YMM-45 MMM Spindle assemblies.
/ YMM-45 MMM Spindle assemblies. #1
Rcpilot82
Member
Yanmar YM135D
I am trying to put together my YMM-45 deck that was tore apart by someone else. They had the 2 outboard spindles in pieces to re-build them. I have the new bearings and all but 2 seals (working on that). I blasted all the parts and will probably just powdercoat them for durability.
Now, The problem is I don't have any exploded views or information on how to re-assemble the spindles. Does anyone have any information on this and recommended pre-load procedure for the tapered bearings? I also am going to need a locknut for the middle blade as the heat required to break it loose melted the nylon.
Any Help would be great!
/ YMM-45 MMM Spindle assemblies. #2
I know someone who does know all about these mowers and parts. Gary Jamieson
Jamiesons Tractors
RR5 Box 5146
Honesdale PA 18431.
Ph 1-570-253-4810.
gandgjamieson@pgtv.net
Winston, yes I know Gary as well. I got an air cleaner housing off him a few weeks ago. I think I have all the parts I need though, just need to see how to approach the re-assembly and if there are any special issues to address. I'll shoot him an e-mail anyway.
That helps! is there a procedure for pre-loading the tapered bearings?
Also do you know what #23 is the first pic?
/ YMM-45 MMM Spindle assemblies. #6
The manual calls it a 'cup washer -5/8'
It does not mention anything in the manual. I would just set them like a trailer axle tapered bearing which is usually: Tighten the nuts fully tight, rotate the spindle a few times in each direction to be sure everything is seated, loosen the nut completely, then re-tighten just beyond finger tight.
It does not mention anything in the manual. I would just set them like a trailer axle tapered bearing which is usually: Tighten the nuts fully tight, rotate the spindle a few times in each direction, loosen the nut completely, then re-tighten just beyond finger tight.
Thanks for the Information! I also just received information from Gary so I hopefully will be good to go.
/ YMM-45 MMM Spindle assemblies. #8
Did Gary have any advice on preload?
No, there doesn't seem to be any specifics on that so I'll just use the method above. It looks like the only thing I am going to need is a new locknut that holds the spindle in. Item 9 on the spindle. Should be able to find that locally once I get the size.
/ YMM-45 MMM Spindle assemblies. #11
Bonjour, est-ce que quelqu’un peut m’expliquer comment assembler le ymm-45 sur mon um135 s’il vous plaît?
/ YMM-45 MMM Spindle assemblies. #12
Translated: ‎Hello, can someone explain to me how to assemble the ymm-45 on my um135 please?‎
/ YMM-45 MMM Spindle assemblies. #14
/ YMM-45 MMM Spindle assemblies. #15
  • nh-143046-307310-1478427 MOUNTING LINKAGE.pdf
  • nh-143046-307310-1478428 GEARBOX ASSEMBLY.pdf
  • nh-143046-307310-1478432 SPINDLE ASSEMBLY.pdf
  • nh-143046-307310-1478434 CLUTCH DRIVE ASSEMBLY.pdf
  • YANMAR YMM-45---NH-FORD-915-143046-307310-1478440 DECK.pdf
/ YMM-45 MMM Spindle assemblies. #16
Whilst searching for any remotely related manuals, I did find pages on Ebay and elsewhere for this YMM-45.
/ YMM-45 MMM Spindle assemblies. #17
The remaining pages,
This should provide a bit more help.
Click on the images and then a second time for FULL SIZE.
/ YMM-45 MMM Spindle assemblies. #18
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
