square baler trouble shooting
/ square baler trouble shooting #21
Just sold my square bailer a few months ago. Personally, I dislike small squares. Had a pristine NH 575 High capacity synthetic twine baler with all the bells and whistles that ran like a champ and was always stored inside. Even the paint on the extra sweep pickup wasn't worn off. Sold it in 2 days for $12500 cash. Not sad to see it leave either. Did good. Had it 10 years and paid 13 for it. That part of my 'hay adventures' is done.
/ square baler trouble shooting #22
Not sure why you think so. I just wanrt to make sure It is worth fixing before I spend $50 on the service and parts manuals. I do not think I need a manual to figure a problem that I imagine will be obvious.
Think about it. Not trying to dis u; just pointing out how it is usually the other way around - the book is needed or at least helps, to figure it out. Thus it sounds funny to do it the other way around……
/ square baler trouble shooting #23
Why would you buy something that you may not use? Obviously your problem is not obvious or you would have already figured it out.
I have hardly tried to figure it out. If I can't find a problem after spending a little time on it I will get the manuals. I would go ahead and get them but my finances are extremely tight right now... Hence me doing it the other way around... :(
I prefer square bales for feeding as I I can feed what the cows need everyday. Also like to spread the hay out to distribute impact and fertilizer. Since I only have 10 cows square is much better.
/ square baler trouble shooting #26
I have run a 9 for years. The machine should turn over by hand by turning the flywheel counter clockwise while facing the flywheel.
Sounds like the slip clutch is doing it's job.
/ square baler trouble shooting #27
So I understand....can you spin the machine by hand at all?
/ square baler trouble shooting #28
If you can turn machine by hand and the PTO will NOT turn the machine, your slip clutch could be shot OR the over running clutch is seized.
/ square baler trouble shooting #29
anyone nearby doing any square baling? Might want to ask for some help
If its been settin a while, the slip clutches are seized.
/ square baler trouble shooting #30
True, likely the slip clutch plate would be seized anyways, it is under all these springs.
Over run clutch is this ring with swinging "teeth" If the teeth are stuck, they won't swing into place to let the PTO spin the slip clutch or flywheel. Mine blew up so I learned more about it than I wanted to.
/ square baler trouble shooting #31
#9 will bale decent when set up right. But they are old and a parts machine is valuable to have.
Farmer495 you have been very helpful!
The baler has been sitting a while.
The baler will not turn at all either way by hand.
My next step is to remove the pin in the swing arm on the other side of the flywheel to see if the problem is in the flywheel/clutch assembly.
/ square baler trouble shooting #33
And you bought a baler you didn’t understand when your finances were so tight you couldn’t afford the manual? Hope it came with twine and grease.
/ square baler trouble shooting #35
#9 will easily turn by hand on flywheel if everything is free. If the baler does not turn by hand with the flywheel, either forwards or backwards, and the baler has been sitting a while, the plunger might be stuck. I think my first comment with that the slip clutch was working if the tractor was just spinning the PTO and not the flywheel, that is what would happen if plunger was stuck.
I'd leave the swing arm alone at this point until you know the plunger isn't stuck.
Ensure all old hay and and debris is out of the chamber and then soak top, bottom and sides of the plunger in PBlaster etc, and wait, then try to see if you get movement.
Depending on where on the plunger stroke it stopped, you might be able to tap the plunger from the bale chute end with a long, heavy wooden post (make sure twine and needles aren't in the way! I've also used a Jackall and a chain to jack a seized plunger out of a parts #9.
Awesome thank you Farmer495 for your tips. I will check out the plunger tomorrow, grease all joints with pb blaster and see if it is stuck.
Sea2Summit, yes I bought my first baler and I am learning. Couldn't pass it up at $300. It did not come with grease or twine. Also did not come with a tractor, rake, cutter bar, fuel, or grass.
I think what I heard you say is, I really think you should prioritize getting the manuals as they will really help you get this baler going for hay season. Is that correct? If so, I agree with you and I will get the manuals.
/ square baler trouble shooting #37
Square balers, especially of that vintage, are made up of incredibly ingenious and simple parts and mechanisms…but there’s a whole ton of them and all rely on one another to be in perfect order for all of them to operate properly. One simple timing issue has to potential to destroy pretty much the whole baler. I would buy manuals before I bought twine if it were me, they are that important IMHO.
/ square baler trouble shooting #38
Thats true. We have a small baler shop nearby and an older Amish fella who worked on mine (New Hollands) for years. Of course he couldnt drive, but he had a driver. I think his name was ”Cowboy Joe” lol. He would have Cowboy Joe drive his pickup next to my baler and listen for the timing. Stop, make adjustments, and bale for a while.
After a while, I got to know just what it should sound like, too and made my own adjustments.
He was a super honest man and could make a baler run perfect. I had a brand new dawg break and he replaced the part without asking for a penny.
Before that I had a John Deere 336 which would make 7 out of 8 bales just right, then make a banana bale or some other distorted shape. Never could figure that thing out….
Ahhh, the bad ol days…..lol
/ square baler trouble shooting #39
The one hay tool that causes the most grief is always a small square baler. Everything has to operate in complete harmony or they just plain don't work and the older they get and the more neglected they get , the less harmoniously working together the parts become. One thing I never cared for with older square balers (I started out with an ancient NH Hayliner 66, was all the chain drives. Chains get stretched and timing goes to hell. Modern balers (like the 575 I sold) are all gear drive so no timing issues, no chain stretch because there are no chains. One Vee belt for the pickup, thats it.
/ square baler trouble shooting #40
NH 575 parts catalog shows some chains were utilized when transferring power
PALLET OF TRACTOR WEIGHTS (A64278)
PALLET OF TRACTOR...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2019 CIMC 40ft. 36 Ton T/A Container Trailer (A64556)
2019 CIMC 40ft. 36...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
