SSQA plate to three point adapter?
/ SSQA plate to three point adapter? #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
Wondering if anyone's ever built, or bought an adapter to hook a QA SS implement to hook on back of a tractors three point. Like a three point SS built land plane? Most use of a land plane on a SS is back dragging any way, in my experience. Only thing I've ever found was a QA attachment to hook a three. point tractor implement to a skid steer. I built one four years ago but the QA pins would never hold like I wanted them to, recently modified it to fit my tractors quick hitch after I sold my SS and every attachment besides an 84" landplane. My yooper rigged hose hanger is just temporary had pretty good results after practice with the hydraulic top link, able to put a little crown in driveway and trails with manually adjustable side link on tractor. Total cost 100 bucks for QA brackets 4 yrs ago, scrap steel, and 7018 rod. Still completely usable on a skid steer if I sell, remove two bolts and put flat face couplers back on. The pipe on lower arm of adapter to quick hitch is sleeved 6" into pipe with hardened pins I had lying around.
Darn it 😂 oh well 4 yrs ago I swear I couldn't find one. Thanks though. I'm pretty sure that's lighter, easier to attach, and use than my over built contraption, the prices on some would make it cost prohibitive in my case. I think I could buy a 7' box blade for the price of some of those adapters anyway.
It does do a pretty nice job though. Before and after.
/ SSQA plate to three point adapter? #6
I've built a couple SSQA to 3pt adapters, going the other way. SSQA plate then just weld a cheap Harbor Freight (or usually garage sale) 3pt Quick Hitch on. Parts arecaround $50 each at garage sales if you are patient. Double or triple that new. You can buy them pre-made for $400ish. But if I recall the QH ones are superior to hitch up, at least if you don't have top hook clearance issues.
My first one was the mounting point for a snow plow. Sold with the old tractor & plow. I built the new one just for moving & loading other impliments.
Thought about one to put a bucket or forks on the 3pt, but never gotten around to it. Couple hundred for the male SSQA mechanism, which is to expensive for me (or to much effort to fab up myself).
View attachment 747988View attachment 747989View attachment 747990
/ SSQA plate to three point adapter? #7
Good idea and I recommend building in some extra rollback like the adapter has that I bought from Washburn Company:
/ SSQA plate to three point adapter? #8
I don't disagree in principle. Not much roll back in my units. But it will tilt the unit past 90 degrees down.
Any extra angle pushes the impliment further out & decreases capacity a bit. Pointing the unit down & hanging my heavy flail vertically means I can lift it. But it pointing straight out is to much for my loader to lift. More curl past vertical would be handy than all the dump range I have.
If you ever work under the loader, make sure there are mechanical locks or supports. If I ever work on my flail while it's dangling I prop up the loader with some 2x4s that will take the weight. Hydraulics aren't reliable for safety & need backups if you will be under there.
/ SSQA plate to three point adapter? #9
I'll agree with adding the roll back angle,
I didn't and could have used it sometimes;
I've seen lots of three point implement to SSQA adapters when I was looking 4 yrs ago. My goal was to keep the ss landplane as unmolested as possible and be able to hook it to a tractor three point which I was able to do, minus two 5/8" bolt holes. there are quite a few adapters for SSQA to hold three point implements some even have a hydraulic motor hookup for a PTO shaft. Personally wish I would have been more actively involved in tbn before I committed to build my contraption 4yrs ago in the first place as I'm sure like a lot of folks after a small or large project is done you always find a better way to do or build something. Like i said my SS landplane works good probably better than a box blade imo, for my usage on a L4150s tractor three point with a hydraulic top link.
/ SSQA plate to three point adapter? #11
I tried doing the same thing a while back using parts I had laying around. By the time I figured out what else I needed to buy for the project, I spent a few $$ more and bought this one from Titan:
While projects like this are fun, I find I just don't have the time anymore.
I agree, but I did the opposite of what you linked and thats all I could find what you posted in your link, 4 years ago when I built this. It was a skid steer QA land plane not a three point tractor landplane/leveler, in any case 1st reply I got was a link to what I initially wanted and eventually built then reconfigured to work with a three point quick hitch and make it work for me.
/ SSQA plate to three point adapter? #13
Sorry, I posted the wrong link. This is the 3pt to ssqa adapter:
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
Hedge Posts (A65640)
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
