bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,591
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I suddenly lost all pressure and water began collecting around the well head. The well is +/- 500' deep with a 3/4 hp. submersible pump in a 6" casing. I dug out and exposed the pipe where it connects to the casing and found water spraying out around the pit-less adapter. I removed the pipe from the adapter and found it was loose where it connects to the well casing. Like a bone head, I pulled the loose adapter from the casing without first securing the pump pipe at the well head. Yeah, the pipe, pump & wiring went for a swim. As I recall, the pump was set about 30' above the well point so the iron supply pipe & broken adapter should be 30 to 35' below the well head. Unfortunately, I can't see it with a flashlight and the steel recovery cable has long since rotted away.
Since I lack any special equipment, I called the local well service company but they are still backed up due to the pandemic. They say it could be a month before they can get out here. Luckily, the well serves just the barn and I'm carrying water up from the house for the livestock.
I could put the system back together myself if I could recover the pump. I don't have to pull it completely from the well, just enough to install a new pit-less adapter. I know the weight of the pump and 400+' of pipe will be excessive. Assuming I can grapple the pipe somehow, I'll have to rig a tripod & winch to lift it. Well drillers use a camera, special grapple and winch rig to recover pumps. Should I just keep hauling water and wait for the experts?
Any advice would be appreciated.
