Alternative 3rd function?
/ Alternative 3rd function? #101
~45lbs is simply atmospheric pressure, applied to a to a ~3inch diameter circle. Yes, that stays ~constant. We *are* starting to get to spherical cows, and TBC that's not my area :)
How far does it have to move? That depends entirely on the assumptions we have to apply to simplify the problem enough to post these ~qualitative answers :)
> Pressure = APysicsConstant * Temperature_Kelvin / Volume
So if you double the volume, you half the pressure. This is "ideal gas law" and it's very accurate estimate for "everyday" temps & pressures.
So the 45lbs exists no matter what on the end we're assuming is fluid "free" to flow in and out (eg NOT up against a valve like LD1 points out). And lets say the cylinder is bottomed-out blind, with "negligible" fluid on the blind end. That fluid on the blind end is also starting atmosphere (if the rod is motionless and our above assumption hold).
So you start to pull. The blind end cavitates. You assumed it has "negligible" contents, so we moved from "zero" volume to "more than zero" - an infinite increase. The force would basically jump up immediately to that ~45psi.
Ignoring static & dynamic friction, and lots of other stuff. But yes, with respect to the pressures acting on the 3sqin of piston, it's that simple.
So, considering that it takes only 45 lbs of force to "pull" the 2" diameter cylinder, what is to keep one from pulling the cylinder full stroke or the rod clear out of the cylinder in the case of a single acting no gland?
Edit:
A discussion similar to ours. The last post is interesting.
/ Alternative 3rd function? #102
Better be careful pulling too hard on the rod, dont want to implode the cylinder :ROFLMAO:
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2002 International 9200i Truck (A61307)
2002 International...
Mini Skid Steer (A60352)
Mini Skid Steer...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
