Another Restoration Project
/ Another Restoration Project
I have been working on framing the front of the hood to match the radiator support on the machine. I milled grooves to press rods into the flat metal to form the grill. This is also like the existing grill. Then I welded the joints from the backside. Kinda snowy outside one day so it was a good day for the cutting and millwork.
/ Another Restoration Project #82
I think the best part about this thread is your attention to detail!!! I really enjoy seeing the steps you take go through to create each part of this.
/ Another Restoration Project #83
This is a great thread. I envey the fortitude that you've spent not only restoring your project but also keeping us entertained. Can't wait to see the final results......
/ Another Restoration Project #84
Hey Aircommuter, any updates? I'm having with drawl symptoms from lack of updates to one of what i consider the most interesting restoration projects to ever appear on this site. Without a fix soon I might just run away from home......
Sorry about the discomfort. Also thanks to everyone for the compliments. I have been criticized for years because I make a production out things, but I have to satisfy myself. As you all know by now I am a little crazy or something.
I have been doing some little things that take as long as the the big things.
I fabricated a locking radiator access door and adjusted the funny looking teardrop hole for the air cleaner pipe, then I made a removable half circle enclosure around the muffler, all on the hood. Why the teardrop hole? It is part of making my hood hinged. I need to remove the air filter pipe after the pre cleaner is removed. That little area allows me to get a ratchet in there to loosen the clamp.
Next I got a couple stainless hinges and bolted them to the bracket where the hood was intended to be bolted. I had to drill and tap the 2 holes on the inner portion of the hinges. That is the reason for the block of wood back there so I wouldn’t drill the radiator too.
Now I have to do some calculations for size and strength of the gas springs. Oh yes I also put the final bolts in the support bracket. I couldn’t handle the ones with screwdriver slots and painted heads. Also I put some pieces of conveyor belt to seal the air gap around the shroud. The original ones weren’t available and weren’t as strong.
Now for the excuses. I had to replace my 3 year old cooktop because it failed and the parts were more than a new one, so I went with a different brand that is my favorite. But it couldn’t be used as a drop in so I had to grind the granite to fit as a flush mount. Pictures show. No:2 excuse preparing firewood for next season. I had some 80’ oaks that were so close to others that I couldn’t fall them and my lift only goes to 40’, so I hired my friend with and 83’ lift and cut them from the top in 25’ sections.
/ Another Restoration Project #86
Thanks aircommuter......... I understand the projects taking time. I've been remodeling my master bath for several months now. Only thing left now is to cover the double sink vanity with porcelain tile. Trying the do it with 24" x 48" tiles so there will be only one thin grout line in the middle. These freaking things are heavy and with me a couple months away from turning 75 it's hard getting them upstairs to the master bath. Already cracked two cutting the holes in them for the sinks. Take care and can't wait to see the final photos.
I am planning on doing a final video on YouTube, running and operating. It’s warmed up this week so I plan on painting the hood, side panels and miscellaneous pieces.
I might do a preliminary engine running and operating the loader up and down at least, YouTube . Can’t do the clam yet as I have to make some cylinder pins.
/ Another Restoration Project #88
I've never seen a lift with tracks before. I've rented 40 foot lifts and they terrify me, I don't think that I would want to go any higher!!!!
The tracks can pull in to make the unit 36” wide and can offset vertically for traversing across slopes, and they are white rubber. It weighs 8600, powered by a Kubota Diesel. Also has wireless remote when needed. They keep that thing busy everyday. They charge $300 per hour with two guys and two chain saws. A lot gets done in a couple hours.
/ Another Restoration Project #90
I've been watching these things for a few years. Our in-laws needed tree work in a tight area. They drove it through the gate in the fence. Really impressive piece of machinery. Not inexpensive, though. Have to keep it working to make money.
/ Another Restoration Project #91
Less than 36" wide! It fits through a 36" gate! Very cool. (y) (y)
/ Another Restoration Project #92
Thank you for putting this entire series together, & looking forward to that final video.
rScotty
Here is a small update. I have been working on the firewood and burning the tree trimmings.
I finished the hood including the radiator access and primed and painted all the parts I made so far. Not a hand rubbed finish exactly but nice enough for the tractor. I made the hinge mounting holes square for adjustment and got some 12mm prevailing torque flanged nuts to use on there.
/ Another Restoration Project #94
Is there a website to buy old Massy construction parts from? What other construction equipment did they make?
I haven’t actually found a dedicated site. Various parts show up at some sites like Steiners, Complete Tractor, Jenn Sales, Broken Tractor and many more.
They made loader backhoes, loader scraper box units that were very popular. Several sizes of the crawler loaders and dozers which were built by Landini of Italy which they owned and the parent company of MF today still owns.
Was yours built by Landini?
Yes, it has a metal plate on the back that says made in Italy. So it is like many cars and trucks from the seventies. Hybrid metric, SAE. Engine is British so that is SAE, everything else is Metric including hydraulics until the end of the 2 steel tubes going to the 4in1 bucket then it is JIC as the Drott bucket is made in Wisconsin owned by Case. Once you are use to it it’s ok.
I have seen a lot of videos on YouTube of the dozers working, seem like India, maybe Mexico or South America. I haven’t seen another matching loader ripper combo like mine. That was what really appealed to me as that was the way I ordered my tractors.
Here is my latest update, I put on the side covers after I fixed a fuel leak on the injection pump. I also did a second valve adjustment now that things are seated in a bit. I made a couple more missing covers and I included a couple pictures to show how I cheat on making bends in 10 gauge when the brake is not nearby. I finished the locking radiator cover too. Next is the floor plate, the last missing piece.
/ Another Restoration Project #99
What's the tank behind the seat with the sight glass? I really like being able to see how much fluid is in a tank by looking at a tube.
The side with the sight tube is Diesel, it’s a split tank with hydraulic on the other side. Sight tube on that one faces forward next to the seat.
2011 Altec CFD-1217 S/A Towable Brush Chipper (A61567)
2011 Altec...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
Caterpillar 259D3 (A62180)
Caterpillar 259D3...
1998 FORD F-150 SINGLE CAB TRUCK (A62130)
1998 FORD F-150...
2022 KOMATSU PC130-7 EXCAVATOR (A62129)
2022 KOMATSU...
