How much does it cost to build a pole barn and what kind is best..
/ How much does it cost to build a pole barn and what kind is best.. #71
I was designing my shop around pole barn type design. I want insulation and the inside paneled with either osb or steel. I'm now leaning towards SIPs construction. 50x60x16 will take about 5 days after the slab is ready. After 5 days I will have a fully insulated shop with osb interior. I was planning to build the walls and insulate later with the pole barn style. With SIPs, it will be done in a week what would have taken me at least a year to do on a pole barn.
/ How much does it cost to build a pole barn and what kind is best.. #72
If you want to build a 20 by 40 pole barn, what kind should you build, and what should it cost? Is metal or wood better, and where can you get the materials or is a prefab cost the same considering time and effort...
I did not even bother to read the umpteen other responses. I will tell you without any hesitation or doubt: The best kind is built by a local (nearby to you) company that will erect it completely in about 2 to at most 3 days. They will do it FAR better than you can and it will both look great and be durable for many years. These companies have become an absolute marvel to me in the last couple of decades -- quick, efficient, and high quality end results. Use prefinished baked finish steel. The roofing type that is custom cut to length and is NOT pieced to make your longest sloped roof dimension. Typically the entire materials list is delivered on a trailer truck. You prep the site, get it level, do the ditching, etc. They erect the building. It depends of course on widely varying needs, pocketbooks and wants but I strongly say have a concrete floor put in it. I was foolish and did not do that and sure wish I had.
It is up to you but the best buy in my opinion is prefinished steel all around (sides, roof) using 4x6 verticals. You decide whether you want insulation, skylight translucent panels (you will want several) , how many doors & windows, ventilation to prevent sweating, etc. You can get the specs on the basic building from the installing company and then beef it up or make changes you want. Like closer spacing of sheathing boards under the roof, heavier trusses if you think you need them, etc.
Other items of experience: Bigger is better than what ever you were planning, guaranteed. Taller is almost as certain to be better also. It cannot be built too big.
/ How much does it cost to build a pole barn and what kind is best.. #73
But how do you support it in the middle with no poles??
Either a pole barn with trusses or a metal building with arch beams that go all the way up and over, side to side.
/ How much does it cost to build a pole barn and what kind is best.. #74
That's big money down here and a crane to place them. How would you do it....?
I can raise two 36’ trusses with purlins by myself without any powered equipment (crane, tractor, etc). Just assemble & lift straight up.
/ How much does it cost to build a pole barn and what kind is best.. #75
As an alternative. Did you look at pony wall structures from Clearspan. Look at their steals and deals. I put up a 24x26 with 16 ft of center head. I used 3000 lb cement blocks from leftover mixes from a cement plant but you could use pressure treated posts instead. Very quick to put up. Mine has been up 12 years and no problems. I also when back and added an additional 48’ 5 years after the initial shelter making 60’ long. Total initial cost was $7000 with breathable end panel at one end. The addition cost another $7000. It is used for round Bale hay storage and equipment repairs. That’s a 60x26 barn. Used gravel and Asphalt millings for floor. It stays very dry inside.
/ How much does it cost to build a pole barn and what kind is best.. #76
I could not agree more about hiring a local company. Unless, and even if you do purchase a kit, few consider all the time associated with completing this type of project. It's not like a do-it-yourselfer cannot do it, but this can be troublesome unless you are very experienced and or have experienced help. Getting everything square, running errands to get other supplies, a partial walls building then a wind storm... there is a lot of issues and I think personally you are money / time ahead hiring a contractor. I have had (2) metal buildings, one metal studs on slab, one pole barn "wood structure" with metal (3 sided). Watched carefully during construction, there would have been many many times I would have needed assistance.... would still be working on them months later.
One issue I *might* disagree with is putting in skylight translucent panels. If by this means on the roof.... I would not. At least in Texas, the sun will eat them up eventually, Mine are in the side walls. Also, consider any translucent panels must "mate" with the metal. These will contract / expand differently and the last place you want trouble is in the roof. I must say, my panels are NOT enough light by themselves for benchwork, but enough for most things. Plan to add lights / power !
Good luck !
/ How much does it cost to build a pole barn and what kind is best.. #77
As an alternative. Did you look at pony wall structures from Clearspan. Look at their steals and deals. I put up a 24x26 with 16 ft of center head. I used 3000 lb cement blocks from leftover mixes from a cement plant but you could use pressure treated posts instead. Very quick to put up. Mine has been up 12 years and no problems. I also when back and added an additional 48’ 5 years after the initial shelter making 60’ long. Total initial cost was $7000 with breathable end panel at one end. The addition cost another $7000. It is used for round Bale hay storage and equipment repairs. That’s a 60x26 barn. Used gravel and Asphalt millings for floor. It stays very dry inside.View attachment 738359
/ How much does it cost to build a pole barn and what kind is best.. #78
Some nice barns here.
/ How much does it cost to build a pole barn and what kind is best.. #79
I caught the power company replacing poles in my area and asked if I could have some and they gladly gave me more than enough for the job. As I was setting the posts my neighbor stopped in and asked if I would like to have some steel for my project as he had taken down a large building and never put it up and would like to get rid of it, score. There was more than enough support beams and sheeting to do a 24X40 pole barn. My total expenses came to around $250 for bolts and screws. I used my TYM 234 with an extension on the bucket for lifting beams and did all the work myself. Pic is prior to putting up the trim but you get the idea.
/ How much does it cost to build a pole barn and what kind is best.. #80
This! I ultimately built a 40x100 when I thought 40x50 would be plenty. I’m browsing this sub because I’m thinking it’s time to upgrade again. Definitely add a Leanto. I didn’t and I regret it. They’re always something to stick under there.
If wanting to build a 20X 40 one should start by instead planning on a 40X60 and settling for at least a 30x50 sized building, with a leanto one one or both sides.
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
2018 Bomag BC572 Articulated Trash Compactor (A59228)
2018 Bomag BC572...
John Deere 5055E (A53317)
John Deere 5055E...
2014 Dodge Charger (A59231)
2014 Dodge Charger...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
