bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,591
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
No, the pipe is still in the well. It's definitely iron pipe according to the neighbor who saw it installed 25 years ago. I'm familiar with the removal process. the well guys use a special clamp that holds the pipe coupler. It hooks to the lip of the well casing and keeps it from turning while each piece is unscrewed.Did I miss something? Is the 500’ of pipe already out? That is the hardest part. 20-25 years ago means there probably will be 20’ sections of pvc down 500’. So 25 pieces to pull. If the pump is broken off the at the bottom it won’t weight much. When you do it normally, the pipe is filled with water and the pump is on the end. So 500’ would be a lot of weight. But if you pull the pipe without something to support it out of the hole it will break. So you need something to support each piece as it comes out and gets unscrewed from the next piece of pipe. Or just factor in getting new pipe.
It is possible the pipe and or pump was damaged when it hit the bottom of the well so it probably should be pulled completely to check. In that case, a new pump on poly pipe will go back in.
