Rotary cutter preference
/ Rotary cutter preference #41
I have an everything attachments extreme 60 it’s built like a brick crapper and I use and abuse it and it had never let me down. I cut 3-4 inch brush with it
/ Rotary cutter preference #42
I’ll have to try that
All you need for annual rotary mower maintenance is a few wrenches, a vacuum powered oil evacuator, a laser thermometer and a cordless grease gun . Less than $250 for everything.
/ Rotary cutter preference #43
I’m still not comfortable with the slip clutch adjustment given the bell shield being in the way. Finger tight plus 3/4 turn? Yeah right. Maybe easy if all was clean shiny and new.
/ Rotary cutter preference #44
Personally, I will never again own a rotary cutter that uses sheer bolts!!
SR
Is there not a drain plug for the oil in the gearbox
/ Rotary cutter preference #46
Titan Implement (not Titan Attachments)
/ Rotary cutter preference #47
I have a Swisher Country Cut (44") 14.5HP Kawasaki Tow-Behind Rough Cut Trail Mower that I pull with my ATV. Not sure if it is considered a high end model but it does an admirable job cutting the thick scotch broom along side the railroad track berms Weighs around 450 pounds.
/ Rotary cutter preference #48
Didn’t know sheer pins were that bad
I think it really depends on your soil. Mine is heavy clay, limestone & lots of rocks. Sheer pins do what they are supposed to do and break before you damage something. Clutches may cost a bit more and they do accomplish the same goal of not allowing something more expensive to break, but in the end (for me anyway), the extra cost is worth it. As I said in the initial post, those pins have a tendency of breaking at the most inopportune time (at least on my property).
Do I push the limit of my implements? Yeah, probably - what do you mean that PHD isn't supposed to use a 24" auger, it fits, doesn't it? 😄😉😁
Haha
/ Rotary cutter preference #51
I see titan products everywhere never used one though
I've got several titans (palletforks.com), 1 yd 3p hyd dump bucket, light duty forks & add ones, e.g., augers, flail hammers, etc, they get the job done and are considerably less expensive. If you do go with them for things, stay away from the "Bucket mounted" items e.g., forks etc. I know there is a whole thread on these kinds of things, but for me, they've never worked very well and are a real waste of money!
I’ve look at their claw attachments for a skid steer good to know to avoid them
/ Rotary cutter preference #53
I have a 13 year old 6’ Bush Hog Squealer it is quite a bush hog. It has a two part rubber clutch and a shear pin.
When we first bought the farm the prior owner said there was a deep well some place on the farm, could not remember where. I found it, it went between the 1” thick forks on the root rake, running along the ground, right into the bush hog, a 2” galvanized with a 1 1/4” inside that cut both pipes half way, completely through side to side, shut the tractor off. Not a chip, dent or bend. Dug around the well, cut the double pipes off with a cordless saws all, buried it up.
On natural stuff, it cuts and smashes up to 3” or so stuff just like a bush hog should. It also mows grass.
I would add a 1 1/2” angle iron reinforcement around the outer edge. So you do not need a handy stump to straighten the edge out on.
Bush hogs are super heavy duty
/ Rotary cutter preference #56
You think a 32 hp ford could pull that
Their MX5 would be a better match for a Ford 1910. It isn't as heavy as a CX, which comes only as a 15 or 20 foot batwing. It is north of 800 pounds and a relatively stout cutter for a compact tractor though. I have an MX6 and apart from replacing a broken bolt on the mast, I have used it quite a bit and it's been a good cutter.
I’ll look into those
/ Rotary cutter preference #59
There was also an HX in the Deere lineup, which is between a MX and a CX (medium, heavy, commercial). There is an HX-6 which runs on 40HP. There is also the smaller Frontier RC lineup.
/ Rotary cutter preference #60
I’m not sure the OP could even run the HX-6 without a struggle and the MX would surely rattle bolts loose on his tractor.
If recommending Frontier you might as well tell him to get the exact same model built by the manufacture who makes them for Frontier (either Befco or Woods for their grooming and rotary mowers - depending on the year and model).
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
