Using Hole Digger In Hard Red Clay
   / Using Hole Digger In Hard Red Clay #21
A word about shear pins- They are there for a reason. If you replace them with something that doesn't shear under excessive load, you run the risk of damaging the gear box. When I first started using an auger, I broke shear pins right and left. Then I learned. If you feel that the auger is going to bind against rocks, tree roots, or just hard clay, pull it out. I guess you have to shear a few pins before you learn. I haven't sheared a pin in over 20 years. If the auger is into rocks or tree roots, you will have to get them out by hand before you can continue. If it is hard clay, you need to soften it up with a digging bar and/or manual PHD. If this is too slow going, use water as advised by others. I've never gotten mine stuck in a hole. I guess knowing when to pull it out has served me well and it just takes practice to recognize the signs. Take it slow at first as you learn and build confidence.
the ground around here gets really hard during the summer. My PHD will usually dig it but its slow going and if I'm not careful the hydraulic downforce on the PHD will pick up the back of the tractor...which is a bit unnerving.
pull the auger out frequently. The first time I used my PHD, I got it stuck down in the hole, and it took me a while to get it back out.
a
   / Using Hole Digger In Hard Red Clay #22
Make sure to have a few sheer pins with you just in case....
   / Using Hole Digger In Hard Red Clay #23
I always keep the RPMs up and go down slowly. The Inertia from a faster spinning auger helps when you hit obstructions. Lots of Shear Pins.............
   / Using Hole Digger In Hard Red Clay #24
My wife watches from a respectable distance to ensure the PHD is going in vertically. We are always very careful to ensure that livestock and visitors are nowhere nearby. (We also don't want visitors when cleaning sheathes on our geldings.) We have yet to drill us some postholes to build us a rack for hanging the PHD when it's not in use, so every time we use it we have to fight to put it onto the 3-point and to remove it.
   / Using Hole Digger In Hard Red Clay #25
shortly after a neighbor bought his house he was drilling holes for fence posts, and drilled through the irrigation district's underground pipe. He called them, they came right out and fixed it. A month or so later a bill for the fix arrived in the mail.
He turned around and gave it to the title company....they missed the irrigation district's easement on his property, and the title company ended up paying the bill. Though really he should have called the call-before-you-dig number.
   / Using Hole Digger In Hard Red Clay #26
Since you are new at this I think safety oughta be mentioned. When the tractor is running nobody should be close to the post hole digger. If drilling with a partner they can use the long handle provided with the digger to position it. Do not allow anyone to get any closer than the handle will allow while the tractor is running. If the auger gets stuck and your PTO doesn't reverse then the auger will need to be unscrewed manually. You can use a pipe wrench on the auger itself to unscrew it. The tractor must not be running when you do this. I know, it might seem to be a pain to shut off and then re-start the tractor engine. But it is necessary to do this to avoid getting seriously injured or killed. Also be aware that if could be any wire buried in the area, like fencing wire for example, the auger could catch it and if a helper is nearby the wire could catch them also and they could be dragged into the auger. I love my post hole digger but it scares me so I make sure nobody is close when I am using it and I shut off my tractor before getting off of the tractor.
Eric
   / Using Hole Digger In Hard Red Clay #27
Here in East Texas, I have red clay and iron ore. It can be mixed, or just solid clay. The clay is like a pie crust, with the top layer being super hard. This can be 4 to ten inches thick, but normally, it's 4 to 6 inches thick. Once you get through that top layer, the ground holds moisture and it's easy digging. I have a full sized backhoe, and it can struggle to break through that top layer.
I started out with a cheap auger that was pretty much worthless. I bought a Speeco with replaceable teeth and tip that was night and day better, but it still struggled. I wore out the teeth fairly quickly using it and then one day, I couldn't find any more teeth for it at the store.
I needed to finish drilling holes and I was a bit desperate, so I went to Tractor Supply and bought a Country Line auger with replaceable teeth and tip. I had no idea that an auger could drill so fast!!! It goes right through the hardest red clay without effort. My biggest challenge is slowing it down so I don't burry it. This has become a real issue for me, it digs too fast!!!!!
Looking at the Speeco and the Country Line augers next to each other, they looks very similar, but performance is totally different.
   / Using Hole Digger In Hard Red Clay #28
My understanding is clay can be rock hard if dry and packed, then powdery, or the stickiest of mud when wet. Sometimes all three depending on depth. Knowing what you’re dealing with and waiting for more ideal conditions can be everything. I know this is true with harrowing and planting on clay.
As others say: I don’t use 540 rpm, but probably around 200. Pull the auger back out frequently to spin off dirt. Corkscrewing auger into ground to where the 3 point hitch isn’t strong enough to raise it back up is a show stopper. Remember, there’s no reverse on a non-hydraulic auger.
Keep people away from spinning auger. Accidents are grisly. The only time people should be bent like a pretzel is… well, if they are enjoying it
Here is another question, what size auger for a 5" post?
I'm installing a fence around my new garden. I live in a rural area and I want to keep deer and other creatures from eating my vegetables. The plan was to use 5" posts for the corners and T-posts in between with one more 5" post for the gate. The posts are 8' and the fence is 5' so I would put the posts in 3' and use a bag of cement for each post.
I'm heading to Tractor Supply to see if they have shear pins for the post hole digger. I'll check out their augers.
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
HYD AUGER W/ 16" BIT (A52708)
HYD AUGER W/ 16"...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
2014 HYUNDAI Veloster (A56859)
2014 HYUNDAI...
