sharpening mower blades
/ sharpening mower blades #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
If you are like me you prefer sharp mower blades. I like to sharpen them with each mow. So I cycle three sets of blades for my Ferris zero turn. But it's still a massive $#$&@&$#*% PITA~!!!!!!!!! I got these great grinder disks from PFERD, They are fabulous I got them in 2019 for my large and 4.5" grinders. I've done a lot of sharpening and mill scale removal and the disks I installed back then are still on my grinders. Unlike flap disks, if used correctly (Read Do not lean on them) they last forever and cut steel like butter. Anyway, I got a triton gizmo vice thing to do my grinding outside instead of the dusty shop. BUT STILL, it was a pita. Set the grinder down struggle to get the blade out of the vice flip it clamp it and bend over for the grinder.
Yah, I know modern problems; they built the pyramids with copper chisels and rocks lashed to sticks. Anyway I repurposed a hunk of a pallet to this and it's fast and easy. I did all three sets in like 15 minutes plus balancing Tools I made or purchased - The Axlotal Tank
/ sharpening mower blades #3
I have to admit that I've never heard of anyone that sharpens their blades after every cutting. Not sure whether I feel inadequate or relieved . . .
Don't feel inadequate, I get by with sharpening once a year. I mow 3+ acres once a week for about 26 weeks a season.
/ sharpening mower blades #4
Yeah. Me too. At the most!
Thanks for the reassurance . . .
/ sharpening mower blades #5
Unless you're cutting heavy turf with sticks and typical debris etc...you should not need to sharpen blades that often...
...It is recommended to have a smooth cutting edge of about 1/16"...they should not be knife sharp...
/ sharpening mower blades #6
I like the blade holder and will have to copy something. I don't sharpen that often but when I do it is blades for 3 60" decks, at least. 2 Zturns and the BX for the rough or steep stuff.
/ sharpening mower blades #7
The Oregon blade 30-30 rule applies. Ground at a 30 degree angle while leaving a .030 blunt edge.
/ sharpening mower blades #8
When things start cutting poorly then its time to sharpen.... Found out OREGON brand blades work a whole lot better and last longer than the JD blades for my riding mower... Sharpening them after every cutting session is a OCD problem, and should be avoided....
I can Fly with sharp blades and I use less fuel. They get a little dull and I notice it right off. Not noticing it, is a problem with one's situational awareness and demonstrates acute mental disability. Discourage people from relying on you for important things.
/ sharpening mower blades #11
Whatever floats your boat!
I personally sharpen my Gator mulching blades every 30-35 hours or so, along with greasing my zd mowers. For me, that works out to be once per week.
I also gave up trying to keep a 30 degree edge by hand with an angle grinder. I have been using a commercial jig that keeps the edge correct.
I am interested in the grinding wheel the op is using. I'll look it up eventually...
/ sharpening mower blades #12
I personally sharpen my Gator mulching blades every 30-35 hours or so, along with greasing my zd mowers. For me, that works out to be once per week. RjCorazza
you're mowing that much per week? almost a full time job...that much per month seems about right, can't imagine spending that much time on mower every day, maybe you're in the business?
sounds like you have a system though, regards
/ sharpening mower blades #13
That's lot of sharping,after 3-4 mowing I touch up the blades also deck couple inches from ground.
/ sharpening mower blades #14
As cheap as blades are, I NEVER sharpen them. Just replace every fall. I get all my blades from ASC. Save the old ones to make knives from. Good tempered steel.
/ sharpening mower blades #15
Retirement gig, plus I really enjoy cutting grass. I mow 18 rural lawns within a 1/2 mile radius of my house.
/ sharpening mower blades #16
what equip & size are you using? weed trimming too, or just mow?
/ sharpening mower blades #17
If I had 18 neighbors within 1/2 mile I'd have to move. I have 2 that close. One on 80 acres the other on 2 acres split from this property many years ago. Not my doing. Mostly I'm almost surrounded by National Forrest.
/ sharpening mower blades #18
ZD326 60", ZD1211 72", Bobcat hydro walk behind, Stihl trimmers and blower.
The 326 is setup as a bank mower with ag style chevron tires that are fluid filled. I have a set of wheel spacers ordered to widen the stance by 4". The 1211 is my primary mower, and the 36" walk behind is used on really steep banks and gated areas.
I trim half of those 18 lawns, the others trim it themselves.
When I let it go that long I notice the difference in fuel, in energy, in speed I can go, in cut quality, especially if I let it get tall, and I do that rather a lot.
I've never paid attention to things like that. I'm, fairly consistent but I have never once bothered to check the angle.
PFERD
This video made me want to try them, And Oh man~!!!
They are spendy but man oh man do they last and last and last I have thrown all my flap disks away. I bought 'em in Jyly 2021. I put one on my 4.5 angle grinder and many welding projects ago. I prefer to descale any steel I'm going to paint so this one disk I've been using has seen a lot of use between the little Metabo grinder and my bigger porter cable 8". So far I have only used the two disks, one for each grinder and they are still going strong.
/ sharpening mower blades #20
Pretty sure OSHA killed it. Toru once made a 2 cycle push mower that had a disk with 4 sickle bar points for the blades. You could push the handle down to angle mower deck and walk thru waist height weeds.
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2012 Ford Expedition SUV (A64557)
2012 Ford...
2013 FREIGHTLINER CASCADIA T/A 6X4 DAY CAB TRUCK (A67147)
2013 FREIGHTLINER...
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
2014 CHEVROLET 2500 SERVICE TRUCK (A64278)
2014 CHEVROLET...
King Kutter II Tiller for sale.
King Kutter II...
