WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,931
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
Yep. I think they did. Looks like I have some work to do on it.
I don't understand this. How does a metal roof float when each panel is nailed to the roof the full length of the panel.The flashing for the vents,yeah iI am going to address that it will have to be an adhesive seal. You do not screw things thru a standing seam metal roof. They are supposed to float.
In our previous house I laid Laminate Flooring in the kitchen/dining area. Was told to not fasten it down and to always leave a slight gap at the walls so it could "float". When I was done I moved the cabinets in and filled them with a hundred pounds of kitchen products. Moved the kitchen stove in. Moved the dishwasher in. Moved the Refrigerator in. Dining table and chairs. All setting on the "floating" floor...... Floating, right.....![]()
True, but I think having a durable and permanent, weather-sealed roofing protrusion is more important than each roofing panel being 100% floating. My roof definitely does some pings and pops on a cool evening after a sizzling summer day. But 32 foot long panels will do that; no problem.You do not screw things thru a standing seam metal roof. They are supposed to float.
I'll take your word for it that this is happening. Watching the video, it looks like he nailed each panel into place just as tight as it was possible with that nail gun. How much movement do you get in 12 inches, I have no idea.They are clipped and nailed on the edges and are supposed to move freely in the middle for thermal movement. There are several types of clips that hold the panels to the roof. Some basically let it float up and down the roof with expansion and some are fixed. I don’t know which ones we’re used on mine. But the center of the pan is supposed to float free. That is why you get oil canning on some roofs.
I think you must have roof leaks on the brainI will look at that video tonight.
Here is the latest that I dripped today.
This is not allowed where I'm at, and pretty much everything is allowed here. We don't have any building Code outside of city limits, but if you want to have "city" water, then you have to do it their way.Around here people install water and power in the same trench all the time. The water line gets installed at least 6+ feet deep because of frost and the power goes in at 32 inches. So water line, partial back fill, power line, finish it off.
For center pivots the water line and the power also go in the same trench. 6-8" water line on one side and 3 phase power on the other. There is enough separation so if any repairs are needed there are no issues as long as there is a competent operator on the excavator.
One of the advantages of having water and power in the same vicinity is that you don't need to bury a tracer wire with the water line as the ground in the power line can be used for that purpose. For those that don't know a tracer wire is used to send a signal for a receiver to pick up. The newer locators are pretty accurate as to where the line is.
It's commonly done here.This is not allowed where I'm at, and pretty much everything is allowed here. We don't have any building Code outside of city limits, but if you want to have "city" water, then you have to do it their way.
It is written in stone that water and electricity must go in separate trenches with at least a foot of virgin soil between them. If you cross, then water MUST be on top of power.
The reasoning is that if you ever have a water line break, and they do all the time, you do not want to be digging in a hole full of water and risk hitting the power line. If the water line is below the power line, it is very easy to hit the power line while getting down to the water line.
I know from personal experience that if you decide to set a fence post, or dig into the ground for any reason, you will hit a power line eventually. In the last couple of years, I've cut two lines going through my yard.
Even if you know exactly where those lines are, there will be a time when you are not able to do the work yourself. Then it will be a friend, family member or contractor that is digging up that broken water line, and risking their life if the power line is above the water line.
Putting water and electricity in the same trench should never be done.
