Rhino35
- Joined
- May 28, 2013
- Messages
- 148
- Location
- Independence, KY
- Tractor
- 2013 Kioti DK 40 SE Hydro and two Cub Cadet riding lawn mowers
Hi All,
My second problem (besides the choke cable sticking in another post) is the 25 HP Kohler engine in my (mother-in-law's) 2004 Craftsman GT5000 intermittently, but frequently during mowing, cuts out, then resurges back to operating RPM. It does this intermittently in all modes of operation except when stationary. Feels very random, although it especially will do it going downhill and after turning left. Something about the motion is either affecting an electrical connection, or causing brief fuel starvation. Turn, count two potatoes, it cuts out, struggles to regain RPM, almost dies sometimes (not always), then roars back up to operating RPM until it happens again. Might be a minute or two, might be 10 seconds.
I suspected the seat safety cutout switch. That definitely works and if you lift off the seat it will kill the engine, but experimenting with partially lifting my weight off the seat did not cause the engine problem. Still, can't rule it out - some minor G force induced loss of continuity could be the culprit.
I'm really thinking fuel starvation. The fuel filter is brand new and contains the normal amount inside it - so if a blockage I think it is between it and the carburetor. I'm vaguely familiar with carburetors - they have jets and floats, and can experience blockages from debris. My mother in law says it happened last summer too. On the way up to resuming operating RPM the exhaust belches some black smoke - unburned fuel?
I'd take it to a mower repair store but right now the turnaround time is many weeks. One place has 300 mowers lined up to repair. So if I can remedy this I'll try. New OEM plugs, clean air filter, new fuel filter, new oil filter and oil. Runs great except for this quirk.
Thanks for any thoughts and advice. It's a nice mower except for the choke problem and this surging. And maybe an oil leak, but I'll leave that for another post if it persists. My neighbor and I just did the cleanup/other stuff I mentioned above.
Rhino 35
Rhino 35
