Inverted Snow Blower
/ Inverted Snow Blower #41
Roy, I purchased a Metor 72" in the spring of '20 after the season, so last year was my first experience with it. The first snow of the season was about 18" of heavy wet packing snow. I had some problems pulling thru it and would have to drive forward with the blower in the air to make a path, and then I was able to pull the blower thru it. This first experience had me questioning my purchase. Fortunately after that first wet mushy snow I had little problem driving thru the snow the rest of the winter. Most of the time I'm blowing a foot or less of snow and I just blow driving out, turn around and finish up on my way back into the driveway. Driving forward is much easier on my neck.
The longer your driveway the more you will like the inverted blower.
/ Inverted Snow Blower #42
Roy,
I’ve looked off and on for a used inverted blower for years now, and found they don’t come up all that often. Are you planning on buying new or used?
I lucked out and happened to come across a good price on a pretty heavy Erskine unit. I don’t know much about Erskine and have always dreamt of a Normand or Pronovost (not puma), but figured I’d take a chance. It’s supposedly 1,400lbs. The model is 901RP.
I bought a blower that is likely way too big for my tractor at 39 PTO hp and 90” wide, but I’ll let you know once snow falls! I’ve always wanted an inverted blower, and for better or for worse, I can’t wait to try it!
/ Inverted Snow Blower #43
If you can manage to make it tr=rough the first pass, you can always just take half a width. You're goung to love a rear pull.
/ Inverted Snow Blower #44
Roy,
That cant wait to try it , is how I feel. Congrats on the inverted blower:)
Chomping at the bit to try the Wifo 84 inch inverted I bought, but it was on back order and the local dealer said it won't be here until November.
I just hope it does get here by then...
/ Inverted Snow Blower #45
I have 72 inch conventional rear 3 point Meteor blower with hydraulic swivel and tilt, have used it the past two winters, sheared 2 pins last winter but they are pretty quick and easy to replace. Tractor is hydrostatic and has 4 wheel drive so far I haven’t needed to use tire chains. My yard and driveway are only about 100 yards long, there are to many parts that require backing into so I don’t think a pull type blower would work as well in my situation. But if I actually had the chance to try a pull type blower my opinion might change.
The previous 30 years I plowed most of my snow with a 8N Ford tractor and a rear blade, it’s much easier and more enjoyable now with a cab heat and radio.
/ Inverted Snow Blower #46
I haven't told the wife yet, but my retirement gift to myself will be either a front mount blower, or an inverted rear mount. My driveway and yard is relatively flat, so I am not concerned about slipping uphill trying to go through whatever dump of snow we receive. Like someone already mentioned, just raise the bucket a foot or so, and whatever excess snow will overflow the bucket, rolling ahead, or escaping out the side, hopefully picked up by the blower. Interested in others opinions as well.
/ Inverted Snow Blower #49
I am unsure why you would not want input from the commercial guys. We have run these blowers more than anyone else. I am also not going to tell you to go out and purchase a setup like mine. With that said.
The inverted blower is not an end all be all by any means. You cannot back into a large snow bank and blow it out of the way. If you get a 4' snow storm there are better choices. They are heavier. If you have an issue with 3pt hitch lift you want to verify you can lift one.
The pros to one are many. It follows the contours of a driveway better than backing into an uneven driveway.
It cleans up better at the end of the driveway and is not leaving that snow bank up by your garage.
It will clean down as well as anything I have used when setup properly. I have owned quite a few of each.
I am not going to say it is way easier on the neck as I still look back. I guess you could never look back but I do.
The blower will swing wider in turns. With a backup blower your front end swings wider. I have never had an issue with either.
Wet snow is not an issue for either blower so long as you are set up right.
These are my thoughts and I will try to answer any questions you may have. I am a commercial snow guy though so may want to disregard :)
/ Inverted Snow Blower #50
Hey Roy, I’m a little north of you in the NEK. I have and had two, actually three rear pull style blowers or inverted.
My wife( girl friend first) had a Kubota 30 hp with a 72” snow way I think it was called. A TBN member now owns it( fitter1) it worked well with that tractor.
I bought a John Deere 5105m with a cab. I then got a Fransgard v style pull behind blower. It worked well but was longer and had a smaller fan along with only four blades.
I then sold that one( to an old neighbor who blew up his Fransgard. Welded drive line, no shear bolt) and bought a Normand 92” inverted. 2018 model only used once for four hours! It was only a little over $6k bought in Canada.
I clear our driveway and a 1/2 mile of class 4 road. These work amazing and to me the only way to go. I have studded ice chains and I can go in as deep of snow that I can drive through. I always run my tractor in epto and never run out of power. In a 3-4’ storm( if we ever get one?) I would go out 2-3 times.
My old v style I have a picture of it handling 2’ of snow.plow guy usually plow every 6” plus or minus. Blowing is slower but once it goes through the machine, it’s gone forever. No banks to push back, if you needed to the loader on the front takes care of that.
I will post some pictures of both units.
John
/ Inverted Snow Blower #51
JohnView attachment 772710View attachment 772711View attachment 772712
I am sad to tell you this, but Roy passed away.
We were both wanting Inverted blowers. I was shocked to hear he had passed.
I think the reason he said he wasn't overly interested in commercial Inverted users was the same use idea as mine- which is more for a long driveway use versus short residential parking space type commercial blowing.
I will sure miss Roy's posts.
/ Inverted Snow Blower #52
That 92" Normand is a beast and you got it for great money.
/ Inverted Snow Blower #53
That's sad news.
/ Inverted Snow Blower #54
The is definitely sad news to hear :cry::cry:
/ Inverted Snow Blower #55
I’m sorry to hear this and apologize for being late to the post!
If anyone has questions, please ask away!
John
/ Inverted Snow Blower #56
It is a beast for sure! You can not go wrong with either Normand and Pronovost. Both of these are commercial products.
Th other ones are very similar and would hold up excellent for homeowner use / light commercial for sure!
They are all basically the same design when it comes down to it!
/ Inverted Snow Blower #57
I understand your logic on a long driveway. I do some that are longer but would not call them long by some folks idea of long. I am unsure where distance comes in though? I do some driveways that are 300' and I do them the same as one 75'. I think if you have one a quarter mile or more it would be the same. I would rather drive forward for that distance than backing up. I have had many back up blowers and I find my pull type rides over gravel better when not frozen. I believe it follows the tractor better. I see no downside to inverted until we have a massive snow. If you do not have tractor enough to drive through some snow that will be an issue. Weight of these things are more than conventional. If you are borderline on lift capacity inverted may not work. I am also not on here waiving pom poms that they are the best thing ever. Everything has a drawback if you look hard enough for it. I still have to look back. I am not running a machine like this and not watch it. Many guys say no looking back. That is not the case for me.
/ Inverted Snow Blower #58
... I see no downside to inverted until we have a massive snow. If you do not have tractor enough to drive through some snow that will be an issue....
I agree. Unless you regularly get 4' snowdrifts or you do not have tractor enough to drive through some snow, an inverted is a great snow clearing option. I've had a conventional 3pt blower and an inverted. The inverted has cut my snowblowing time in half. Yes, I still look back occasionally to monitor the operation, but with the conventional 3pt blower, I had to look backwards all the time.
I occasionally do our 1/2 mile private road and frequently do my neighbors driveways. Short or long, the inverted blower is faster and easier.
I'd do more cheering, but I can't find my pom poms.
/ Inverted Snow Blower #59
Mostly I use my rear pull for my driveway, around buildings, etc. And a quick in and out of neighbors driveways. Occasionally I blow out 1/2 mile road. Easy/Peasy
I have to look back as I am for hire and most driveways are 100' or less. It is impressive how quickly I can blow over a light pole side the driveway. :) With going ahead and back short distances I think the looking back is probably pretty equal. If doing only your own driveway I expect you could almost never look back. My Cyclone is the newer hybrid style of pull type. It works great for me but a bit of overkill for a homeowner. The advantages are getting closer to the garage door and less snow into the road. The cost would be prohibitive though for a homeowner. The basic style does a fine job and if wanted you can also mount a rear scraper on them.
/ Inverted Snow Blower #60
I just put the chains on yesterday.... I have a 74 Normand on my MX6000. I can drive through 15-18" of wind packed snow... A fresh snow... I am sure a bit more. I have euro chains on all 4 corners. I absolutely hated using a traditional 3 point blower... I ran 72" skid steer blower off an auxiliary tank. For DEEP snow, drifts or piles.. that was great! I have 3/8 of a mile of gravel. The inverted is great! I picked mine up in June of 2020 used for $3k. It does weigh 840#
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2000 FREIGHTLINER 3-AXLE BOBTAIL VACUUM TRUCK(INOPERABLE) (A63569)
2000 FREIGHTLINER...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
