Good morning!!!!
   / Good morning!!!! #155,881
Here’s the course that my neighbor put in-
And here’s a drone video I made of one of the car shows there. There was once a dragstrip there, it’s now used as a private runway.
   / Good morning!!!! #155,882
I saw this when looking around, looks like a worthy addition to almost any mechanics tool box.
Sure.... now you post an inexpensive set..... after I fought to get the bearing out! :););)
   / Good morning!!!! #155,884
Successful day! Transfer case back in, Jeep is drivable! The clanking noise heard before the rebuild is gone. Ran it through the 4wd ranges, working fine. Brakes work great, transmission shifting great. Only one more thing to do... change the gear oil in the front differential. If the oil in there is as bad as the rear oil, it's long overdue.
2 out of 3 of my kids think you just have to take a vehicle to Jiffy Lube every few thousand miles.... I have tried to teach them that maintenance can be a good deal more than just oil changes... maybe some day.....
Since I had the mechanic hat on, our little go-getter car decided that it wanted some love too...... It was a bit chilly this morning when I went to run an errand, so decided to turn up the heat a little. The darn temperature control decided to give up.... won't turn without a bunch of crunching!
The parts breakdown shows it is one 'module' containing the A/C switch, blower switch, temp switch, defrost switch, fresh air / recirculating switch. Checked with Nissan parts ---- $415 -- WHAT.?? I wonder what they would charge to put it in! My guess the total would be around $800.
Found a used one at a salvage yard in Ft. Worth. $60 shipped with a 1 year warranty. It should be here by Thursday.
   / Good morning!!!! #155,886
Did not rain all day until about 30 minutes ago now 1/4 in and rising
   / Good morning!!!! #155,887
Roy, I hope you have avoided the alligoritis! Hope your daughter gets well soon!
BEF, hope your land search finds you a suitable property.
Drew, that's amazing the amaryllis bloomed down in the basement. Strong stock!
David, take your time on the cleanout project. Those types of jobs always morph into bigger projects.
M7040, is that a pic of your house? Beautiful if it is....
Time to go relax....
Everyone have a great evening!
   / Good morning!!!! #155,888
Good evening.
Got the winter firewood straightened out and covers are up to protect the wood. More to split likely tomorrow.
Then finished the wiring on the Kawasaki race bike. I “saved“ the harness it originally had to get it running. Long term plan is to modify another stock harness, I need this one as a pattern. Not my favorite loom material, but it is functional.
Have a good evening.
   / Good morning!!!! #155,889
Yes that is our house
   / Good morning!!!! #155,890
Thanks.
This area in VA is better for us in the long run. The WV land is very pretty, but only one grocery store and tsc close. Walmart, Lowe’s or HD is close to an hour away. In the winter, it could get rough.
At this VA lot, at least 2 Walmart’s within 20 minutes, and so much more shopping wise. Also no shared road.
Wife wanted to go tomorrow, but I got busy at work today and can’t go tomorrow. BTW, I’m down to 4 weeks before new job.
I did ask for a well quote, and will call another driller tomorrow. Real estate guy sent me the perc info. 4 BR conventional system.
I’m also car shopping. Would like to get that done before new job. Looking at Mazda CX-5.
House at bottom is end of the road. Road comes down right side then goes below the lot. Over half woods. Hill top up in the woods, but not big elevation gain.
AT and blue ridge parkway is near. Perc in upper field area. Electric at the road, both right and bottom sides.
   / Good morning!!!! #155,891
58F and "Fair" @ 22:15, heading down to a low of 57F overnight. Good chance of showers developing after midnight.
Spent some time on the phone calling around for prices, mix of good news and not-so-good news: found a good source on 1's and 2's at a reasonable price (half the price of the guys I normally have used), ready-mix is ... rather pricey ... right now ... :(
Found out the one ready-mix supplier I contacted does not have their own pumper trucks but did get a couple of names of companies to contact so will need to follow up.
Got hopper and 1 suet feeder refilled first thing after I went outside.
Really too wet to work down around the barn so decided to screen that clay.
Dropped a bucketload of screened compost/manure in the depression where the old apple tree was:
Woman spread that out with the bow rake and I ran over it with the Kubota to compact it. Still needs another bucketload and some additional work before it gets seeded.
Got a little better than half the pile of clay screened and moved down to the barn:
Probably finish screening the rest of it tomorrow and move it down.
Woman ran out and got more gas and diesel and took the garbage up to the can at the road while she was at it.
With the rain and cooler temps the grass is growing really fast, will probably mow again tomorrow.
On one of my last trips back up Mom and the three kids were out looking for tasty treats. Ended up getting pretty close to them before they scattered and headed off towards the front yard.
Hope everyone had a great day ... (y)
   / Good morning!!!! #155,892
Good evening all. 56ºF for the start, mostly clear sky, light breeze. Light wind, mostly clear sky, and high temp was 84ºF. Bike ride to start day, slow start, after lunch mowed backyard. did get nap in. Have not looked at battery charge system yet on boat. Also some maintenance on bike before Saturday ride.
Drew glad landlord is splitting the paint in basement, sorry you are getting stuck with driveway stone. Hope you don't flood.
Drew have fun with new tool
Roy hope you don't get sick. prayers sent.
Mike good to hear somewhat better today, no fond memories of rush hour traffic.
Frits glad daughter did not burn down hotel, sounds like busy day for you. ice pic
Dennis sorry no sleep last night.
PJ nice weather, summer not done here either :(
Paul sorry about the trip cancellation.
Don you are getting much warmer than we are in afternoon.
Billy good to hear humidity going down.
RNG good to hear a lot of progress on red bike. Did you send heads out?
Rich good to hear Kawasaki coming along. Always nice to have a real expert in your corner.
Drew interesting potatoes, nice flower pic.
David sorry about the needing to throw stuff away, but they is only so room to store stuff. Good luck deciding what to keep.
RS good to hear sting issues may be over, hope not to wet to work outside.
Roy sorry to hear driveway that bad.
David if those numbers are accurate your heart rate has really dropped way down, way to go!
Mike just think of it as job security.
Drew they are changing color fast. Good luck with new cleaning lady.
Thomas hope you can get off work. Sorry about medical staff lack of sense of humor.
Don not much grass on that course. Hope whipper enjoyed the walk.
Paul good attendance, nice drone and video work.
Ted great news on the Jeep. Sorry about the module, glad you found a used one, wonder if old unit repairable?
Buppies hope you were able to work today.
Rich good to hear wood covered, mine is not covered yet, lot of dry days in forecast. Nice pic
Dennis nice lot. Hope job transition goes smoothly.
RS nice progress today, hope prices work out for you.
prayer for all, especially Jay/Peg, Kyle's daughter and family drama, /mom's breathing, /learning new job, Bird/aging issues/, Don /mom's pipeline process, Randy / RIP /condolences to Family, Roy /palpitations, /angina /wife ankle, not get sick, Billy /wife back & hip, David(moss) /remodel, /divorce, Buppies /3 new skin cancer spots and treatment, /wife knee healing, Thomas /gout, Phil /reflux, /wife's eyes, Frits/ daughters hip replacement /vetran son with mental issues, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted /knee recovery, /retirement, /family issues, /wife feeling bad, Doug and wife/health issues, /nerve and pain, / wife headaches, David(sadamo)/Sophie's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /wife not feeling well, /marriage, / friend stop drinking, Paul/ wife's healing from back surgery, Gale and KY/ tornado victims, Mike /5 year plan, Dennis /retirement plans and land purchase and development, / brother "alligallyitus" and improving, Drew /foot heel issues, /friend cancer diagnosis and recovery,Mike /spine injury and recovery, Helogabals /second opinion, /wife's friend situation, Ukraine war, and Country.
   / Good morning!!!! #155,893
Already did, Ted. This will be measured in weeks, not days with a complete go thru all areas, inside and out. Already got a false start a couple of time with just the idea of picking up and then next day get distracted. Not this time. Could still morph bigger as I do have my eye on Sophie’s suggest to add more roof, but wouldn’t think of doing that until the rest is in order.
   / Good morning!!!! #155,894
Good early (Tuesday) evening and I'm back from Launceston. Spring may be 'in the air' but Winter reminded that it's not gone yet with an early morning Low of -0.5C. The light frost quickly dissipated under a clear sky and light breeze. Cool day with a top of 13C. The roads were dry & clear for the mid-morning drive.
And the visit to the Big Smoke went surprisingly quick! Basically a few minutes in each of the 'shops' to get the things that I wanted or answers to questions... I still had over 2 hours left on my parking docket. :D
Take care all.
   / Good morning!!!! #155,895
2022-09-13, 0414
65° right now...high in the low 70's and t-storms today. Hopefully, we'll get at least ½" of rain too.
Well, back to the job (on-site) today
Thanks for all the well wishes!!
   / Good morning!!!! #155,896
62 high of 80 today very low humidity nice
Did work yesterday Mostly
BEF hope this works out for you
Prayers for all our Country
   / Good morning!!!! #155,897
Any that you can recommend? Most of us have legs that are getting older.
In my case I have a problem with the knee cap on the left leg not tracking correctly causing pain when walking and especially stepping up on stairs. Strengthening muscles around the knee can help pull it into alignment. I picked a few exercises to focus on in the beginning and that has helped to where I can walk without pain and has also improved my ability to walk on stairs and my balance. I would say look at a few videos and pick a few of the activities to focus on and stick with it until you see improvements in strength and balance
   / Good morning!!!! #155,898
67 outside this AM. Rain came through yesterday. It was a soaker event. Then more last night. Should be around upper 70's today. Need to move some animals around so that the roofers don't get bothered tomorrow.
Not much else on the agenda.
Last night while feeding the animals I stopped and watched the sun set. It was worth it, but the grass needs to be cut.....again. LOL.
Hope all have a great day today. Be safe.
   / Good morning!!!! #155,899
Good Morning, 64F going to 75 today. No rain in the forecast. Not much is planned today other the normal household activities.
Got the bivalent booster shot yesterday at our recently completed library in our small town Myersville.
One of the original Trolley cars that ran between Frederick and Hagerstown was restored and placed inside the library. The trolley car dates back to the early 1900's. The rail line for the trolley actually ran across our farm land. The farm at the time was over 200 acres and included the area with highway 40 and the rail line running parallel to it
   / Good morning!!!! #155,900
64° got another .5” rain yesterday.
Nice trolley car. Thurmont has one. I almost bought land outside myersville years ago when I was looking.
Cat CB24B (A60462)
Cat CB24B (A60462)
2006 Acura RL Sedan (A59231)
2006 Acura RL...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2369 (A60432)
2369 (A60432)
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
