HAllen
/ HAllen #1
HAllen
2130 john deere
Bought a 2130 John deere ,after starting tractor thepower steering nor hydraulics will work until you start turning the steering from left to right a couple of times power steering starts working then the front end loader will also start working?
/ HAllen #2
G'day Mate and welcome to TBN from Downunder, from wherever in the world you are.
Well, it's got to be something 'common' for that/those symptoms to occur. There must be a screen or valve within the hydraulic system that is gummed-up or sticking until you engage the steering, 'handraulically'. It's an older tractor and I don't know when the hydraulic fluid was replaced and the filter/screen cleaned.
Info on your tractor: TractorData.com John Deere 2130 tractor information
/ HAllen #3
HAllen
Welcome to TBN
Since you have a newly purchased used tractor 1st/simplest thing to do is change hyd filter(JD part # AR75603) & check/clean hyd oil suction screen. One needs to drain hyd oil or block hyd filler hole with a plastic bag in order to create a vacuum to slow oil from draining. I suggest to perform my suggested maintenance then report back.
/ HAllen
Thanks for your reply I changed oil and filter,cleaned the screen. I also opened the flush valve,, on the front hydraulic pump,with no results still got the same problem. Coming to you from Hallettsville,Texas.
/ HAllen
HAllen
Welcome to TBN
I changed the oil and filter and cleaned the oil screan and flushed the front hydraulic pump. I also installed a control valve for the front end loader,closed system.
/ HAllen
HAllen
Welcome to TBN
/ HAllen
I changed the oil and filter and cleaned screen and flushed the front pump, still no change.Added a close system control up front for front endloader.
/ HAllen
/ HAllen
Idid the maintenance on the tractor when I had a new engine installed, cleaned oil screen and changed the hydraulic oil and filter.
/ HAllen #11
What are you referring to as a ''flush valve"? I've never heard that term used on JD tractor closed center hyd system. Next I suggest to disconnect & cap power steering supply line & cap fitting to determine if hyd's operate better with power steering not operating.
/ HAllen #12
I'm 'grasping at straws' here, but does this include raising/lowering the 3PH (3 point hitch)?
/ HAllen
Yes it does include the 3 point hitch.
/ HAllen
The 3 point hitch is part of the problem.
/ HAllen
/ HAllen
Well it's a valve used to bleed foreign material from the pump. I'll let you know what happens when I cap the power steering supply line,may not be until next week.
/ HAllen #17
OK, so it's the entire hydraulic system that needs to be 'nudged' to start working. And then the hydraulic system works for everything... so the 'common' fault is something that activates the hydraulic pump.
That's why I asked about the 3PH... you only mentioned that the power steering and the FEL wouldn't work until you'd moved the steering wheel back'n'forth a few times.
A sticking relay?
/ HAllen #18
A sticking relay?
JD 2130 normally has no relay associated with it's closed center hyd system. Frt hyd pump has a stroke control valve that when seated correctly allows hyd pump to create pressure.
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2008 UNKONW  SPOOL TRAILER (A60736)
2008 UNKONW SPOOL...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2020 MACK PINNACLE DAYCAB (A60736)
2020 MACK PINNACLE...
