Bentrim
Gold Member
- Joined
- Apr 22, 2020
- Messages
- 374
- Location
- York County, Pennsylvania
- Tractor
- Massey Ferguson 245, Massey Ferguson 14 Allis Chalmers G
As an old once young farm kid that was operating tractors too soon to realize the dangers of them.
The row crop tractors we had were all of the tricycle configuration. Simply because they were high enough to go over growing crops, and they used mounted equipment such as cultivators and corn pickers. Also note it was easier to turn at the end of the field because the axle did not stick out and hit a tree or the fence row. If you notice most row crop tractors built in the 30's, 40's, 50's and early 60's were built as tricycles. As you would think most of these were used for tillage and other work across the slope NOT up and down, reason it was determined that you had more erosion and loss of top soil when ground was worked up and down the slope.
Having been raised on a farm and operating tractors I was very aware of how to prepare and operate tractors across the slope.
The utility tractor most always had a wide front end AND like for example the 8N ford was a much lower tractor. They raked the hay and other utility work.
Most all work was done without any precaution as to wheel spacing etc. Even plowing on a steep slope with the lower wheel in the eight inch furrow was not a problem. But when needing to mow extremely steep slopes the wheels were made wide as possible. Note that most "modern" subcompact and compact tractors have very limited rear wheel width adjustment and are usually fairly narrow, even though they are low they are not very stable on hillsides.
In the early 60's de to the narrow rows and other needs wide front ends became more popular now you cannot find a new tricycle tractor. Also about this time manufacturers started being concerned with safety and started manufacturing roll bars. Even the old "tin" cabs got replaced with cabs that had integrated roll bars.
Most tractor accidents are caused by carelessness or operator error, such as going too fast, turning too short, loader too high, hitching too high, traveling to fast with the brakes uneven, not knowing the terrain you are working on, and I'm sure you can add more.
By the way Harry Ferguson was tired of hearing about farmers killed when the tractor rolled backwards, that is why he invented the three point hitch. When used correctly it is very hard to roll a tractor using a three point hitch.
Tractor safety is all about the "nut" behind the wheel. If you have any question how to do something safely read the operators manual and the safety brochure that accompanies it or visit an old farm equipment dealer. In the mean time remember to hitch up to only the drawbar, or three point hitch, travel slowly, know the ground you are operating on, and keep the loader bucket low. If you feel you need a roll bar search the web, there a companies that make them for just about any tractor.
Oh by the way there is no machine on wheels that can't be upset, Z turns, lawn tractors, garden tractors, If it has a foldable roll bar -- get it up, if it doesn't have one check out getting one if you want.
But no matter what THINK SAFETY.
