How to Recover a Lost Submersible Well Pump
/ How to Recover a Lost Submersible Well Pump #31
I recently had a well pump replaced. The experienced well technician had a boom truck with special rigging to lift the old pipe up one section at a time, then grip it again close to the well head so the recently raised section could be unscrewed/removed.
I can't imagine trying to DIY that using a tractor, bucket, come-a-long, or anything else available to me. The vertical lift and need to hold something up that high, securely, while changing the attach point was beyond that ....
Yes. Pretty much how 90% of older wells are done. The special rigging is just a threaded short piece of pipe attached to the boom. Screw it onto the pipe like the previous piece that was removed. Lift the remaining pipe up. Slide a plate of metal that is big enough to go around the pipe and sit on the well head, but smaller than the joint. lower the boom down to rest the pipe on the metal plate and unscrew the pipe section now above the plate. Once unscrewed move it off to the side With the boom. Unscrew the short pipe. Screw that into the joint sitting on the plate. Rinse and repeat.
/ How to Recover a Lost Submersible Well Pump #32
On the reasons not to attempt the retrieval, the possibility that trying might block the well irreparably would be high on my list. Drilling a new 500' well isn't going to be cheap anywhere.
Using @LouNY's pipe numbers, it would seem that the lift is on the order of a ton; 1500+lbs of pipe, 80lbs of water in the pipe, 110lbs of wire, and a hundred pounds or so of pump. Oh, yes, and the safety cable. You'd also need the well head clamp for the right sized pipe, and the winch to pipe adapter, and the 4-8' pipe wrenches need to unthread 25 year old pipe. Plus of course, the grapple capable of lifting a ton safely, the 25-30' winch tripod to be able to lift a 20' section clear of the well head, and the winch that is capable of safely lifting that much weight without overheating.
All that I am saying is that to me this is a little more involved than snagging a lost fishing rod in a pond.
All the best,
Peter
/ How to Recover a Lost Submersible Well Pump #33
All the best,
Peter
Why would you go to the trouble, time and expense to unscrew the pipe if you are going to replace it. Just take a portable band saw and zip it off.
/ How to Recover a Lost Submersible Well Pump #34
Not sure id want all the metal filings going into the well. Im sure alot would even if you try to block well head between cuts.
/ How to Recover a Lost Submersible Well Pump #35
Nothing like rusty steel on the bottom of the well...
/ How to Recover a Lost Submersible Well Pump #36
All the best,
Peter
Wouldn’t the only additional water weight be the amount of water in the pipe that’s above the water level in the well? Anything below the water level in the well can be discounted. So now it only weighs…. A lot more than I can lift safely.
/ How to Recover a Lost Submersible Well Pump #37
The danger is getting the power cable or the safety cable or something else wedged between the pump and the bore wall. If that happens, then OP is in serious trouble. Let the pros do it.
/ How to Recover a Lost Submersible Well Pump #38
😆 wise guy. Yes, you are right. Totally valid point, but I did take a stab at that. So here is the bigger thinking. If the well is 500' deep, and the pitless adapter and wires are in view, that means the assembly didn't drop that far, so the water level above the pump couldn't have been that much higher either as it is only a 2HP pump lifting 470'+, and therefore not high flow. Plus, you don't drill wells deeper than you have to to get the yield that is needed. (Guesstimated at the yield rate of 5-7gpm, and some draw down.) If it is in really impermeable rock, even below his shale, then yes, the water column might be 100-200', and I didn't budget for that much. That is more like a Vermont well drilled into granite ($$$). The real weight is the iron pipe; the water is may be 5% of the total, less if you are right and the well is low flow with a high water table... I didn't add in the extra weight for the couplers, which are another 25-40lbs, depending on what schedule pipe they are.
All the best,
Peter
/ How to Recover a Lost Submersible Well Pump #39
I think you have to accept two things:
1. You are going to need a new pump and pipe.
2. You're not going to be able to install the new pump and pipe yourself.
I think the most you can hope for would being able to get the pipe end to the surface and reconnected so that you can have water until a professional can replace the pump. You'd have the side benefit of not having to pay to have the pipe lifted (although if you can do it, it probably would be pretty easy for a professional.) If you got the pipe to the surface you could cut the end off with a sawzall and use a flexible coupling to attach a new pitless adapter, that should keep you going until it can be permanently fixed. If the pipe end is fairly close you could pull it up with a winch or even a come-along, 2,000 lbs is a lot but it's manageable. You'd need something to tie onto which could be your tractor.
So the first question is establishing how far down the end of the pipe is. You could probably use a fishing weight on a string and try to hit it, but I like the idea of the endoscopic camera. The real issue is grabbing onto the pipe. Specialized tools are made for grabbing the pipe. I couldn't find a lot of info online, but I did find one here: The Fetch broken well pipe and pump removal tool . It's about $700 to buy, they also offer a rental option which is about $500.
How far is it from the house to the barn? A roll of 3/4" black poly pipe is about $.50 per foot, PEX is slightly cheaper. It might be easier to run a temporary pipe from the house and wait a month.
Well it turns out, one of the wires I see 10' down in the casing is the end of the steel retrieval cable. It was the clamp that attached the cable to the casing that rotted off. The cable itself appears to be 1/4" galvanized steel and looks to be in pretty good shape. I should be able to grab it but it likely won't be long enough to clear the top of the casing. I would have to hold it taught and try to get a come along clamp on it:
It should make it easier for the pro's but just another tool I'll have to get. The consensus of posters seem to think it would be best to let the pro's handle it. So far, I'm inclined to agree.
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
17501-FL (A56857)
17501-FL (A56857)
2016 Peterbilt 579 (A60462)
2016 Peterbilt 579...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Sdlanch SDLE20 (A60463)
Sdlanch SDLE20...
