Pallet Forks
   / Pallet Forks
I think 60” forks would be a nuisance. They’re going to stick through the pallet a considerable distance and accidentally hit stuff on the other side. BTW, shingles are way heavier than they look and the M59 won’t lift a bundle.
Hmm... two guys that know tractors & both say stick with 48".... So I guess that settles it.
It never crossed my mind that the M59 wouldn't pick up a pallet of whatever. Now I wonder if palletized loads are standard weights?
A pallet of the shingles I'm looking at is said to weigh about 1800 lbs. That should be well within the M59's capabilities. I've carried 3200 lbs (30" concrete culvert section) on a chain that went over padding on the front of the bucket lip. So the weight was centered below the bucket lip. That's the max I've done. It had no problem lifting that load and traveling a few hundred yards - but I wouldn't do it again. I went slowly. Very slowly.
rScotty
   / Pallet Forks #13
4570Man made the point: the extra length is likely to be more troublesome for most maneuvering. If I expected semi-regular need for longer forks I would probably spend the few hundred bucks for fork extensions; the aggravation of puncturing walls or whatever would quickly out-weigh the cost of the extensions..
If you need 60” forks you’d definitely realize it and it wouldn’t be a debate. Otherwise buy 48 or 42 ones.
   / Pallet Forks #14
rScotty
A bundle of plywood is 3600 pounds or so. The M59 didn’t want anymore but it’ll do that. I can’t imagine any full pallet of shingles being 1800 pounds. A pallet of dimensional shingles is 4400 pounds and that’s a no from the M59.
   / Pallet Forks
I agree on those numbers. The shingles I'm using are stone-coated metal type. They are much lighter.
Thanks. I'll get the 48". BTW, I didn't know there was such a thing as fork extenders...
   / Pallet Forks #16
Bunks of plywood are a standardized weight, but palletized freight isn’t.
   / Pallet Forks #17
The Bobcat pallet forks had a nice sticker chart on the guard noting the max lift VS distance on the tines. Sure drops off fast. Some loads I could curl lift to clear the ground or off the truck but couldn’t lift straight up.
Sometimes forking a pallet or stack is only time I turn off the soft ride FEL system because of the bounce. Carrying a load particularly steel on steel much smoother when on.
Rear implement ballast a must.
   / Pallet Forks #18
I have a set of 42" forks and regret not going to 48". Tough to see the tips of the forks when they are 42" and you are trying to align them with a pallet.
Check out Skid Steer Attachment Depot. I ordered from them and their prices and service are great.
   / Pallet Forks #19
Titan owner here. 60's because I also lift snowmobiles. I use a pallet to put items onto and lift them onto my mezzanine in the garage for out of the way storage.
1843 (A57192)
1843 (A57192)
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
