Case 65A - Cab air conditioning
/ Case 65A - Cab air conditioning #1
DB Pilot
Gold Member
SW, New York
Case Farmall 65A, L3800 Kubota, BX2200 Kubota
Before I call my dealer I thought I might just run this question here and maybe someone has experienced this problem with their air conditioner. With summer coming on and air temperatures about 60. Running my 2020 Case 65A utility tractor at idle I'm getting cold air inside that glass cage. As soon as I throttle up to speed about 1500 RPM I lose the cool air. Back to idle and cool air again. I also noticed the radiator for the A/C also feels very warm when raising RPM's.
It has been suggested to me that it might be a sensor for the unit?
I have cleaned the Cab filters and made sure the radiators are dust/debris free.
/ Case 65A - Cab air conditioning #2
1st thing I'd recommend is installing a maual cutoff valve in a heater hose. If heater coolant control valve is leaking internally allowing hot coolant to cycle through heater core this is a cheap solution. My '91 JD 4255 has had manual valve installed in heater hose for many yrs
/ Case 65A - Cab air conditioning #3
WOG (water-oil-gas) full port ball valves are cheap, any box or hardware store will have them and you only need to shut off one side of the heater line (usually have 2 lines). I have never seen a flow control valve on any heater than didn't leak a bit, even new. Cut the hose in an accessible spot, install the valve and hose clamp it and you are golden. You'll probably need 2 short nipples as well to mate the valve to the hose. Off on the summer, on in the winter. Easy peasy.
/ Case 65A - Cab air conditioning #4
I have to ask, did you bother to clean the in cab evaporator when you cleaned the cabin filters? A dirty evap cab coil will not efficiently transfer cold refrigerant to the air flow. I clean both my evap and heater cores yearly when I clean the cabin filter.
/ Case 65A - Cab air conditioning #5
I would wager that you are a bit low on gas in the AC system, speed the compressor up and it pumps faster and
you get a low suction pressure shutdown of the compressor.
Also as has been mentioned cutting off all the heat helps in hot weather.
/ Case 65A - Cab air conditioning #6
That could be as well but I'd be adding refrigerant in the form of dry propane instead of R whatever. Propane is a much more efficient medium for heat transfer and is compatible with all refrigerants used today.
Thanks for the ideas. I was working with the Tractor this morning and noticed the in cab filter looked a little dirty, so that, and the Cab evaporator, which I have never looked at. Will let you know results.
/ Case 65A - Cab air conditioning #8
Or as it can be labeled R290, I've used my 20 pounders before.
I have had success with my air conditioner in the Case 65A. I read the manual and found that it clearly states "Not to wash the cabin filters". So I washed the filters, figuring what difference does it make if I need new filters. I washed off very fine carcinogenic particles with no damage to the filters. I am still not 100% sure but I have been getting cool air at operating speeds. The inside filter could not be washed. But the outside filters seem to be sturdier. The filters did not seem that dirty but again a fine particle powder came off and now I have good air in the cab.
/ Case 65A - Cab air conditioning #10
Wow, it is a major deal to clean the evaporator on my NH TN70D. You have to remove the headliner in the cab, remove the heater core/evaporator/fan enclosure then split the enclosure to get to the evaporator. Just finished cleaning the coils and reinstalling the enclosure. What a pain in the A$$. But the AC is back to work so it was worth it. Last job with it was mowing 35 acres. out door tem 107 deg. Cab was like a solar oven.
Tim
Air conditioner still giving out cold air after washing the two outside air filters.
/ Case 65A - Cab air conditioning #12
I don't use the outside air just want to leave
the 100+ air outside the cab. Only used my
a/c unit for about 7 months still works fine.
Years ago my a/c instructor said the you should
run you a/c for 15 to 20 minutes every month
weather you need it or not just to keep the seals
lubricated or don't do it and enjoy the leaks.
willy
I also heard about running the A/C during winter months to keep seals lubricated. I do that about twice a winter for autos and now the tractor. I cannot find the evap pan but there are two hoses over the rear tires that drip water after using the A/C. I expect that means that there is no build-up in the unit. I took the access panel off of the roof of the cab but found nothing to clean. Again all seems to be working as it should right now. I cannot explain why at start-up this spring I was getting hot air at operating RPM's.
/ Case 65A - Cab air conditioning #14
DB Pilot get a parts list for your tractor and you
should be able to find it and it will be easy to
remove or repair and you can see how every
thing goes together.
willy
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
(4) HD Pipe Gates (A66408)
(4) HD Pipe Gates...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
New Holland 273 Square Baler (A66408)
New Holland 273...
