Inverted Snow Blower
/ Inverted Snow Blower #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I have a 74" conventional rear snow blower, but I'm interested in other folks' experiences with the inverted blowers.
Not too interested in the guys doing residential commercial work...more interested in the rural folks using the implement to clear the drives and such
My tractor is a Deere 4052R cab with 40 PTO HP
/ Inverted Snow Blower #2
subscribed
/ Inverted Snow Blower #3
Roy, I have an inverted. It's fine and does what I need it to. Ask away!
/ Inverted Snow Blower #4
I had a Meteor 3pt push snowblower and ir worked well, but was a pain in the neck. I sold it and bought a 68" Meteor Rear Pull snowblower, and I love it. I can clear the same are in half the time. I have zero issues with driving over the snow. Unless, you regularly get snowfalls of over 18" or have lots of drifting, you will love it.
Keep 'em coming, folks!!!
/ Inverted Snow Blower #7
RoyJ - I had no idea what you were referring to, but I did a bit of google research. I get it now. I think this is far more preferable to the front attached, or rear shooting show blowers. I like it. PULLING is better than Pushing (from either direction) in my opinion. I'm going to look into that also.
are the blades spinning in the opposite direction to normal ?
it's not even digging up the blacktop :)
/ Inverted Snow Blower #8
I have both a conventional rear mount that you use in reverse and an inverted one to pull.
I'm usually using a Branson 8050 on either of them, I prefer the inverted pull type.
If I'm moving a pile of plowed snow bank then the conventional is better.
For just blowing the driveway the inverted works great, mine also has a rear drag blde to pull snow away from doors and such, after you pull ahead while blowing you lift, back up and drop and pull ahead again blowing what you have pulled out.
I have not have any issues clearing the plow wipes at the end of the driveway.
My inverted blower does have the poly cutting edge and shoes, I like them but they are expensive.
These are 2" thick and the cutting edge is 6-8" on the ground the full width.
/ Inverted Snow Blower #9
Roy I ordered a WIFO 84 inch pull behind for my tractor.
Only a little info and 2 vids I could find. They were back ordered so I probably won't see it till November
Looks to be well built and weighs 1220lb. Ordered with the hydraulic deflector and comes with a hydraulic shoot rotator.
/ Inverted Snow Blower #10
Mostly I use my rear pull for my driveway, around buildings, etc. And a quick in and out of neighbors driveways. Occasionally I blow out 1/2 mile road. Easy/Peasy
What brand and width?
If I go for one, I'll want 72 (±2") width...also, the hydraulic chute rotation. Deflector rotation would be nice, but I don't have it on my current Frontier conventional blower and rarely adjust the deflector.
/ Inverted Snow Blower #12
I have a 78" Erskine with the hydraulic chute. Same as you, I rarely adjust the deflector. It's heavy, 1100 pounds so dragging it up a steep part of my gravel drive, chains are required.
I've only had it for one snow season but so far I'm happy with it. It is noisy however from the gear drive assembly. I'm hoping it will break in and lessen the noise.
/ Inverted Snow Blower #13
Deleted previous post.
/ Inverted Snow Blower #14
Not hi-jack this thread but I am curious on how well the pull type blowers work on wet heavy heart attack snows that packs into ice the first time you drive on it. Will they scrape up the tire tracks or just ride on top leaving a layer of snow?
/ Inverted Snow Blower #15
I've used mine in wet snow that was almost slush, it left just the smallest amount of ice under the tire marks you could actually see where the chain studs had dug into it.
/ Inverted Snow Blower #16
Anyone else a bit surprised that there appear to be only a Very few TBN members with inverted blowers.
Maybe I am wrong, but looks like well under 10 that have pull type blowers.
I have a couple reasons that imo will make it a big improvement for me,
first I have a damaged back, plowing in reverse with the box blade is not fun plus when getting to the pile it wears a guy out clutching and shifting and looking back hopefully will be reduced along with hitting the pile.
Also especially hopeful that I can make a big loop out of the 2 connected driveways of ~1000 feet by driving to one end turning around and repeat Basically access will be available after just one full looped forward pass.
Next thinking that multiple single passes in the parking areas will reduce the multiple passes that the bucket and box blade over the same area required because of spill over.
Finally like the idea of still having a bucket available, so still can move a bank back or clear out the mail box area.
The bucket also from other posts sounds like if a big snow happens can be held at a foot or two off the ground and then the blower used to clean right to to the ground.
/ Inverted Snow Blower #17
People buy traditional 3pt blowers because they are cheaper and that's what dealers stock (in the US). I think if dealers had a Rear Pull that people could demo, they would sell like hotcakes.
They seem to be more prevalent in Canada, maybe because more people have seen them in action.
If you don't mind me asking...what did it cost? PM if you prefer
/ Inverted Snow Blower #19
I have thought about it and the idea seems great. But the idea of waking up and finding the storm has dumped 2 or 4 feet of snow in my driveway and I've got a 4 to 6+ foot drift across the middle of it and all I have is a blower the requires me to drive thought that before I can move it with my little tractor just does not seem like a good idea. I have a traditional rear blower because I need one piece of equipment that can handle whatever I get. Big snowfalls are a common event here.
/ Inverted Snow Blower #20
Two feet of snow can be driven through with my inverted unit easily. We got a 38" storm and I managed to walk through 90% of that. Were the town plows had rowed it up I did have to back in a ways then drive ahead, I got 4 - 5 feet each time doing that so a half dozen pulls and the driveway width was opened. I did have the bucket sitting a couple of feet above the ground and while driving it acted similar to a plow pushing some snow ahead with the majority going off to the side. When I picked up the other passes I was centering the row of snow, no issues for me.
UNUSED CFG INDUSTRIAL QH12R MINI EXCAVATOR (A62130)
UNUSED CFG...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED RAYTREE RMDM70-70" HYD DISC MULCHER (A62131)
UNUSED RAYTREE...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
