Can all tractors flip over easy?
/ Can all tractors flip over easy? #121
One way to roll over a tractor = drive in snow on a incline parallel to a bank and start sliding towards the bank instead of moving forward. Even tho the awd 4 tires a spinning forward but the tractor is sliding sideways towards the bank. On snow spinning tires are no traction gravity takes hold and ooopsie.
**** happens really fast. I've been lucky so far. I've got ditches banks and hills that lead to the ditches and banks. Go VERY slow. There's no hurry.
Best to not take chances. If you think its sketchy its sketchy. Stop the tractor and re-asses you intentions. Sometimes another viewpoint is good. Or just call it a day. Take a sleep on it.
Time for chains
You have the right idea.
Common sense is the key.
N series tractors have been doing just what you say you want to do for 80+ years and will be still doing it after you are gone.
Just the number of them still in operation should tell you something.
Stumps & roots will be a challenge but doable.
The REAL advantage to an N is price and reparability.
They are cheap to buy & keep running.
I've had mine for pushing 30 years now and haven't rolled/flipped it yet & I have some hills that "could" be a problem if I did something stupid on. Back to "common sense". It helps.
The rest of this thread I just laugh at as it doesn't have ANYTHING to do with normal operation that YOU will most likely encounter.
Go ahead & get the N, it's a great learning tool.
Later you "MAY" want to get something newer when you find more uses for tractors.
I saw one that might be a good project for $1000. Don't know if it is what I should do, but it was enticing. Then I saw kits, some expensive.
I don't know enough to know if something is good for a project vs parting out and me getting ripped off. I guess I should start another thread or search existing first.
DO YOU GUYS REALIZE YOU RAN THE "NEWBIE", WHO WAS THE ORIGINAL POSTER OFF SEVERAL DAYS AGO?????
I am surprised by most of you, and that especially means you Mossroad, because I thought better of this forum! We were all in his shoes at one time and needed guidance with what we needed to accomplish using what we had available. Y'all gave him the impression that an 8n would not plow new ground safely. Can you even begin to calculate the number of aceage that has been broken with a plow behind an 8n since it was new?
We should have helped him realize what it took to operate it safely rather than going off into a rabbithole.
Y'all do realize that an 8n isn't even a trike, so why push the issue?
I will go back to my corner, but wanted all of you to realize what you had done.
David from Jax
It's no problem. Folks fuss about the finer points of everything, but I did get worried people must have been dying right and left on the 8N.
I need to figure out what constitutes a rollover risk angle. My small bit is not perfectly flat, but I don't know it's enough to tumble over.
/ Can all tractors flip over easy? #124
It sure would help if this were easier to get exactly right. A terrible tractor accident just happened not far away, where I hike sometimes, 4 dead, 8 injured. Sounds like mostly children. Lost control and went down embankment -- don't know if rolling was cause, but must have been involved at some point.
/ Can all tractors flip over easy? #125
Pretty much if an N runs, it's good to go.
Remember, nice shinny paint doesn't make it work harder.
Front end loaders are not recommended for them and grease makes the steering easy.
EVERY part for them is STILL available and there is no end to the help you can/will get on line.
As you can tell, I would recommend you go for it.
12 people were on the tractor? Pulling a hayride trailer?
/ Can all tractors flip over easy? #127
"YORK COUNTY, Pa. (WHTM) – One adult and three children have died after a farm tractor rollover crash in York County, according to Pennsylvania State Police (PSP).
According to PSP, a 36-year-old adult female and 11 children were riding in an open flatbed trailer being pulled by a tractor when the driver lost control and left the roadway. The trailer flipped and rolled down an embankment, throwing all of the passengers out of the trailer.
The adult female passenger and three children, a 6-year-old girl, a 9-year-old boy, and a 14-year-old girl, who were riding in the trailer were confirmed deceased. An adult male was operating the older model farm tractor and officials are not sure how the vehicle lost control."
/ Can all tractors flip over easy? #128
From reading various similar accounts, I'm not sure "rollover" is how we would describe the accident happening. If the accident started because the tractor left the roadway and started down the embankment, for whatever reason, it's bound to start rolling over, but that might not have been how it started. Maybe "accident resulting in rollover" might be more accurate than "rollover crash".
In that location, you can't go far without steep hills. Trying to hold a big flatbed trailer back while descending a steep hill could have overwhelmed the drive train or brakes, or lifted the rear end enough to lose traction, or all kinds of things. I suppose an "older model tractor" as it's described in some accounts would have had no 4WD and no front brakes. Also, in this region, many people won't use rubber wheels for religious reasons, and steel wheels on pavement would skid much more easily (Furnace road is paved).
/ Can all tractors flip over easy? #129
1- twinwheels really help,
2- realise counter weights on the front compensate for instability when lifting stuff on the rear and moving about on slopes,
3- most importantly when towing : attachementpoint should horizontally lay below the rear axel !
/ Can all tractors flip over easy? #131
If I were to venture a guess as to what happened, the man driving the tractor may have turned around to check the trailer while driving down the road. It is really easy to lose control of a tractor if you turn around to look behind you. I've almost done it with a tractor running down the road in high range full speed and turned around to look at my bush hog. Started to go toward the ditch.
/ Can all tractors flip over easy? #132
8n has a pretty wide stance and low center, I would think they wouldn't be a threat to tip at all compared to other tractors. They are also wide front end.
/ Can all tractors flip over easy? #133
I've had a dozen or more 8n tractors. Never even came close to flipping any tractor ever.
Be glad, it's your worst nightmare. I barely survived a sideways roll over before I had a ROPS cause I did not see a large pot hole in the grass. When I woke up, I looked up at the gearbox bottom of my Iseki ... The second slip in the mountains was when I entered wet grass that was hiding an edge, I slid downward front first, for 20M of height, banged into a fallen tree, jumped 3M through the air tractor and all. Was lucky that I got out undamaged, but I had enough of the mountains and sold our property. No more wood cutting and works on the mountain sides for me!
/ Can all tractors flip over easy? #134
How you are configured and what you are doing is the question. I have lately begun to think that my 7106 FEL is ill suited for my 1220 Ford. It puts too much mass, too high, to be safe on anything but flat ground. I've had it on two wheels so often now, that I'm a bit paranoid. I'm also realizing that my vision isn't what it once was. Sometimes I'll walk a section with and with out my glasses. With the glasses, everything looks good. But then walking without the glasses, I can see and feel that the terrain is much more steep than I thought.
/ Can all tractors flip over easy? #135
Those Roll bars are 3' too high and will upend you when they catch any overhang. They also need diagonal bracing.
/ Can all tractors flip over easy? #136
In the good ole days tractors were built as tricycle (narrow front end) because too many implements mounted on a tractor such as a corn picker, cultivator, and more. These tractor and the danger of roll over was just an accepted fact. Most who operated those tractors knew this and practiced safe operator but yet accidents did happen. The problem came when a part timer or a newbie. or even someone that did not understand the danger operated a tractor carelessly.
Harry Ferguson studied the problem of tractor pulling plows, hitting objects and flipping back over, often killing the operator. So he invented the three point hitch. Experimented with some tractors in England (Black and David Brown) before coming to America and allowing Henry Ford to use them on his new 9N tractor. In the late 40's or early fifties Harry asked Henry to stop using the hitch on the Ford tractors. Went to court Harry won, and Ford came with their own system in 1953 with the Jubilee. The patent soon ran out and every manufacturer used the three point hitch instead of their own hitch.
John Deere was concerned with safety and roll overs in the late 50's or early 60's and "invented" the Roll Guard. In the interest of safety the allowed other manufacturers to use the design for their tractors. Early cabs were no more than tin and glass boxes and were no protection in a rollover, so manufacturers and aftermarket cab makers soon integrated a roll bar in the cabs.
Dangers of roll overs are higher on the old row crop tricycle tractors were a lot higher, until the adjustable front wide frontend became popular.
Utility tractors are safer due to their lower center of gravity. Even then roll bars are recommended.
Back in the 70's I believe roll bars were mandated on all new tractors over 20 horsepower. Interesting John Deere rated the 400 at 19.9 HP so the did not need a roll bar.
If you purchase a tractor and want to use a roll bar there are folks who make them for just about any tractor. These have been tested and are usually tagged with the allowable weight of the tractor and the maker. It is not recommended that someone grabs some steel and weld his own together. That is unless you know your steel and understand the forces involved.
So if you purchase that old N series Ford and want a roll bar here is a place you can get one. Not cheap but what is your life worth? There may be more, just search the web.
And don't forget the seat belt!! It doesn't help if you fall out of the seat and still wind up under the tractor.
/ Can all tractors flip over easy? #137
I thought about buying an older tractor like an 8N, but then I started reading about them flipping over. I'm sure you can use common sense be pretty safe, but I got to thinking that maybe all tractors could flip? Was looking for advice on safety. I was thinking I probably need a sub compact now because they look safer, but I could be fooling myself.
It for plowing new ground with stumps and roots, mostly the leftover roots.
Edit: I have no experience with tractors, if you couldn't tell.
You bet they can. If you park on muddy ground and then get an overnight freeze, putting the tractor in a forward gear can cause you to flip over when you let out the clutch. The rear wheels can freeze to the ground and the torque reaction can flip the tractor over. It can happen to any tractor not just those early models.
/ Can all tractors flip over easy? #138
A N series Ford or similar tractor are usually safer than the new scuts or cuts as the wheels are wider and can be set wider. Most of the new small tractor have a very limited width adjustment if they have any.
As I stated above The old Fords have a very low center of gravity so the are hard to roll sideways, especially when the wheels are set wide. As for rolling back over that is why the three point hitch was invented. For drawn (pull type) implements Hitch ONLY to an approved drawbar. Do NOT hook to the axle housings or the top link mount. Follow these cautions even if the tractor is equipped with a roll bar.
Consider one thing, there are millions of old tractors that were never rolled over and have been operated for many hours on hills, rough ground, etc. But remember too accident can happen especially if you are careless. Think and act safely no matter what you do.
/ Can all tractors flip over easy? #139
That Rover... 💜
Glad you're alright, that's not a game you want to play twice.
/ Can all tractors flip over easy? #140
That Rover... 💜
Yeah she's become a beauty indeed, after 3 years of restoring. She nearly took my toe off when the new chassis fell during rebuild, but hey life's a ***** ;-)
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
JCB 510-56 TELESCOPIC FORKLIFT (A64279)
JCB 510-56...
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A61573)
2018 GMC Sierra...
UNUSED WOLVERINE MCB-11-48W 48" HYD 4N1 BUCKET (A64281)
UNUSED WOLVERINE...
