beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,680
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Stihl, and happy!who owns owns one ? Brand ?
I have two, a Roybi 40 volt 14" that I use for liming trees in the woods and cutting slabs at my sawmill. The other is a Kobalt 80 volt, 18" saw that I use for felling larger trees and cutting into desired lengths. I have three gas chainsaws that have been gathering dust on the shelf in my shop ever since I bought the Kobalt almost 4 years ago. I've had the Roybi about 13 months and wouldn't part with it. Both saws are still using the original batteries that came with them and both are working like new.who owns owns one ? Brand ?
I would not try a blade in a battery trimmer. I don't think they have enough HP.Does anyone use a brush cutter blade in their battery string trimmers? Is battery a good way to go with this setup (for more heavy duty brush and weed clearing)?
Plus big strings heads take more power the steel blades.I would not try a blade in a battery trimmer. I don't think they have enough HP.
My FS-110 is just big enough to use an 8" blade.
My larger brushcutter takes 10" blades.
I would never even try it or the thicker wire. I use .095 though in the Milwaukee.
It runs fine, but the battery does drain faster.
I tried my buddies Oregon battery chainsaw (model?) and it keep stopping when the chain got slightly bound up. Yes it was fully charged. It didn't become my favorite saw.The Ryobi 14 inch 40v irked me yesterday because it kept shutting down on heavy cutting. Wife's Stihl MSA-120 does not do this.
I've no complaints about my EGO chainsaw or pole sawI am considering getting an Ego chain saw as I am in that brand for a string trimmer and leaf blower.
Project Farm youtube channel has a comparison of battery chain saws. You should check that out.
Recently bought the DeWalt 20V because I have numerous tools for this line. No complaints so far, IF you only expect to do "light work". It will easily cut what I need to do with it. Have cut a 5" tree / limb without issues. I have not cut enough to run the battery down. So I cannot comment on how long it might cut. But, I also have a Stihl gas for more serious jobs.who owns owns one ? Brand ?
If it cut through that block it is sitting on, then it did pretty well. Or is that what took 18 months?I have had this Husky 120i for about 18 months .
Has it’s uses , but they aren’t many .
Excellent for almost all small to midsized jobs, have no complaints. But make sure you get the 40V model...I've thinking about buying a cheap one (Ryobi) I have a 15% off coupon at HD.
A friend has one and he really likes it. Says it has plenty of power and he can put it down, do other things and not have to pull the start rope to get the engine going, Just push the button and start cutting.
I already own 3 gasoline powered saws, and just thought this battery saw is something that would be handy to use around the farm
Strange, my 40 volt Greenworks I've never thrown the chain and used it a LOT over the years. I'd be sure the bar and chain are OK, rolling it around by hand. Easy to adjust and tighten by hand...no tools needed.Has anyone experienced their battery chainsaw throwing the chain? My green works 40 v has thrown the chain more often then my gas saw. Had it tightened and lubed. Power last long enough and like the idea of not having to screw around with hard starting and fuel issues. Thanks
Yes and that's why I mentioned having to constantly check the bar/chain tension on my Makita with the 'handle' bar 'lock' (as opposed to the two nut bar lock on my 2-stroke).Has anyone experienced their battery chainsaw throwing the chain? My green works 40 v has thrown the chain more often then my gas saw. Had it tightened and lubed. Power last long enough and like the idea of not having to screw around with hard starting and fuel issues. Thanks
