Battery powered chainsaw
/ Battery powered chainsaw #161
Thanks for this thread. I've been considering a battery saw to add to the gas saws. We have more forest then we'll ever be able to keep up with and am considering the battery for either the wife, who hates pull cords, or me for quick jobs of dropping lower limbs or small jobs. We also have concerns with needing to keep going in burn ban season.
To burn ban season: I've often sawed into the evening when one can easily see sparks. The sparks I have seen ALWAYS come from the chain and bar. The closest I've ever come to a fire is from very hot exhaust on dry bark or the chain/bar throwing sparks into dry duff. I think the battery saw would have a lower chain speed which would lower the friction from the bar/chain and consequentially the incidence of sparks? Thoughts?
My 18" EGO saw revs to 11,500 rpm with variable speed trigger.
/ Battery powered chainsaw #162
I bought into the Stihl AP line both home and Christmas Tree Farm and no complaints other than the cost.
Now have pole saw, blower, 3 hedge trimmers and 3 saws.
Use something every week.
I would like Stihl to develop more uses for the AP... maybe lighting, USB, etc.
The hardest part is the first tool because it's the tool, charger and at least one battery and it adds up!
Dewalt 20v 12inch , I love it, can't pull anymore due to shoulders, I have 2 Stilh 16" nearly new, thinking I will sell them and put money on bigger chain cordless chain saw.
/ Battery powered chainsaw #163
who owns owns one ? Brand ?
My brother bought 2 60v oregon battery saws 16 ", he has repair shop, works on mowers,chain saws, 4x4, . Those chain saws sold fast, this was about 2 years ago, still no complaints for buyers.
/ Battery powered chainsaw #164
I’ve had a Greenworks 80v chainsaw for several years and a pole saw. I highly recommend these tools. I’ve taken down and reduced countless post oaks up to 16” without concern. I recommend you replace the original chain with a standard chain right off the bat, the original is a “safety chain” and is a definite hindrance to productivity. I also have two 4-amp hour batteries which each outlast me. These are powerful, heavy duty tools. And they require very little maintenance and start without fail whenever you push a button!
/ Battery powered chainsaw #165
What makes one a safety chain?
/ Battery powered chainsaw #166
Does anyone use a brush cutter blade in their battery string trimmers? Is battery a good way to go with this setup (for more heavy duty brush and weed clearing)?
/ Battery powered chainsaw #167
Bought several Harbor Fright 40v lithium outdoor tools a couple years ago. "Lynxx" brand name. Now they don't sell that brand anymore. Too bad because the chainsaw is a little workhorse, and the pole saw too. The weed whacker not so much. Wanted to mount the blade type cutters instead of the string thing. Can't do that.
/ Battery powered chainsaw #169
A lot of great responses here...and some BS responses, as expected.
As long as one understands the limitations of battery powered chain saws and pole saws, they're great tools!!
/ Battery powered chainsaw #170
It was enlightening to purchase a Makita battery powered impact gun for lug nuts and big jobs around the place, since it was more powerful than my air tools and way more portable.
I recently bought a Dewalt impact wrench. I was hesitant, as I could do more with an 18" breaker bar than with the Craftsman 1/2 inch air tool I bought 30 years ago for comparable money. So far I've been impressed. It will rip a 1/2 inch bolt in two if I'm not careful, and sure was handy when I put my sawmill together this spring. I still think I'll go with another brand for a chain saw though, something which uses a bigger battery.
/ Battery powered chainsaw #171
Keep it out of the dirt.
/ Battery powered chainsaw #172
I have a 30A tract and a good portion of that is wooded, so I use chain saws every day.
Really? Every day? I have 52 acres and 45 of it is wooded, and I use a chainsaw about 10, maybe 15 days of the year. Are you clear cutting it?
/ Battery powered chainsaw #173
Stihl. Good run times out 40 minutes. Will saw through anything I want. Small blade doesn’t last as long as other larger toothed blades. Love it!!!
Let me be a Debbie downer here. 40 minuets is not long.... Not even to the first break.
/ Battery powered chainsaw #174
If you’re getting sparks from the bar/chain you’re hitting rocks or nails.
/ Battery powered chainsaw #175
I have a Stihl MSA 160 (12" bar, pico chain) that I bought in 2012. When I asked the guys at the tractor store how customers liked it, they said "don't know, you'd be the first". It was a new product back then and it was clear the guys at the store though I was nuts for paying 2x the price of a 16" two-stroke but I don't have a garage and didn't want to stink up the basement, so I gritted my teeth about the price and bought it.
Boy I am glad I did! Ten years later, I still love this chainsaw. Obviously this would not be the chainsaw Paul Bunyan would pick, but it has been a champ for what I do: cutting down buckthorn trees (up to 8-9"), dead ash trees, chopping up storm damaged limbs in the yard, etc. It's true you don't get as much runtime as you would with gas, but since I am usually in the position of dragging whatever I cut out to somewhere where can get chipped up, it is a rare day when the battery (AP160 = 4.4 A-hr @ 36V) runs out of juice before I do. It's a pleasure to have it be silent when it isn't actively cutting (I am usually following up with a herbicide application, so there's a lot of non-cutting time) and it's not *too* loud when it is. (I do still wear earplugs.)
Batteries make a big difference with these products. The AP160 battery is great: well-engineered, works in cold weather, holds a charge well when not in use. This saw is always ready to go. Stihl was running a rebate program that got a me a free grass trimmer and AP80 battery with my overpriced saw. The AP80 is the same form factor as the AP160 but can deliver only half the current, that just doesn't cut it (literally); the runtime is so short with the AP80 it's not even worth carrying it around as a backup. I agree with the concerns about the increasingly disposable nature of tools and am glad to see Stihl is still supporting this model and even has upgraded batteries. I also appreciated the discussion on standardizing on a particular line of batteries if you can. I love this chainsaw, but it does means I have battery and charger just for it (the trimmer being worthless.) Everything else I have is 20V DeWalt. DeWalt's tools are good but I don't think much of their battery electronics; I've had two brand-new DeWalt 20V batteries that refused to take a charge until I (following the advice of crazy people on the internet) short-circuited them briefly, which astonishingly enough fixes them. I wish I'd standardized on Milwaukee cordless tools since I hear nothing but praise for them, but I'm too far down the DeWalt road to switch at this point.
Not really negatives so much as "usage notes" on the MSA 160: First, the kerf is very narrow so it's easy for the to chain can get caught if you don't support your cut correctly. A few times I've done something stupid with a cut and gotten the bar trapped. I always worry I've damaged it since it's thinner than the bar on a regular chainsaw, but it seems fine. Second, keeping the chain sharp is even more important with battery-powered chainsaws than with gas ones. I had to use magnifying glasses to sharpen the tiny teeth on this saw, result being that I rarely did it. I've been doing a much better job since buying the sharpening tool shown above (part number 5605 750 4306). It makes a HUGE difference in how many cuts you get from one battery charge. Third, let it get up to full speed (2-3 seconds) before starting the cut. Oh and don't try to cut down 30" oak trees with it.:)
Rob
/ Battery powered chainsaw #176
Rob
Very good point in that a little thought when cutting can go a long way.
A tree guy laughed at my pole saw... He has the biggest Stihl with extensions.
Tried mine and got it stuck... said his gasser never stops full throttle...
/ Battery powered chainsaw #177
I have the Bauer from Harbor Freight, don’t flame me. It’s mainly for light use around deer stands. I have been very pleased with it, but that being said my Husqvarna 440 can usually be found in the back of my truck.
/ Battery powered chainsaw #180
Own three gas powered Stihl's(MS170 up to MS440), a corded McCulloch that I've had forever.
Within the past year of so, I've acquired a battery powered Green Works(40v), and self propelled walk behind mower, and a leaf blower. They all use the same size batteries. I couldn't be happier. Unless I need to get serious about the chainsaw work, I'll grab the battery powered one every time. No fuss, no muss. Power is very good, but you still have to be patient and let the tool to the work. With four batteries, you have almost endless juice.
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
