Well pressure Switch question
/ Well pressure Switch question #1
wawajake
Canada
Kubota BX2660 , Kubota RTV X1100C
So I have been worried my water pressure is too high in my house. If I can trust the pressure gauges ( one at entrance to 30 gal pressure tank and one near carbon and string filter setup) when well shuts off with the 20 /40 pressure switch at 40 psi, the well pump clearly can be heard to shut off, but the pressure gauges continue to rise and even out around 80 psi ( if I can trust the gauges) I got a new gould 240 volt submersible well pump 2 years ago that replaced a 20 yr old one, my well is 30 ft deep spring) I did try adjusting the two nuts on the pressure switch and now have it turning well pump on at around 15 psi , if I can trust gauges , and well pump shuts off at 40 psi, but pressure continues to rise to at least 75 psi. What do the well experts here think is going on ???
/ Well pressure Switch question #2
Could you draw the water circuit, scan the drawing, and post it? What you are describing should not be possible, but it's unlikely that two separate gauges would give wrong information. I'm stumped.
No scanning tech skills , but water comes in thru 1 1/4 " check valve past pressure switch tee, and pressure gauge tee, into pressure bladder tank, then out tank thru water softner, then thru carbon and string filter and another pressure gauge tee. Then to hot water tank tee off and cold water system etc etc. ( lots of inline valves to isolate the previous described components) I do notice that the pressure gauge near pressure tank is sometimes 10 psi different than the other gauge)
/ Well pressure Switch question #4
A couple dumb questions, but have to ask . . .
You are not also connected to a city water supply, right?
You're not pumping water way uphill or into an elevated tank that could leak back past a check-valve, right?
Doesn't seem possible to build up pressure AFTER the pump shuts off. Does it feel like a fire hose when you first turn on a faucet or does it feel like typical 40 PSI well water system?
No not connected to city ( 20 miles away ) and top of well is 6ft in elevation down from house) I do agree it does not seem like 80 psi coming out of taps.....but replaced two toilet flush valves that began leaking over past year.( two different toilets)
/ Well pressure Switch question #6
Are your pressure gauges both standard 100# range gauges?
/ Well pressure Switch question #8
If you trip the breaker to the well pump as soon as you hear the relay in the pressure switch shut off, does it still build up pressure? Do you think there's some way that the pump is being backfed voltage? Could it be running on one leg of the 240 volt circuit?
/ Well pressure Switch question #9
Clutching at straws here . . .
/ Well pressure Switch question #10
Don't know if it would account for the pressure increase you are seeing, but got to ask... Is the hot water heater cycling after the well cuts off and adding pressure into the system?
/ Well pressure Switch question #11
Check your tee's for the switch and gauges.
I have seen the tee's get plugged up with rust and corrosion,
then it acted like a very small orifice which slowed down the pressure buildup.
Also many gauges will have a restriction orifice to reduce pulsation on the gauge.
/ Well pressure Switch question #12
To add does your water heater have a thermal expansion tank and also have you tested that you pressure relief valve is working on the tank.
/ Well pressure Switch question #13
Like @LouNY, I would bet on a corroded or partially blocked portion of your system.
On my water system, the piping to the pressure switch, and the internals of the switch, are prone to clogging and will produce a pressure overshoot, but that won't explain the gradual pressure rise after the pump cuts out. Since your pressure gauges keep rising, I would bet on the gauges either having crud in them, or in the piping that connects them to the system. Most gauges have brass internal tubing which does corrode, and any gauge can get filled with sand or hard water deposits.
High system pressures are hard on everything, (pipes, valves, gauges, tanks) so it is worth getting after the problem in my opinion.
All the best,
Peter
I think the crud in the tees to gauges is quite possible ( high iron content) I wondered if that could cause high....will research a few suggestions here over next few days.
/ Well pressure Switch question #15
You might want to flush the tees and then put in new gauges and a new pressure switch, and while I was at it, I would probably replace the 3/8" piping to the pressure switch and gauge. (In brass or PVC) The fact that the pressure rises after the pump kicks off probably means that your pressure is that high, which may mean that you have a pressure switch issue as well.
One question; it looks like you have copper piping plumbed into galvanized. I don't see any galvanic isolation in the photo. If you don't have isolation, I would put in 3-6" of PVC between the copper and the galvanized pipe, otherwise, your copper pipe is going to be accelerating the corrosion and rusting in the galvanized fittings.
All the best,
Peter
/ Well pressure Switch question #16
I've had similar behavior when the tiny pipe leading to the pressure switch was plugged with rust. Our water dissolves galvanizing quickly. I replaced all the little pipes and fittings in the system with brass.
Bruce
/ Well pressure Switch question #17
Bruce
Seen this before. Gauge and pressure switch pipe clogged.
Thanks for all the advice, I decided to call local plumber, but now with advice here at TBN I am less likely to be led astray by any mischievous tradesman. At minimum I will have focus on him replace small piping with brass to new gauge and pressure switch and I have a new spare pressure switch already. Hopefully they return my voicemail this week with an appointment. I am going to see if I can find a pressure gauge tool that screws on to hosebib to give me a accurate read to calm my nerves in future. Meanwhile everytime I walk by pressure gauge in mechanical room and see it at 75 or 80 psi , I turn laundry tap on to relieve some pressure. ( but I swear it doesn't seem like 80 psi in faucets)
/ Well pressure Switch question #19
I would start by replacing the gauge.... costs less than $10 normally for the part and easy to do... the newer gauges have short life spans.... When i adjust pressures whether 20/40 or 30/50 I always just replace the gauge before even trying to adjust the 2 screws as this keeps at bay lots of aggravation many times... I often find no problems at all other than gauge has crapped out.... I would bet a steak dinner (or gallon of gas) that if you are seeing an 80 psi reading the gauge is toast.
/ Well pressure Switch question #20
You can make one easily enough. Just use a hose bib to NPT adapter and a bushing with the gauge screwed into it.
2022 INTERNATIONAL LT625 DAYCAB (A67714)
2022 INTERNATIONAL...
2017 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
2004 Mack CX613 Vision T/A Wet Kit Day Cab Truck Tractor (A66736)
2004 Mack CX613...
2025 Swict 60in Bucket Skid Steer Attachment (A66734)
2025 Swict 60in...
2017 International WorkStar 7500 T/A VacCon VPD4211 Combination Sewer Jetter Vacuum Truck (A66736)
2017 International...
2014 Jeep Cherokee Limited SUV (A66738)
2014 Jeep Cherokee...
