Expandable tracks stuck in narrow position
/ Expandable tracks stuck in narrow position #1
KubotaEv
1992 Kubota l2650
Hello everyone, I am new to excavators and just picked up an old sumitomo (IHI) uj18 mini excavator. As the title suggests this machine has widening tracks. they were working for a little while, then i sucked them in, and one of the tracks got stuck in the narrow position. I am really just wondering how this system works. from what I know, it is a single hydraulic cylinder that operates boths sides. and the tracks are on a sort of "rail" system (small tube inside of big tube). I have cleaned it as best i can with no luck. So as it sits now, one track is free moving and the other is stuck all the way in. I have tried to pull it with my tractor while operating the hydraulics with no luck. Should I just pull it harder??
thanks everyone.
/ Expandable tracks stuck in narrow position #2
if you rotate the bucket to the side and lift the track off the ground does it try to move?
/ Expandable tracks stuck in narrow position #3
You’re probably supposed to lift the tracks off the ground before sliding them. Are you doing that?
it does not move. I always lift the excavator off the ground before trying to retract or expand the tracks.
Yes I always lift the machine up when i try to expand/retract them
/ Expandable tracks stuck in narrow position #6
We use to have a bobcat that did the same thing . Sometimes we' get it to work by trying the controls to work in different combos. Slew ,curl tracks in Etc. But finally it had to go in to shop developed a bad leak . They said it was a solunoid that stop the track from moving .
The tracks moved in and out with full weight on the machine in deep mud or on dry pavement. Bobcat tried to stop that leak 6 times . Cost a small fortune. Resigned it to the machine just marks it territory like a dog only with hydro fluid . My boss use to call it dust control.🍻
I found the problem. The stop on the track was broken causing the track to over extend. So the cylinder was pushing out as far as it could go. I welded the stop back on and all is well.
/ Expandable tracks stuck in narrow position #8
Nice when you can fix them yourself . (y) Usually only takes a little investigating and desire to get r done.🍻
/ Expandable tracks stuck in narrow position #9
great, its nice when its a fix one can do themselves instead of a visit to dealer, seems nothing is less than 1000 dollars these days
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
Trek (A65640)
Trek (A65640)
(3) JOHN DEERE DRY FERTILIZER DISTRIBUTORS (A64278)
(3) JOHN DEERE DRY...
