Your towing rigs and trailers
   / Your towing rigs and trailers #4,051
4WD Tractor might be better with ag tires pulling it through mud, but really deep mud would be difficult.
It doesn’t take much to sink it to the axels even on fairly solid ground, not what I would consider mud. I’ve buried it on ground that you can walk on without getting your shoes dirty.
   / Your towing rigs and trailers #4,052
24 foot gooseneck and 2015 Chevrolet 3/4 ton gas engine. Hauling two tractor s for my wife and I to help another couple clean up ten acres they just bought.
the bigger Mahindra 1538 is actually my wife’s tractor lol.
   / Your towing rigs and trailers #4,053
03 1500Hd and a 16ft 14k PJ LP Dump. This fit my xj2025h and 4ft rotary cutter.
   / Your towing rigs and trailers #4,054
My 03 looks much like that except extended cab. And a smaller PJ dump trailer. Top Notch tilt deck hauls the tractor. And the toy.
   / Your towing rigs and trailers #4,057
I like the colors! The truck and vette match (or close anyway)!
   / Your towing rigs and trailers #4,058
Took the 3038e out to the acreage the other day. The 2020 Longhorn Ram is a nicer tow vehicle than the old 2008 F-150 in a few ways w/ backup cam, factory brake controller, self leveling air suspension, etc.
I've settled on a tie down routine using 2 10' chains, 4 axle straps & 4 ratchet binders.
   / Your towing rigs and trailers #4,059
nikdfish, suggestion for you. When chaining down, move your anchor points on the trailer closer to the tractor. In other words, try to chain more "down" than back. You will find that there is less bounce when going down the road. And ultimately, you will have a better ride in your truck.
   / Your towing rigs and trailers #4,060
I appreciate the advice, but the car hauler only has 4 deck rings, one at each corner. I wouldn't want to try & DIY additional ones for fear of screwing it up.
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
BRAKE DRUM HANDLER (A55745)
BRAKE DRUM HANDLER...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
