Alternative 3rd function?
/ Alternative 3rd function? #41
Would something like this wolverine valve be suited to use as a manual diverter and also function as a relief valve? The product description says it has an adjustable relief valve?
Then I would just need hoses, adapter fittings and a mounting bracket. Right?
And something else now puzzles me. If I put a check valve in the system, does that prevent it from retracting the grapple hyd cylinder or is the check valve somehow pressure dependent so that it limits excessive pressure but still allows normal operation of the cylinder?
Or should some relief valve be added?
/ Alternative 3rd function? #42
Yes it would work.
You will need a Pressure in hose, a power beyond hose to carry on through the system, a return to tank hose plus your two lines for your grapple. Also be aware that when using that valve your other functions will not function untill that loop is pressurized to a greater valve then another function.
I would not install a check valve I have read of the possibility of applied stresses creating an excessive pressure condition. All a check valve would do if that happens is restrict the excess pressure to the system prior to the check.
I run my FEL remotes off a rear SCV and it works, but just as your idea will require letting go of any other hydraulic function to activate the new one so does mine.
Yes, I saved a bit of money and it works I do find myself reaching across my body to use both hands on hydraulic levers at times.
If doing it again I would use a electric diverter valve and wire the switch into the loader joystick,
I may end up doing so one of these days when I get "a round to it".
Not much more money and less hose footage and fittings.
You can add relief valves but they would need to be plumbed into a tank return line
/ Alternative 3rd function? #43
I used the valve Lou displayed to run two cylinders off one rear remote on my rear blade. For my uses a toggle switch mounted near the valve levers works fine. For Grapple use I'd want a push button on the joystick.
/ Alternative 3rd function? #44
As do I and I even had another one to add to the blade to get 3 uses out of one remote
Those devices have many uses I plumbed one into a JD forage harvester last year.
It was built for use with JD's closed center system and we had to get it to function with Pressure Compensated Closed Center which
does not lit to play with closed center applications.
We plumbed it so that when not energized the flow circulated right trough the NO ports and when energized it provided hydraulics to the closed center valve body ( an electrically controlled 5 section body header lift/ that controlled all the functions of the forage harvester, drive clutch fwd/N/rev, header lift/lower, chute rotation and defector position, and machine position in or out compared to tractor centerline) ended up working quite well.
Mother Deere had a component to perform the job for $600 plus a few other bits and pieces but didn't want to divulge the info on what it was or how it worked.
We found a wire in the Deere harness that was hot upon activation of any of the controller switchs and used it to control our electric valve,
so the diverter valve and 3 short hoses and ready to go to work. It did take considerable researching and probbing to figure it out, but a piece of cake after that.
/ Alternative 3rd function? #45
Lou, your method(s) are EXACTLY what I have plans and parts for on my 580B - now if LIFE would just leave me alone for awhile 😫
I have a 6' grapple to control, and plans for an articulated brush cutter, QA for loader, several already built attachments to mod for direct hookup, etc (dilusions of grandeur anyone) - already have dual diverters (they'll run off bucket curl), control handle, etc, plus already added motor control for the hydraulic motor, supplied from an adjustable flow splitter -
This
is the handle I bought, mine's configured for up to 3 separate diverters (I'll be using two, same as you described exactly) - those aren't cheap, but ergonomics are as perfect for one-handing as I could find.
Now, if that elusive "tuit" would break a leg so I could catch up... Steve
/ Alternative 3rd function? #46
The barn where I plan to store the L2501 has a lot of moisture. I have some concerns that the electric solenoid controls are going to eventually stick. When I asked Summit about the availability of replacement solenoids, all they said was that they stock them for warranty service. This is one of the reasons why I"m leaning towards a manually operated valve.
/ Alternative 3rd function? #47
I had a diverter for my old B2620 and on the BH for the thumb, both stayed out in the weather for years while building a shop and have been service for over 10years with no problem.
The coil is the only external part, the action of the solenoid is internal so its not like a starter solenoid where moisture can cause it to jamb up.
Sent from my SM-G715U1 using TractorByNet mobile app
/ Alternative 3rd function? #48
I would not think that would be that big of an issue, 100's (++) of tractors sit outside year round & have electric solenoid valves on them... (unfortunately ours has the past 2yrs)... I mean it might happen but I'll risk it for the convenience, the ergonomics, & production time...
I really would want to ever loss the convenience of the controls right in the joystick over a separately operated valve, it is amazing how much we use that function when using a grapple & the tree / post puller... I could imagine having to move my hand off the loader joystick every time I need to operate the 3rd function.
/ Alternative 3rd function? #49
Folks, yes the solenoid valves are on/off affairs, kind of. Your pump move a maiximum of so many gpm. A given size cylinder takes a set amount of fluid to extend fully, and a certain amount of fluid on the other side of hte piston to close it completely. You can add restrictions in the hoses after the solenoid valve to control the volumetric flow rate. There are nifty valves which are controlled by a needle valve going one way, and open the other direction. By putting one on. Each hydraulic line serving a cylinder you can control how fast it moves. I put them on the down and dump lines for my FEL. I have a small 23-hp tractor. The Valve the factory installed is an 11-gpm valve, with a 5-gpm pump. The loader was very manageable when you were raising or curling. It moved a bit too rapidly going down and dumping. I put the valves in and now it drops at the same rate it raises. Much more controllable, and enjoyable to run.
You can control the reaction rate on the solenoid controlled valve with the same inline valves. If just adds a bit of cost to the installation. If a fella was good at hydraulics calculations, you could probably come up with some kind of fixed orifice to add to one of the fittings
/ Alternative 3rd function? #50
I have a question about the concerns of a grapple producing an alarming amount of back pressure on the hydraulic system. How is this different than the loader cylinders or bucket curl cylinders while digging, pushing or grading? Do each of those lines have check valves? I also don't understand why you would be pushing with the lid of a grapple. Respect the tool for what it is and it will last a long time.
/ Alternative 3rd function? #51
One of the problems that the Messick's video raises is grabbing a long piece of unbalanced material (tree trunk) in the grapple which then acts as a giant lever prying against the grapple cylinder. I'd venture a guess that too much stress can also be placed on tractor loader cylinders from trying to dig, push or grade with the front bucket instead of using the rear 3 point hitch. The loader arms are not in a straight line to the tractor frame like a dozer.
/ Alternative 3rd function? #52
A Grapple puts a tremendous amount of stress on the FEL hydraulics that mostly isn't possible with just a bucket. This added stress makes it very easy to overload the tractor hydraulics.
/ Alternative 3rd function? #53
How does it put any more stress than a bucket or forks on the hydraulics? I'm trying to rap my head around your line of thinking.
/ Alternative 3rd function? #54
Things like logs have high polar moments and inertia. You pick them up, and all the spools in the hydraulic valves are closed when you transport.
Every bump, turn, or change in speed, and it pushes against the grapple, lift arm and bucket cylinders. That push is translated into a hydraulic pressure surging in the closed hydraulics On your FEL and grapple.
/ Alternative 3rd function? #55
Another possible way to mitigate these spike with an accumulator.
Guys moving lots of hay and are trying to go fast are using them and i makes a difference when stacking lots in a year my hay supplier does about 15k bales a year and he’s a small operation.
/ Alternative 3rd function? #56
I'm here learning about hydraulics, TBC ... but I think this one makes sense:
with the other functions (FEL, etc), the load is "on" the action you're performing. As you lift, you are pushing against the load. Too high, and the OP valve will trigger, and the movement that's increasing the load stops.
now consider a grapple: you clamp with the tree on the ground. Cylinders are clamping with ~rated PSI. Now you LIFT. grapple cylinders are still clamped, but the load they are experiencing can increase dramatically as the tree exerts leverage. The FEL itself may be well within rated lift, and the OP valve never trips. But the grapple, with it's fluid path shut, sees an unknown amount of higher pressure.
/ Alternative 3rd function? #57
While the fact that the grapple runs the risk of unexpectedly high pressures makes sense as in the discussion above, and I can see how a check valve would at least isolate more of the system, I have two questions:
  1. the pressure still [could] rise unacceptably in the grapple cyclinders & fittings. The check valve might even make this (slightly) worse do the smaller total elasticity in the (now tiny) isolated section of the system so exposed. Shouldn't this be an "over pressure" valve application that would allow the cylinder to retract when the pressure passes [some] threshold?
  2. how does a check valve work in normal operation - fluid has to flow both ways ...
    1. this is actually how I found this thread; struggling to find a good answer to this. A check valve is a one-way valve. But the flow needs to reverse when the implement opens. I'm missing something ....
/ Alternative 3rd function? #58
When the engineers design the hydraulic system with a loader in mind, they've pretty well got the load and pressure confined to whatever kind of material fits in the bucket they spec for that tractor and loader. They can estimate that the loader is going to be lifting a certain number of pounds of material based on the cubic foot size of the bucket.
With a grapple, there are guys on youtube grabbing pretty good sized tree trunks both in weight and length. The leverage forces that the grapple is resisting can be much greater than material sitting in a bucket. Picking up a 15'-25' log, especially if it is off center and acting as a lever, exerts different force than scooping up a 5' bucket of gravel.
/ Alternative 3rd function? #59
The device to handle and disipate teh surge would be an accumulator, with restricted office to limit hours fast fluid could go in and out. Essentially a slightly larger version of a hammer arrestor in plumbing.
/ Alternative 3rd function? #60
Thanks for the name. Yes, that function sounds like it applies to the concern here - although in a ~month of reading about this I don't believe I've seen anyone else refer to it ... at a minimum it's highly uncommon on everyday TLB/grapple/etc (?)
@davedj1, @2manyrocks, @LouNY discuss "check valves" on several pages of this thread - and in the (few) other threads discussing this same overpressure risk, the phrase seems to be used the same way. I'm trying to understand what folks are proposing; those uses do not seem to be a reference to an "accumulator" type device.
Is this some sort of overpressure device that, rather than shunting the fluid to tank, just "short circuits" the cylinder, allowing it to open/close as necessary to avoid damage? As I am picturing it, if say the normal hydraulic OP valve is set for 2000psi, this "grapple saver" would be substantially higher, say 3000psi. Thus it would only ever open when the valve to the grapple circuit is closed and the grapple is isolated from the rest of the system.
Maybe I should start a new thread about this, don't want to completely hijack this one :)
EDIT: thread created check valves, accumulators, overpressure; oh my
YALE FORKLIFT (A63291)
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
