How Hard Can a Tractor Pull?
/ How Hard Can a Tractor Pull? #1
Suburban Plowboy
FL
Kubota L3710
I tried to pull a big rock out of my yard with my Kubota L3710 and got nowhere. Today it occurred to me that I should think about getting a come-along.
So how hard can a 37-horse tractor pull? I don't really know. I can get a come-along that supposedly pulls with two tons of force.
I also have a Dodge with a 5.9 Cummins. They seem to do well against farm tractors, at least on Youtube.
/ How Hard Can a Tractor Pull? #2
Generally speaking a 4-WD tractor's ability to pull without losing traction is proportional to the tractor's bare weight.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Kubota L3710 Dimensions​
Kubota L3710 tractor photo
1998 - 2002
Grand L10 Series
Compact Utility tractor
Kubota L3710 Weight
4WD gear :2,955 lbs
1340 kg
Hydro :2,990 lbs
1356 kg
Hydro cab :3,490 lbs
1583 kg
Yes, tire type makes some difference, as does transmission type and the soil under the tractor tires, but the key metric is tractor WEIGHT.
Based on experience I SPECULATE your tractor can pull/drag a rock around 2,000 pounds (+/-). A fairly high friction load.
Thanks for the help.
So a big come-along chained to an oak should be a lot better.
/ How Hard Can a Tractor Pull? #4
Should be...........if the big rock weighs no more than 4,000 pounds and the rock is not mired in cement-like earth.
Drape a couple heavy beach towels, moving pads or old blankets on the cable as it draws taut, before applying full force.
Oh, it's mired all right.
Sometimes I wonder if it's the size of a house, and I'm trying to pull it out by one tiny corner.
/ How Hard Can a Tractor Pull? #6
Somewhat unlikely in Florida, but not impossible.
In nine years of plowing, ripping, disking and raking soil around Fanning Springs, Florida I have encountered only one (1) rock larger than an orange. That one "rock" was a chunk of soft lime-rock somewhat larger than a basketball.
Check this out.
/ How Hard Can a Tractor Pull? #8
I am going to guess NW Florida?
North Central.
There are some fully-exposed rocks in my yard way bigger than that. One is like a pool table.
/ How Hard Can a Tractor Pull? #15
I also have an L3710, I've pulled fully loaded one ton dump trucks out of the mud, buried to the frame. I also routinely pull 3+ ton hay wagons. Rolling weight is different from dead weight. I'm sure your tractor will out pull most 4wd trucks. Mine has a FEL and loaded R4 tires.
/ How Hard Can a Tractor Pull? #20
It will pull really easy if you first judge it onto a rock sled etc...an inverted car hood makes a good one among other alternatives...!
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2014 BRENNER 210 BBL CRUDE TRAILER W/ PUMP (A65643)
2014 BRENNER 210...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
