Yanmar tiller ID help
/ Yanmar tiller ID help #21
Good eye! Goodness, you are right, they are everso slightly different in size! I didn't even notice as I was stacking, just that some were slanted one way and others another. Lol wow. She said she's seen sets on eBay before. Once I figure out which is correct I will take a look.
Yes, there will be sets going one way and the other. Even in the modern Yanmar tillers it's the same.
Winston posted this a while back, but it still applies.
The entire thread is here.
Much of the people giving you advice today are the same from the shared thread. :)
/ Yanmar tiller ID help #22
It's pricey, but stainless steel 316 or 316L bolts are way stronger than the generic stainless steel 18-8 bolts. Since it's a tiller pounding on the soil, I would invest in those bolts and nylocks. :)
Read the MSDS or SDS data sheet. I wouldn't want any of those chemicals touching my garden soil.
I do use PB on my daily driver for vehicle repairs. :)
Normal motor oils and synthetic oils all came from the ground at one time. Those would have less impact on the soil. And there are microbes that will break down oils in the soil quickly in a season. Not so with PB, WD40, or the like.
PB is an antifreeze based chemical. This will harm the garden soil, kill plants, and not at all good for wildlife if food plots are made.
For tractors on organic farms, the antifreeze is changed to RV Pet Safe formulas that align with FDA approvals for use. Sierra Antifreeze is propylene glycol based. The same stuff in salad dressings, BBQ sauces, gummy bears and the like. It's also used to fill tractor tires on organic farms, yet pricey.
Not to be a pedant, well, OK, I'll be pedantic. EVERYTHING on the earth comes out of the ground or the atmosphere. It is what we do with it that makes the difference. Lots of the components of crude oil, for example, are carcinogenic right out of the ground. We separate these components in the most simple of distilling processes and get stuff like baby oil, which we can apply to our skin and drink safely. Though drinking it will tend to give a person diarrhea. And stuff like benzene and gasoline, which you cannot safely drink. From reading the WD40 MSDS it looks like all the components are derived from petroleum. Which comes out of the ground. And though synthetic oils are synthesized from from the same petroleum products that come from the ground, they do not exist naturally. Which is why they are synthesized. Anyway, just sayin'.
Cheers,
Eric,
Who also came from the ground in a roundabout way and will return to the ground but in a more direct way.
Ah you just posted.
OK, since the Yanmar logo marking and the color don't match up, the RS1200 and it's related RSxx00 family are in the first PDF. The second PDF is the RC1200, somewhat related, but added for good measure as your tiller is difficult otherwise to identify.
The 48-inches really narrows things down in a good way to the 1200mm (1.2M) width size.
Awesome thank you! Now I just need to brush up on my Japanese. LOL
/ Yanmar tiller ID help #24
You already know Japanese.
Copy page section as image, then past into Yandex OCR. Pick Japanese <===> English.
Page-5 upper left side.
Via Yandex
If it translates funny, zoom in a little more and try again. ;)
Drive Binion shaft = Drive Pinion Shaft
Bevel Vinion = Beveled Union.
Rotagya Case Left = Rotary Case Left.
Japanese is based on phonic sounds to symbols, thus even in translating we sound out the words until it makes sense.
Via Yandex
cool! Thanks again!!
All y'all are awesome, thank you! I had been on here many years ago, but couldn't find my old profile so maybe after so long it gets wiped. But I knew where to come soon as I got this tiller for help! You guys are always so much help! Thank you!
/ Yanmar tiller ID help #27
Lets try another one. :)
Page 7 on the parts side of the diagram to the right.
Bouncing to the diagram and then this list, you can figure out the names.
Now with that said, if you find a part, and it translates really whacky, drop the p/n into a search engine and see if the findings turn up with a proper name. I've done this on many manuals already.
/ Yanmar tiller ID help #28
FWIW: Hoye Tractor sizes the times by the size of the bolts. 10mm small & 12mm large. The small set has 32 tines, with a note that the special "end/center" times are no longer available.
All the best,
Peter
Ah you just posted.
It's the rs1200 or 1300 based on the position of the fill bolt on the gear box. yay!
/ Yanmar tiller ID help #30
It's the rs1200 or 1300 based on the position of the fill bolt on the gear box. yay! View attachment 748494
In the RS1200/RS1300 section, go to page 9. Look at item-1.
This is the parts list to the right.
1264L = 1264mm Long.
1264 / 25.4 = 49.763 inches. You measured 48 inside. That item-1 shaft goes to the outside chain case too.
Deduction, you have an RS1200 tiller. :)
The RS1300 is 1359L (1359mm Long.)
1359 / 25.4 = 53.50 inches. Thus it's a 52 inch tiller.
Glad the mystery is solved. Now it's up to you to work towards the restoration. Keep posting to this thread as you make progress. It will keep us intrigued and help others in the near future with an RS1xxx series tiller.
I'm still amazed at the big round Yanmar logo on the machine; Wonder how it became to be on the tiller.
The farmer I got it from said she got it as is from whereever she got it. She ordered set of tines, which may acct for the various sizes (2 and the 1 oddball)
I've got it all stripped down now - need to relocate a lady black widow and her egg ball, but then i'll be looking to reattach the tines I have based on that other thread that shows the various patterns, and see how many I actually need - IF I need to get any more really at all.
thank you!
Via Yandex
I'm having a little trouble figuring out what the item on section 5 is for? I tried to translate it, but it comes up as a "Debs gauge relationship". It's the threaded pole that has a handle/wheel on the top. It's basically frozen up for now, I've been trying to break it loose. it's been soaked in wd40 for days but it won't budge. Is it imperative to use?
Also, I need to find another bolt for the bolt that holds the arms. (I can't find it in the diagram, so sorry it's a terrible description. I'll shoot a pic)
/ Yanmar tiller ID help #33
WD40 is one of the weakest oil to use. Something that old and stuck needs Deep Creep.
Plenty of YT vids showing how weak WD40 and PB are. In many instances hydraulic oil can beat WD40 & PB.
/ Yanmar tiller ID help #34
That wheel adjusts the 'training wheels' in back up/down for depth control. If you don't have the wheels, ignore it. (Most modern tillers don't have depth wheels at all).
I've read that ATF + 25% Acetone is the best penetrant. Works for me! That's my favorite since both are free, from the re-use shelf at the county's Hazardous Waste Disposal facility. Anything that's legal to sell in California goes on that shelf instead of being trucked and buried at a disposal site in the Nevada desert.
/ Yanmar tiller ID help #35
Heat often helps lubricants get in, especially if there is some residual tension when hot.
I think that the translation was perhaps not that far off. Saying it out loud sometimes helps me...
"Depth gauge adjuster"(?)
I have a friend who does simulataneous Japanese English translation, as well as technical translations. I remember two that she brought to me for help on the concise English meaning;
IIRC,
cold-hot-cold-strong-pressed-rock (gneiss) and​
Stiff-motion-time-distance-height-music-observation (vibrational stiffness testing of a foundation floor)​
I may have the English version of the kanji wrong with the passage of time. Apologies to all Japanese speakers out there.
Personally, I am fascinated with the different ways concepts and items are named and described in different languages. Some concepts are easy in some languages and quite alien in others. I remember one language that had a phrase for "thank you", but really only foreigners used it, and there was no word or phrase for "you are welcome", but gratitude was expressed in other ways. It made me think a lot about how to express gratitude towards others.
All the best,
Peter
/ Yanmar tiller ID help #36
Those tiller depth wheels can work as hiller discs too. Some of the tillers have the wheels nearly straight out the back and just off center and not at the outer edges.
ah well, no wheels or hillers (I have a sep attachment for those anyway), so I'll quit fussing with it. lol THANK YOU!
/ Yanmar tiller ID help #38
If you are talented, you could fab something up like the original to use as a hiller off the back of the tiller. This way, 1-pass to do 2 jobs. And with the price of fuel, that is a SAVINGS right there. :)
Here is an RS1303. Notice the hiller or training wheels. IF one swaps the right and left wheels via the positional brackets, then the hiller function can work.
Additionally, I came across another tiller with the round Yanmar logo. It seems this is a masked template and using a white rattle can the logo is made.
It would be neat to find out who the re-seller of these marked tiller were once they got here.
/ Yanmar tiller ID help #39
The link down to the wheel axle, like half a bicycle fork, should be on the outside of the wheel for the wheel to roll straight.
Or, set up like in the photo with the link on the inner side, the wheels will crab to maximum and have some hiller effect. Or at least, cut gouges.
1654621591496-png.749285
Here's where I learned this. I then swapped wheel assemblies left/right, no more gouges.
p1640595rrototilling2011-jpg.222411
/ Yanmar tiller ID help #40
No gauge wheels and never a need for my mothers old garden. She said planting was effortless. The pic. is as low as the 3Pt. would go down. Really deep.... 1st of the season pass.
2017 International HX620 Quint Dump (A62613)
2017 International...
John Deere 6130M (A62180)
John Deere 6130M...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
2010 Deere 318D (A62180)
2010 Deere 318D...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
