2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,632
Would something like this wolverine valve be suited to use as a manual diverter and also function as a relief valve? The product description says it has an adjustable relief valve?
Then I would just need hoses, adapter fittings and a mounting bracket. Right?
And something else now puzzles me. If I put a check valve in the system, does that prevent it from retracting the grapple hyd cylinder or is the check valve somehow pressure dependent so that it limits excessive pressure but still allows normal operation of the cylinder?
Or should some relief valve be added?
Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Directional Control Valves,Hydraulic Valves,Hydraulics, PRINCE MONOBLOCK VALVE Brand new PRINCE. For control of cylinders, motors, etc. Open center,
