Using Hole Digger In Hard Red Clay
/ Using Hole Digger In Hard Red Clay #42
Safety should always be used around equiptment as not paying attention to spinning rods, moving parts will RIP body parts OFF quickly. I have seen this happen many times to children and adults purely by carelessness. AS a child and a adult myself. SAFETY FIRST!!
There are options, and certainly don't necessarily take my word on a 5' fence. When I was reading up on deer fence years ago 7' was the min recommended height. If they get popped on a shorter electric fence I suspect they would avoid the area entirely.
My neighbor uses motion activated sprinklers to keep deer from passing through his garden area with good results.
I was just kidding. I already bought the fence and posts so the fence will be 5'. If the deer try to jump it then I will come up with additional countermeasures.
I agree! My neighbor was seriously injured last year with a hay bale spear going through his leg after it fell off the quick attach, which was not working properly. The sheriff that showed up said he see's injuries and deaths from farm equipment frequently.
/ Using Hole Digger In Hard Red Clay #46
Once had a neighbor with an 8' chain link fence around a small pond where he kept exotic water birds - the fence to keep foxes & coyotes out. I have actually seen, more than once, a deer standing next to the fence do a flat-footed jump right over that fence. Not a running jump, standing just a couple feet from it.
I tried the 3' set-back 2nd fence method on my electric fence and it kept a lot of deer out but not all. I run a 5' high electric fence with 10 runs of steel wire spaced pretty close for small critters, every other one hot and the others ground to catch them hopping thru. Then I set a single wire at the top of 8' posts set back 3' inside from the main fence. Some deer wouldn't jump it but always had 1 or 2 that figured it out and made the jump anyway and MOST the time made it. The other times they tore the **** out of my fence when they tangled-up in it so I took out the setback fence this year and will just maintain my main fence. I've spent WAY too much money on fencing and WAY too much time on it too. My perimeter is just shy of 800'. At least the main fence will keep the coons out of my corn and MOST squirrels out of my peach trees.
/ Using Hole Digger In Hard Red Clay #47
What the others have said. In addition, in my soil, which is hard clay cementing together round river bank gravel, I will often start holes with my largest masonry bit. I can also work in cycles, drilling a hole further until I can't penetrate any more, then filling it with water and letting it soak. It's a good idea to bring a very big plumber's wrench with you so if you screw it into the ground (for me this depends on tree roots) you can turn it the other way by hand. Doing that is a pain but you don't have to make many turns to free it. Augers must be something like 0.1 threads per inch! Finally, yeah, safety. You might google pro shaft accidents. There seem to be many more of those than accidents involving getting snagged by an auger, and the auger isn't the only spinning hazard. There are scary pictures out there, and at least one video. Operators who are not a bit scared are more likely to wind up getting wound up.
/ Using Hole Digger In Hard Red Clay #48
I use Grade 5 bolts for sheer pins. I don't know what a Grade 2 bolt is. I never heard of that before.
I have a 9 inch auger and a 12 inch auger. I use the 12 inch for everything. When installing fence posts, it's almost impossible to keep the holes straight for every posts. With a 12 inch hole, you will still need to have a clam shell digger to adjust the hole on one of the sides.
The 9 inch just buries itself in the ground. My 37 hp tractor doesn't have enough up lift to stop the auger from drilling down to quickly. I haven't used it in years and I can't think of any reason to keep it, other then it's paid for and not in the way of anything.
I use mixed concrete on my corner and gate posts. Mixing it allows the concrete to get as strong as possible. For line posts, I usually back fill the clay that came out of the hole and pack it with the end of the handle on the shovel. If I'm going a long distance, I'll fill the hole with dry concrete and pour in a little water.
Most important on every post is to create a lip around the bottom of the post so water drains away from it. Every post that rots, will start rotting away at ground level. Water settles there and remains wet for long periods of time. Six inches down, and the post is still solid. Force the water to go away from the post and it will last a very long time.
/ Using Hole Digger In Hard Red Clay #49
Grade 2 bolts are the least expensive ones sold. They are usually sold from bins in small hardware stores like ACE Hardware. Big box stores may sell them in packs, I don't know though. Grade 2 fasteners are pretty soft and much weaker than Grade 5 fasteners.
Eric
Eric
I was looking for grade 2 but only saw grade 5 and 8 clearly marked. Are grade 2 bolts typically not labeled with a grade?
/ Using Hole Digger In Hard Red Clay #51
I've switched, for the most part, from digging holes, planting the post and filling the hole around the post to just pounding steel posts directly in the ground. I use a Mansaver and a smallish compressor. The steel posts will outlast me.
/ Using Hole Digger In Hard Red Clay #52
Yeah, grade 2 bolts are typically not marked. You can tell they are grade 2 because they will be the cheapest.
Eric
/ Using Hole Digger In Hard Red Clay #53
That is correct.... grade 2 is usually unmarked.
Thanks again for all the help! I completed most of the hole digging yesterday and started setting posts.
/ Using Hole Digger In Hard Red Clay #55
Eric
Thanks. I never knew that they where called Grade 2. I just assumed that they didn't have a Grade to them.
I also don't really know what Grade means, other then Grade 5 is stronger then the bolts with smooth heads, and used for sheer pins, and that Grade 8 is the strongest that I can buy at the store, but they are too strong to use for sheer pins.
/ Using Hole Digger In Hard Red Clay #56
Eddie
Maybe the chart below will help you understand differences in bolt grades.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
