What did I do wrong drilling these holes?
/ What did I do wrong drilling these holes? #31
Feed rate is just as important as speed.
Since this was a press....and not a hand drill you should have been able to feed at a pretty good rate.
But for starters....mistake #1 was drilling a pilot hole for such a small final size anyway. That puts all the load and cutting action on less than half the bit...
You only need to pilot larger bits that aren't split point. Then you only need a pilot the size of the chisel point/web thickness of the bit.
Second mistake was light oil instead of cutting fluid.
Others mentioned quality bits. Have no idea what you were using...so that could be a factor.
Third thing.....learn to read the chips.....feed it too light for the speed....the chips coming off turn blue......that's too hot. You either need to slow down the speed or increase feed rate......don't let the chips turn colors more than a light straw color on HSS tooling.
100o rpm on a good press with roughly 5/16" holes....going through 7/8" total....should take no more than about 10 seconds per hole. And that would be at a rather light .005 feed rate had you set automatic feed.
I doubt work hardening was an issue with mild steel. Stainless is notorious for work hardening.....as are some high carbon hardenable steels. But not mild steel.
LD1, what do yo use for cutting fluid? What is the difference between light oil and cutting fluid?
Agree... I also wonder what metal the OP was trying to drill. Sounds like he was drilling stainless.
/ What did I do wrong drilling these holes? #32
Sounds to me like there was enough carbon the steel that it work hardened from the dull drill that was being forced into it and ended that fiasco.
/ What did I do wrong drilling these holes? #33
I agree. There just isn't any way to work harden mild steel... so it probably wasn't really mild steel.
Or maybe not a consistent steel.
Someday I hope to find the perfect cutting and lubricating oil for use on my machine tools, but I guess it's confession time: I use whatever is handy as a drill lube.... Light oil, heavy oil, spit, antifreeze, water, candle wax, or even snow... & my drills seems to work just fine and last a long time.
Most of my old drill bit collection are Chicago-Latrobe HSS. They cut fine & sharpen well. Aluminum does tend to stick to the flutes... but for steel they are fine. For stainless steel caution is needed. But for SS, nothing beats very low speed, lots of pressure, a continuous chip, a waxy lube, and hopefully all with a brand new factory drill bit.
TIN coating is a good anti-stick for chips in the flutes....but I've not noticed it making any particular difference in drilling a hole.
A Drill Doctor is a marvelous tool and takes up a prominent place in my shop along with several well-sorted narrow boxes of drills awaiting attention. A kitchen tableware tray makes the perfect place to put drills waiting for attention. And wait they do; in fact in my shop they've been sitting there by the Drill Doctor waiting for years now.... Being lazy, I tend to just hand-sharpen a bit when I need it.
I will say this about the Drill Doctor..... if you are good enough to use one to advantage you are probably pretty good at sharpening generally. The DD does take some practice. Once figured out, it is better than hand-sharpening.
Lately it seems like more and more of my drills are ruined by poor chucking than by not being sharpened right. Or is it my less tight chucking - getting old now - or are chucks just not as good today?
Drill slowly with enough pressure to keep a chip forming. The lip should be cutting, not skidding.
rScotty
/ What did I do wrong drilling these holes? #34
I have the Darex Professional drill sharpener myself. It's a bit beyond the reach of consumers as it was 2 grand years ago. I rarely use it because I offhand sharpen most times. I do use it on small diameter drills because at 72, it's hard for me to see the ends of the drills and sharpen them correctly and the one I have will sharpen parabolic twist drills as well.
The Chinese drills are junk btw. None here. I tend to use Tap-Magic as drill lubricant. I drill and machine a lot of 300 series stainless and it works quite well.
/ What did I do wrong drilling these holes? #36
Never consulted that chart. I machine a lot of exotic metals and it just works for me. I use Trico Mist coolant as well on the mills and Flood coolant on the lathes and surface grinders.
/ What did I do wrong drilling these holes? #37
Technique and cutting fluid always a trick.
I had exotic platinum/iridium alloy needing micro deep holes. Killing parts and breaking carbide drills. Luckily the shop had over 100 years experience of retired ORNL machinists. Supplied them with 200 proof ethanol to lube/cool the drilling solved the issue.
Monarch 10” lathe with 0.00005” runout incredible.
/ What did I do wrong drilling these holes? #38
Help a novice here. I thought the long stringy chip on a lathe was probably a good thing. What should I look for?
What ruffdog said below.
Lathe tooling usually has chip breakers. IF your speed and feed is set correctly....should see a bunch of little 6's coming off.
The long stringy stuff can wrap around the spindle and fling stuff everywhere, or worse, wrap around the part and break tooling.
Long stringy chips can be dangerous and are a pain to clean up. Maintaining chip control means using a chip breaker and correct feed rate to break the chips into small pieces.
I honestly dont know the difference other than the stuff I use is super sticky and will cling to parts and tooling rather than just run away.
Bout like asking me what the difference between hydraulic oil and engine oil is? I dont know the technical details other than I dont run hydro oil in my engine and dont use engine oil in my HST. Beyond that....i dont know the technical "engineering" difference.
As far as what I use....I like tap magic for aluminum. Its thinner....dont really need tacky/clingy properties for aluminum. For everything else I use either ultra SP which is really good Ultra SP Super Premium High Viscosity Cutting Tool Lubricant Display Unit 4oz Bottles, or CRC Crc 14050 $9.42 Cutting Oil, 12 oz, Aerosol | Zoro.com
I find myself using the ultra-sp for smaller projects or shorter holes. And the CRC for bigger/longer working times simply because the aerosol is easier to apply without stopping.
/ What did I do wrong drilling these holes? #39
The reason I asked about the composition of cutting oil is that a few years ago - around 2006 - I got into some projects in my day job that involved chemistry of fluids. And found to my surprise that a lot of what was being sold in the specialty chemical market was nothing more than bottling and advertising of commonly known solutions used for many years - often with an emphasis on using less expensive ingrediants.
And then I remembered an old machinist who used rendered lard for his cutting lube. I have no idea what else he mixed into it, but he was one of the standouts in a trade that has many..., so that got me wondering.
rScotty
/ What did I do wrong drilling these holes? #40
rScotty
Stearic acid is chemically made lard. Dissolved in acetone and applied for coating punches and dies is a preferred high pressure lubricant to prevent galling for our applications. Machinist made some wicked brews for cutting and penetration.
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2000 REITNOUER ALUMINUM FLATBED TRAILER (A60736)
2000 REITNOUER...
17501-FL (A56857)
17501-FL (A56857)
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
