bearthebruce
- Joined
- Jul 26, 2018
- Messages
- 560
- Location
- Property is in Floyd County VA
- Tractor
- '05 Massey Ferguson 1533; '22 LS MT125, '23 Kubota SVL65-2
We have 210 acres - none of it flat. We operate with a 2005 Massey 1533 Compact tractor. The tires are not loaded. It has a FEL and we mow 25 acres give or take with a rotary brush mower. The mower is a 60" light duty, good for cutting up to an inch - inch and a half - requires 25hp from the PTO.. the 1533 has 28PTO Hp.
Tractor by itself is right around 3000#. The FEL adds another thousand. Wheel spacing is set at 63". We could go wider but then our trail work would be more problematic.
Slopes are max at 20 degrees... which gave me quite a bit of seat pucker my first time out on the big meadow. We do not cut across the slopes. Up and down only. Some places it is backing up and down, no turning up top. When up slope, you want to keep the tractor in gear... a mistake at the top can have you flying down the hill at a crazy rate of speed with no or little ability to stop. Learn to use the FEL to help hold if changing gears up top. (Lesson learned the hard way.)
Slow is my answer. Yeah, I love riding the tractor for 12 hours straight! NOT!. Fast is how I got in trouble every time. Slow. Take breaks. Stay fresh. You need your brain for when things go sideways and they will.
Seat belt on. ROPS up. Seat switch functional. You don't want to be tossed off the tractor and then be run over by the mower. On slopes, do not defeat that switch... I have a defeat for my switch.. I rarely use it.
Lots here will tell you to load the tires as should the dealer. We feel that would be a bad idea for the trails we are developing so we do not have them loaded. Maybe someday our opinion will change but not yet. We don't need the weight to do our driveway work as we get plenty of traction to drag our grader blade and box blade. We don't feel we need more rear weight for mowing, light lifting, and so on. We are ever conscious of the limits when lifting and always have ballast on the back. (Another lesson learned the hard way.)
I don't know the tractors you are looking at. I have a colleague who loves his sub-compact Kubota on hilly ground. He runs all over, has about 10 acres, mows it all. He is running a mid-mount mower.
I've learned reading on TBN that strong opinions exist. You have been given much to think about but in the end, it is your decision. You get to choose and I doubt you will make a wrong choice.
You can't be the only family on that hill. What are others doing to maintain their property? Perhaps talking with them would give a better feel for how to manage you 6 acres?
We have a neighbor who has 15-20 head of cattle, does a lot of haying, lifts big rounds in the winter for the cattle. He has a full size JD tractor for much of that work. He has a skid steer and heavy duty front loader/back hoe - which I have never seen him run. He produces hay on 100 acres give or take.. If I have a tractor question about operating on the slopes of the mountain we share, Larry is my go to. My recommendation: talk to a neighbor and see what they have to say.
