Well pressure Switch question
/ Well pressure Switch question #41
The relief valve on water heaters is usually set for 150 PSI. Most well pumps cannot build 150 PSI and would not be able to utilize that relief valve. But some can build 120-140 PSI, which could blow up a 100 PSI rated water pressure tank. I use a 75 PSI relief valve with any 40/60 pressure switch. It is good to keep the tank from exploding. But the main reason is to dump some water to keep the pump cool in case the pressure switch does not shut the pump off at 60 like it should as in this case. Yes you can run a pump against a closed valve without hurting anything. But if no water is let out it for some time it will boil around the motor, destroying the pump/motor and possibly melting any plastic well casing.
/ Well pressure Switch question #42
Just remember; when you reset your cut-in pressure/air pad, this MUST be done with system OFF and tank WATER open to atmosphere - your plumber would've mentioned this if he's any good, but it's an easy thing for inexperienced people to forget. Generally the air pad should be 10 psi BELOW the cut in setting (a 40-60 psi setting should have air only at 30 psi) ... Steve
/ Well pressure Switch question #43
With water heaters the problem may be a heater that does not shut off and creates steam.
Actually my experienced plumber volunteered to set the pressure tank air pressure while he had the tank empty, but my portable air compressor I had lent to my neighbor, so I told him I would do it myself next week.
/ Well pressure Switch question #45
Late into this conversation I know... Sorry.
How many GPM is your well capable of producing? Let's say your well is capable of 4 GPM. It is entirely possible to have a pump that is capable of 20 GPM and under a water demand may in fact run your well casing dry. To eliminate the overpump possibility, there is frequently a restrictor in the line from the well to the system, is that what the blue handled valve is to perform or is the (for lack of better terms) "flow restrictor" at the well itself?
One of my wells is capable of 10 GPM maximum flow per well log by driller. I free flow from the pump only 10 GPM by restricting the flow with a gate valve and secure the gate valve handle so it cannot be moved or adjusted. I then flow to the pressure tank with the pressure control switch attached to the manifold. My line from the well may, and likely does, exceed the 60 PSI switch pressure but ultimately I am concerned with the pressure in the tank itself.
Thanks for input Repete.... but as seen above the problem was identified and solved. of note.. a very well respected Well company replaced rhe well pump 2 years ago and my system worked great for over a year and a half, but my high iron/ mineral content bit me in butt of late and constricted a valve that was actually not necessary ( see above earlier resolve described) so all is good now. I imagine lessons learned for many .
/ Well pressure Switch question #47
I know you don't want to hear this. But that same iron/mineral that clogged the valve will just as easily clog the pressure switch itself. Just like you saw last time the pressure will increase to as much as the pump can produce. If is doesn't blow a line or your regular "water well pressure tank", it will cause the pump and/or plastic casing to melt. A 10 dollar pressure relief valve anywhere in your piping system is all it takes to prevent catastrophes like that. But I won't say it again.
My God Valveman, as much as I appreciate the advice, why does asking for advice then become a pissing match to see who knows better at tBN often. You saw 3 ft of my plumbing system and assumed I and my eventual plumber were not taking into account my pressure vessel capabilities, the new well pump , the new pressure switch and new clean nipples , and you assume to know what is 2 ft out of sight over by my sophisticated Laars high efficiency boiler heating system and on demand hot water, installed 8 yrs ago with pressure relief and pressure reducing valves from what I can see. ( but my plumber would know and understand) ......so thanks for your thousand pressure tank installs and I appreciate your attempt to warn me, but there is no need to take a holier than thou attitude now.
/ Well pressure Switch question #49
If a person is worried about over pumping a well you can get a pressure that will operate just like your normal
30-50 PSI or 40-60PSI switch but also has a low pressure cutout function which will shut a pump down of low pressure.
This will help protect against over pumping as well as ruptured lines or other devices after the switch.
/ Well pressure Switch question #50
I suppose that would work but my wife would likely be irritated if the well shut down due to having a sprinkler on while doing a load of laundry and flushing a toilet. Best she just gets low pressure and volume due to the 10GPM limit.
I guess there are a number of ways to skin this cat but I will opt for not cavitating my pump as my over volume shutoff.
/ Well pressure Switch question #51
This one of those times when I wonder why I care and even try to help. I felt bad that my use of the word "boiler drain" made you think I was talking about a boiler. So, I wanted to reiterate how important it is to have a pressure relief valve on a regular water pressure tank. You are the one taking the "holier than thou" attitude. You spent all that money on your "sophisticated Laars high efficiency heating and on demand water heater", and want to believe it is superior. It maybe fantastic but it would still be rare for any plumber to know anything about a well pump system. As was said the pressure relief on a boiler or water heater is set at 150 PSI and will not protect your pump, pressure tank, and water supply system. I don't even need to see 2' of your plumbing system as the scenario you describe would not have happened if you had a proper pressure relief set at 75 PSI. It is obvious your plumber does not "know and understand". But rest assured I will no longer try to help you! Please don't install a 10 dollar pressure relief valve now as I will be waiting for your next thread asking what happened to cause your tank to rupture or the pump to melt down. But what do I know? Have a nice day!
Thats funny, you decided my rural plumber last week does not know about wells, you decided the other plumbers that installed my Laars Combi boiler 8 yrs ago didnt understand they were installing in a well pump serviced house, and you decided my Well pump installer two years ago didn't know what he was doing to protect the well pump he warrantied. ......nope you don't even need to see my plumbing to diss all those folks.....but thanks anyway for everyone elses calm input.
/ Well pressure Switch question #53
Yep! I can tell all of that by looking at that one little picture. I said I wasn't going to help you anymore so this is for the benefit of anyone else reading this thread. When you live on a well, everything you do is dependent on a dependable supply of well water. You can purchase the fanciest and most expensive boiler/heater and tankliess water heater there is, but if your well system is inadequate none of those things will work as they should, or at least not as well as they should. An instant water heater and everything else in a house works better with constant pressure from your well pump system. Getting the right constant pressure system can also make your pump much more dependable and last many times longer than normal.
There is no need to spend all that money updating the other systems if your well pump still just has a little 20-30 gallon pressure tank and a pressure switch. If your pump guy had to warranty the last pump he put in, he may not know as much about what he is doing as he or you think. If he puts a check valve at the tank but not a pressure relief valve, that is a sign he needs much more tutoring. I wouldn't hold it against my plumber that he didn't notice my inadequate pump system, or that there was a check valve were there shouldn't be and no pressure relief valve where there should be. Just like getting the right constant pressure system, pump guys should know these things, but it surprises me how many do not.
Ok SUPER WELL PLUMBER.....you obviously need the last word on your discussions , no one in Canada or USA knows as much as you. I and my various plumbers bow to your arrogance. Cheers !
/ Well pressure Switch question #55
You should say experience not arrogance.
I know who Valveman is, know about his company and have experience with his Cycle Stop Valve: https://cyclestopvalves.com/
I don't doubt that he is good at what he does , but his arrogance overwhelms his communications. Of note My house is 28 yrs old, and I bought it 14 yrs ago , the previous well pump lasted 26 yrs, and I proactively had it replaced 2 yrs ago , before it wore out. The Laars combi boiler has worked flawlessly for 8 yrs, it replaced a wood boiler .....it took 26 yrs for the minerals in my well water to constrict my pressure switch piping and pressure gauge nipple. So I am pretty sure I will die of old age before the pipes are constricted again. Eventually when the bladder in the well pressure tank starts leaking I will have a plumber back in and he can add another port on the feed tee and put a pressure relief valve if he sees need.
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
(5) Drive Motors (A64119)
(5) Drive Motors...
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
2011 CATERPILLAR TH337AG TELESCOPIC LOADER (A64279)
2011 CATERPILLAR...
KUBOTA L3901D TRACTOR (A64280)
KUBOTA L3901D...
