Starlink
/ Starlink #2,621
I remembered something. SL's "crackerjack" programmers don't seem to have considered that one iPhone might be used to setup more than one Starlink. A few weeks ago, I encountered much SL weirdness about this. I believe SL hard-sets some parameters in the controlling phone. Those parameters are then in conflict with any new or different SL you connect to.
Before rebooting my SL 3 times, I tried accessing SL using my wife's phone. Ahhh, more bugs. Her phone acted as if SL had never been set up. This is strange, as I used her phone to set up this exact SL system. (Since my phone seemed to be "contaminated" from having setup a different SL system before.)
Her phone offered a button to click to "Start Setup." Had no choice but to click on it. When I did, rather than running the setup process again, it immediately said: "Setup Complete!." Ain't life grand? :D
Then I was able to go into bypass mode on her phone .............
/ Starlink #2,622
@RedNeckGeek You might want to check that your access points aren't putting you on your presumably bandwidth throttled guest network. I.e. try deleting all of the WiFi authorizations except for Gunsmoke 5GHz on a single device, e.g. a tablet, and rerunning the speed test.
Here's a snap of the Statistics tab in Unifi Network for the iPhone:
Doesn't look like the WiFi link is the bottleneck, at least not from the Rx Rate and Tx Rate being reported for the iPhone:
Looking at the RF Environment of the iPhone on channel 36 shows a pretty narrow 5G band is being used. Would a wider band channel be faster? Or would it even matter, since the Rx/Tx rates are already much higher than what SL is reporting in the iPhone app speed test?
With the SL router running in bypass mode, the SL app on the iPhone reports 16 Mbps down and 6 Mbps up today. The readings are fairly consistent. FWIW, this area is currently wait listed for new SL residential.connections.
/ Starlink #2,623
Just ran a test, also in a waitlist restricted area. From a wired PC-- 29mbps down, just under 3mbps up.
Shortly after that, one iPhone reports 116mbps down. A 2nd iPhone reported 36mbps down. All within probably less than 2 minutes.
Just noticed on the Starlink app, at least on mine, it no longer breaks out phone to internet vs router to internet. So I'm not sure which of those the phone is measuring?
/ Starlink #2,624
You may have encountered a bug in the SL implementation. I suspect it thinks you are not "logged in" to your account with an appropriate name and password. It's also now happening to me, but I don't know why.
I was having problems logging in to the SL app on an iPhone when I let a password manager automagically populate the username and password fields. When I manually typed in the username/password, I was able to login. Not sure if that's the same problem you're seeing, but it's an easy fix to try.
/ Starlink #2,625
Here is another oddity:
"My" iphone set up a Starlink (in Nevada) that is dedicated to a residential address.
"My wife's" iphone set up a Starlink RV system (now in California) that is subject to speed reductions.
Using both phones, simultaneously, connected to the "Starlink RV" system in California, they report different speeds. Wife's speeds always seem to be slower, sometimes by a lot. Plus that phone includes a message below the speed about using the "RV system" that is subject to slowdowns.
My phone always report faster speeds. And although it's connected to the "RV" system, it never shows the message about that.
Hmmmmmmmmmm.
/ Starlink #2,627
Found an email from StarLink this morning, asking me to sign a petition to encourage the FCC to not let Dish Network re-purpose the 12 gHz band. Doing so would likely ruin SL use, even for rural users like me. You can use the link above to directly access the petition even if you're not a SL user or didn't get the SL email.
/ Starlink #2,628
Dare I dream of the day, my SL is good enough I can fully cancel my Dish? Ahhhh, the hope.
/ Starlink #2,629
My setup stopped reporting two speeds when I put the router into bypass mode. My guess is because the phone to router part is now handled by the Unifi network hardware, not the SL router.
/ Starlink #2,630
I have Dishy2 and have had the ethernet adapter installed about a month. The SL router is in a basement location that does not provide enough coverage for the entire house so I connect the ethernet adapter to an Asus mesh via the ethernet adapter/cable that is in a more central location. I did not put the router in bypass mode. Smart TYV's, some Alexa devices, computers, phones, and tablets connect to the Asus router. We do not seem to be having any issues by not using bypass mode.
Despite reasonable speed tests, I get some buffering while watching YouTube TV and when making cell phone calls using wifi calling, I get dropouts. I believe the buffering and dropouts relate to a tree that has leafed out since winter and obstructs Dishy. I'm working on moving Dishy to a better location to see if that helps.
/ Starlink #2,631
Fast.com (in your screenshot) has nothing to do with Starlink, so that's not going to give you any insight as to your LAN speeds. But in the Starlink app, if you open the Speed Test section, you can swipe up for the advance speed test section, which will allow you to see WAN and LAN speeds.
/ Starlink #2,632
We will have to disagree that it provides no insight.
Using my phone thru the Starlink app, I can view speeds without "contamination" from my LAN, my equipment, or any of its potential bottlenecks.
But from a PC using a speedtest site, operating on a LAN that doesn't change, I can monitor for such bottlenecks. Plus, it gives data on relative changes at differing times of the day-- such as better speeds when the Starlink network is lightly loaded vs slower speeds when it is loaded.
The barely-consumer-grade SL router also figures in. Put it in bypass mode to use a "normal" router with typical routing functions and capabilities-- then how do you speedtest using the app?
/ Starlink #2,633
When running with the Ethernet adapter in bypass mode, the Speed Test function is still available in the SL app on the iPhone. But there is no Advanced option. Not surprising since bypass mode shuts down the SL router WiFi, and other functions as well. Depending on the router you're using, you might be able to see speed data from clients to the router. That info is available in the Unifi Network app if you're using one of their managed routers.
FWIW, under Setup in the SL app, the only settings available are the Snow Melt Configuration, Stow Starlink, a graphic showing how to reset the router, and an Advanced button that gives the options to Debug Data and Reboot Starlink. At this point, I'm not too sure why I went to the trouble to put the SL router into bypass mode. Leaving the SL WiFi active didn't seem to hurt anything, and going to bypass mode might have even slowed down the SL router's connection to the SL satellite, at least in my case. If I get some time later, I'll reset the SL router and run another set of speed tests.
/ Starlink #2,634
Yes, you are correct. So am I, but I wish I was not. lol
My phone app misbehaves-- not allowing speedtest and sometimes anything at all. Best I can tell- it's because it wasn't the *original* phone which set *that* particular Starlink up.
I previously got speed test results from both my phone and my wife's phone. Those were the ones which showed different speeds and different presentations although they were taken at almost the exact same time. (??)
I'm pretty sure I'm dealing with some non-standard weirdness because of having more than one phone involved. One phone that originally set up *that* Starlink, and a different phone I was trying to use for configuration.
I need to remember to not use the wrong phone with each particular SL system. Each phone is somehow "linked" to the SL it set up. And it doesn't like talking to a different SL.
I do have a 3rd Starlink on order-- but only have access to 2 phones. That ought to get interesting!!! :D
/ Starlink #2,635
I tried as best I could to not use bypass for my SL in California. I let SL control the network and took my own router out of the loop. But it would work perfectly for less than a day, then any remote access would shut down. Locally, it seemed the LAN was working fine, but the remote access would just stop.
I use remote access using Synology, Synology Surveillance Station, and IP cameras. Best I can tell, you *must* use fixed IP for cameras so the Synology Surveillance knows which camera is which, and even how to find them on your LAN. And I believe those fixed IP's were crashing something when using the SL router.
I went back to bypass mode on Monday, put a traditional router back in, and everything seems stable since then .... we'll see.
/ Starlink #2,636
I did not put SL into Bypass mode, just plugged router directly into my Ubitquiti switch, leaving my eeros and unifi nets as they were. Seem to work well. I did try to incorporate my USG but that blocked my internet access. Haven’t had chance to explore if there is a USG setting I can change. The USG would allow me to add my LTE connection (I think). Of course I’d be almost playing in the dark as to knowing what I’m doing . Other option is to put SL into bypass, but at this point it’s working well so hate to mess with it.
RNG, will be interesting if your UDM Pro works in non bypass. Looking forward to your report.
/ Starlink #2,637
It took several weeks to figure out the SL app login problem, and during that time the SL router was NOT in bypass mode. The UDMPro was working just fine, and speed test results were much higher than they are now using bypass mode. Speeds were higher when the iPhone was logged in to the SL WiFi than when using the Unifi APs. And the iPhone->SL router speed was higher using the SL WiFi, too. The bottleneck is clearly the UDMPro, as SL Router to Internet speeds remained consistent when I was able to test in non-bypass mode.
It could be that you need to create a static route in your USG so that it knows the IP address of the SL Router. Look under Network -> Settings -> Routing and Firewall -> CREATE NEW ROUTE
My settings are as follows:
Give the route a name
Enable it
Type is Static
Destination Network is 192.168.100.1/32
Distance is 10
Static Route Type is Interface
Interface is WAN
It was working fine, then for some reason I disabled it, and things continued to work. So you may or may not need this, depending on your setup.
/ Starlink #2,640
I don't remember that-- what did you find was the problem?
I use a password manager, and for some reason when it auto populated the username/password fields, the login would fail with a message about INVALID CREDENTIALS. Typing the username/password on either the laptop or iPhone solved the problem.
2001 FREIGHTLINER FLD132 XL CLASSIC (A67714)
2001 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
