New tractor Grease Question
/ New tractor Grease Question #1
kittyhawk
Buffalo, Texas
JD X300 X350 Lawn Tractors. BRANSON 3620H
Good morning everyone, I took delivery of my new Branson 3620H last weekend. I already have a grease gun and been using TSC Traveller Premium HD Lithium NLGI#2 grease on my lawn equipment and it seems to be working good for for my mower's and was checking to see what the consciences of this particular grease are. My owners manual specifies NLGI#2 grease, so I'm thinking this will work and give me the protection I need or should I move to the TSC Traveller Extreme-Duty Moly.
Thanks in advance for your thoughts and input.
Dave
/ New tractor Grease Question #3
Plain lithium grease for the tractor proper.
Lithium grease fortified with Molybdenum for the FEL, every ten hours of FEL use.
TSC Traveller Extreme-Duty Moly. I buy TSC's moly grease occasionally.
Plain lithium grease applied regularly is better than the most expensive grease applied infrequently.
thanks guys.
/ New tractor Grease Question #5
I use Schaeffer's 219 on almost everything I own. Been very happy with it. I have a few items that take special grease that cost 125 dollars a tube (ouch) but otherwise the 219 goes everywhere.
/ New tractor Grease Question #9
I use polyurea on everything: mower, loader, backhoe, etc.
I’ve got other brands, too, but my go-to is the John Deere, since I have a JD dealer local. This stuff used to be around $4 a tube. The last case (ten tubes) I bought was $55, after tax. Now, I see it’s even higher.
/ New tractor Grease Question #10
Only problem I have with polyurea is that it is incompatible with so many other greases. So it could lead to problems if you are not careful
/ New tractor Grease Question #11
You’re looking at the wrong polyurea. Look one line lower. Shear stable (Kubota and John Deere are) actually is comparable with more different grease than anything else. Another reason I use them.
/ New tractor Grease Question #12
I use 2, pretty in pink for bearings and u joints and sticky black bear shate for the bush and pins. We use the Travelers and have done a little comparing and the bear shate stays in a lot longer than the cheap common does. Doesnt seem to plug up.
/ New tractor Grease Question #13
You're right, I was wrong. This is the shear stable polyurea.
I'm gonna leave the chart I think it's still helpful.
/ New tractor Grease Question #14
The chart is helpful, thanks!
/ New tractor Grease Question #15
Got my girl a tractor 🚜 and she bought me this grease set up
Go big or go home is her motto .
Texas Refinery Corp Paragon 3000. It’s the only grease my 2000 New Holland has ever seen .
/ New tractor Grease Question #16
I just started looking myself and seems like the LI400 might be the quick and easy way to go for all tractor applications. It's more expensive but then again, the time wasted looking for a cheaper alternative or making sure everyone that might be greasing the tractor uses the correct grease for each application doesn't seem worth it. At least not for new tractor owners. Thoughts?
/ New tractor Grease Question #17
Ah SO:
Jeff speaks wisdom, Respect is garnered!
/ New tractor Grease Question #18
Dave
Grease is grease. Water works fine, too, as a "grease". Only trouble is it evaporates.
Same way with wax. Works great as a lube oil, but it freezes up even at ambient temperatures.
Doubt you need any kind of fancy grease. Just grease every 50 hours.
/ New tractor Grease Question #20
I use HD marine grease on every thing from my Jeep, Tractor, Lawn tractor, Boat, Trailers & Tools.
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2015 Ford Taurus AWD Sedan (A61569)
2015 Ford Taurus...
Wacker Neuson HI400 Heater (A61166)
Wacker Neuson...
2010 Volkswagen GTI Hatchback (A61569)
2010 Volkswagen...
John Deere 612 2-Bottom Plow (A63116)
John Deere 612...
