Can a propane tank be repurposed?
/ Can a propane tank be repurposed? #42
Air tanks at work are State Inspected for safety...
No one inspects my home set up.
When I worked at the Tool and Machine there was an ancient riveted air tank... it predated anything modern.
Inspector tested wall thickness and boss had to install a pressure relief and signage not to exceed so much PSI...
It could date from the 1800's
/ Can a propane tank be repurposed? #43
When you refer to a one pound cylinder, are you talking about the little disposable propane tanks?
As others have said, do yourself a favor and just go buy a small tank. Roundup is caustic and trying to compare it to an air tank is like comparing apples to rock salt.
/ Can a propane tank be repurposed? #44
That’s why most sprayers are plastic: herbicide and insecticides are corrosive to metals.
/ Can a propane tank be repurposed? #45
PVC for compressed air is a bad idea. So is trying to reuse a 1lb propane tank for compressed air just to save some money.
Buy the proper materials and be done with it.
For some information:
OSHA does not allow PVC for compressed air unless it’s buried underground. It’s assumed that when it explodes underground, the ground will prevent shrapnel from injuring humans.
PVC joints are inconsistent.
PVC degrades with age and becomes brittle.
PVC degrades in sunlight.
PVC degrades in cold temperatures.
PVC explodes, while PEX splits.
PEX would be a much better material than PVC.
Some information from a PVC pipe manufacturer.
/ Can a propane tank be repurposed? #46
5 pages and this will be just as if not more convenient?
/ Can a propane tank be repurposed? #48
MossRoad,
Your suggestion makes much more sense than kluging something together into homemade bomb. Thanks for a moment of sanity.
/ Can a propane tank be repurposed? #49
I don't think you could find even one Amish farm here that doesn't have an old propane tank for storing air!
They pump them up twice a day with a small diesel engine, as they milk their cows/goats.
SR
/ Can a propane tank be repurposed? #50
I've got a 4 gal sprayer cart on wheels so I don't have to pump and I can throw it in the Polaris ranger and spray on the go.
/ Can a propane tank be repurposed? #51
W8BYA,
All pressure vessels have a rated lifetime for a reason, to keep people safe from Rapid Unscheduled Disassembly ( thank you Elon Musk ). There is a date stamped on the side of the 20+ Lb propane cylinders and pressurized air storage tanks to prevent it from being refilled after that date and the 1 Lb bottles are built for single use/ single fill only. That is also why the connection on 20+ Lb bottles has been periodically changed to prevent the continued use of older cylinders.
HF does make a connection that would allow you to fill a 1 Lb bottle but you are playing with a hand grenade that may or may not go off. Air pressure tanks have a valve to remove ( blow off ) water that accumulates so as not to compromise the tank by causing internal pitting/ rusting. 1 Lb cylinders have no means of getting rid of water.
Here is propane vapor pressure graph ( log scale ) but I have no idea what the schrader pressure relief valve on top of the 1 Lb bottle is rated for.
Here is a possible non exploding solution
I have a propane tank I use. Last certified 1955. Came off an old camper. It still works.
/ Can a propane tank be repurposed? #52
My entire shop air system is plumbed with PVC and has been for 30+ years, Running 150 psi no problems in all that time, not heated or cooled, from -20 to 110 F. Of course I'm not an attorney nor have I ever consulted one, ergo it can not be done.
1" Sch 40 is rated for 450 psi working and well over 1000 psi burst, sch 80 is rated for 630 psi and even higher burst. Ratings drop as pipe diameter increases.
Well good for you!! Would you bet your children or grandchildren‘s life on that old brittle pipe. I sure wouldn’t, that being said
I have some schedule 80 1 1/4” pipe buried between building for air line, if it blows no one is hurt. Steel risers coming out of the ground.
For all we know the fellow that said make a sprayer out of pvc might be making it out of 4” DWV foam core pipe that’s not pressure rated.
The propane tanks would hold the pressure fine, if you were worried about it you could hydro test them easily. But its still a stupid idea when you can buy a proper plastic than for cheap that will work well.
/ Can a propane tank be repurposed? #53
When Dad passed a few years ago, I inherited an air tank he made out of a 20lb propane tank. I had a 10 gallon tank for inflating tires and such, so after it sat around the shop for a while, I decided to repurpose it into a couple of flower pots.
The larger one I added four legs to hold it up, the smaller one I added a couple of handles to. Painted them Kubota orange and JD yellow.
/ Can a propane tank be repurposed? #54
SR
He's not talking about an air tank, he wants something to pressurize for Roundup. Furthermore, those one pound single use tanks are just that; single use.
/ Can a propane tank be repurposed? #56
Gee, I've always pulled out the Schrader valve and crushed them in my press.
Never thought of making a piggy bank out of them.
/ Can a propane tank be repurposed? #57
We made bead cheaters that pop tires on the rim. Old propane bottles. 150 psi all day long.
The little bottles have a relief on them. When you fill them, it sprays out when full. So how can you over pressure that?
By putting 5.6 gallons of propane in a 5 gallon bottle, then wait for high ambient temperatures. That might do it?
And yes you can over fill a tank by not shutting off the pump when you see liquid propane coming out the bleed valve. I've watched someone do it, just to see if anything would happen.
/ Can a propane tank be repurposed? #58
Sure you can but by the time you buy adapter to tank, shut off valve, regulators and plumb it all together, you can probably buy a small "power" sprayer for less....
/ Can a propane tank be repurposed? #59
I was specifically referring to the one pound bottles. They have a relief that sprays out when full. That's how you know it's full yes, the fish cooker bottles have a screw that you loosen and fill until gas comes out, then tighten. I've used butane tractors and trucks we filled from a 500 gal tank. We had a Minneapolis Moline and a John Deere 4020 that ran on vapor and a GMC truck. I know the truck was a 73 3/4 ton with 500 grand on it and still ran nice.
/ Can a propane tank be repurposed? #60
Link to effects of temperature on PVC pipe. The pipe will expand when temperature rises and get brittle when it gets cold. At 110 degrees F, the PSI rating is half of marked value on pipe.
I would not reccomend using pvc as a pressure pipe for anything except an underground water system.
just my opinion.
Many years ago in an industrial accident we had to leave the shattered plastic shards sticking in a guy for fear that pulling them out would cause excesive bleeding. On the ambulance radio we took instructions to give plasma multiple times in route to the emergency room (closest Medical facility was a 31 mile trip). When we got to the hospital they were waiting for him and took him directly to surgery.
They used 5 pints of blood to as they removed the plastic pieces from his body.
INOP/NON-RUNNING 2004 International 4200 Dump Truck, VIN # 1HTMPAFM64H660244 (A65563)
INOP/NON-RUNNING...
3142 (A63117)
3142 (A63117)
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2017 Chevrolet Silverado 1500 (A64194)
2017 Chevrolet...
