all for the input...
/ 2440 Hydraulic Woes #7
I suggest to perform some GOOD diagnostics BEFORE splitting tractor. I suggest to remove shift cover & blow compressed air into brake engagement pipe & listen for hissing air.
/ 2440 Hydraulic Woes #8
I am with TX Jim, I too think you have failed tube to the PTO brake. This will cause an internal leak to sump and bleed off the flow from the transmission pump to the front pump causing your problem.
If you do the repair or have it done replace BOTH PTO hydraulic tubes. The labor is the same for two as one.
Update, so two of the lines inside the housing were messed up. They have been replaced and we are back in business!
/ 2440 Hydraulic Woes #10
Congratulations on your successful repair. Thanks for updating your thread.
Jim
/ 2440 Hydraulic Woes #11
As a regular attender of a couple different forums, it's nice to have the OP follow up with the results. Thank you for letting us know the outcome.
Jes
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
2015 FORD F-550 (INOPERABLE) (A63569)
2015 FORD F-550...
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
