JD 1050 - LABOR COST for cleaning and reinstalling injectors?
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #21
Thank you very much for your suggestions and the tips. I will have the job done by someone who knows what he is doing because, as another member mentioned, a injector puller tool is required for this kind of job and I don't want to screw it up. I appreciate your taking the time to send those links.
Does the manual say you must have a puller?
I pulled Ford 1310 injectors without puller or any difficulty.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #22
I'm thinking it depends more on the engine, alloys, tolerances than on the manual. Some injectors pull easily. Yanmars are notoriously tough engines to pull the injectors out. It's just a guess, but my guess is he will need a puller on that engine. Not that there is any reason why he can't try it without one. All that will do is maybe mess up an injector but it sounds like he is going to replace them anyway.
Of course any mechanic with a box full of puller, scrap iron, a torch and some threaded rod can probably fabricate something that will work - the injectors have an accessible thread, the head is flat, and they are all three separate and on top of the engine. Old individual injector type diesels are deliberately built to be easy to service. Very simple engines
If they do come out without damage the injectors come apart and can even be rebuilt. These are old style individual mechanical injectors - not the new electric/hydraulic ultra-pressure common rail types.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #23
Excellent advice, I will follow your suggestions. Thank you very much. I am not a spring chicken myself and I thought that my
preference for older, skilled people and old equipment was just because I can't keep up.
It's not just you and I keeping up, the whole manufacturing industry has changed while we weren't watching. It took them awhile, but manufacturers finally noticed that maybe perfecting all the best features in tractors that were high quality and designed to be easily repaired wasn't the brightest profit-making idea they could have had.....
So in the last 20/25 years they changed from repairable and gone whole hog towards replaceable. It's been a major shift in manufacturing philosophy, and we are just beginning to see the changes that will create in everything from education to economics. If you are interested, google some articles on "The Right to Repair".
For those of us who like wrenching, we are living in a Golden Age. Good old machines of every type are dirt cheap and available everywhere.
Enjoy!
rScotty
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #24
One of the problems with green paint is that they figure if you paid the premium price for the equipment, you can also afford to pay a premium for service and parts. The same thing happens in the auto world. Wife drove an A6 for a few years...oil changes and everything else were more expensive. Same with Lexus vs Toyota...an ES300 is a Camry with nicer appointments and you pay more for maintenance, parts and repairs. Congrats? You're rich? :)
Your location is listed as brattleboro, Vt. Ask your extension service or the Vermont Farm Bureau to recommend a mechanic. Swapping injectors - with the right tools - is just a little more difficult than changing spark plugs - as long as you don't have to drop the engine for access.
/edit - And don't do what I did on my IDI 7.3 Ford - Don't get air in the injector lines - it took me a LONG tome cranking to bleed it out!!
Thank you very much for the advice. The injectors are right on top and by looking at the service manual it is a very easy job (for someone who knows how to do it). I found out that it requires a puller at the cost of $100. That is nothing compared to the $1,000 (one thousand) PER INJECTOR = total $3,000 that the local JD asked for. All I need to find now is a mechanic.
Enjoy!
rScotty
Indeed, when I bought my first car in the '70s windshield wipers used to last a lifetime. Then they got worse but at least you could just change the blade (a pain in the butt but manageable). Now they last maybe a season and you have to throw away the whole thing and buy new ones.
What a waste, just for the sake of indecent profit.
Thank you, I am learning a lot through the thoughtful suggestions I receive. Contacting the extension service and farm bureau is a great idea and I will add it to list of possible resources also for future reference. I found out that my tractor requires a specialized puller to remove
the injectors. It's not too expensive but the complexity is still above my level. I will definitely need an expert to work on it.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #28
Rememer that the injetors take a special kind of washer.
Order them from the agents
I do not have the part number
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #29
$135/hr is not out of line for shop time, but I'm curious about the "cleaning" part. Are they disassembling the injector and inspecting the pintle and seat? Doing a pop test with calibration fluid? Not really worth it for a $118 injector, but pop testing a new one is. I have found defective new injectors by pop testing.
If they found diesel bugs and dirt in your tank that ruined your injection pump, that tells me that you are not up on changing primary and secondary fuel filters, and not insuring you're using clean and dry fuel.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #30
$135/hr is not out of line for shop time, but I'm curious about the "cleaning" part. Are they disassembling the injector and inspecting the pintle and seat? Doing a pop test? Not really worth it for a $118 injector, but pop testing a new one is. I have found defective new injectors by pop testing.
What I am learning is that doing any type of mechanical work is now considered a specialty and the work is priced beyond most tractor owners....nor do they have the impetus to use tools. That is interesting in a way, because doing things for ourselves is traditionally how a recession/depression economic cycle is dealt with at the personal level. This one may be different. Although to make that even more attractive, the price of parts - even JD1050 parts - still seems reasonable.
Looking online, at $125 for a replacement fuel tank and $60 for a complete primary filter including mounting, it is hardly worth cleaning the old ones. An injector pump at $525 and injectors for $118.... add them all up along with a few tools and it seems easier and cheaper to simply replace the entire fuel system. That's a job any high school mechanic could do.
rScotty
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #31
I would call an injector service in your area and get an estimate on cleaning. They will check spray patterns as part of the service. You can then decide if you want to clean or replace. Another consideration is parts are not as good as they used to be, thank globalization.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #32
One other thought since Bob brought up filters that it may have been the filter problem and not the injection pump. I had a problem that turned out to be dirty tank and filters on a compact loader I bought recently. Would run for awhile then lose power. Tank was dirty and filters needed replacement. Nothing should get to the pump if filters are in place.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #33
I have a JD 1050 (I believe it is 20 + years old) with a 3-cylincer Yanmar engine. The JD dealer replace the fuel injector pump (that I bought) and now wants to 'clean' the injectors.
The estimate he game me seems way too high.
Does anyone know how many hours it would take to install the three injectors?
I am considering buying new ones (they don't seem too expensive) but I am concerned about the labor cost for installing them.
Thank you (I am new to this kind of world, just took over a small farm from my retired father-in-law who is no longer physically and mentally able.)
Farmer Marx
I am old school. If i faced paying 2k for finishing that particular job, i would consider that i am being ripped off. At most, it should only take 4-5 hours for the whole job. Three days to clean three injectors… nah
I would be buying a repair manual and making friends with youtube…
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #34
I compared the price of cleaning injectors for an old JD and I decided to just buy new ones. No way I would pay that dealer to do anything. If you ask around or even check craigslist you can find mechanics that are looking for work. They are much cheaper and if you get some recommendations, you can find someone that does good work. I had my injector pump on a 4020 rebuilt by a fella that had retired from the local JD shop. The injectors, I just changed myself. I think you should give it a try. If you own a tractor, you must acquire some basic maintenance skills.
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #35
I sure do agree with both of these. I suppose it is possible to simply pay to have every little thing done for you instead of acquiring some basic skills....but then you risk losing out on half the enjoyment.
And you also lose one time-tested way to sidestep the effects of an economic recession/depression.
So do it yourself if you can - and know when not to do so. Injectors are easy; injector pumps are NOT!
The exception to all the "do it yourself advice" - including mine - might be simply age. I know I'm getting to that point where I have to have some things done that I'd enjoy doing myself. No sense in speeding that process up, though.
rScotty
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #36
I own the same tractor. I’m gonna order new filters again pronto after reading this. Lol
/ JD 1050 - LABOR COST for cleaning and reinstalling injectors? #37
My 1050 with rear 3pt log drag, boom pole that extends another 4.5 feet. Home built.
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2007 Volvo C70 Coupe (A61569)
2007 Volvo C70...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
Case CX75C (A62177)
Case CX75C (A62177)
New/Unused AGT Flail Mower for Excavator (A61166)
New/Unused AGT...
