WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,932
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
Yep. I think they did. Looks like I have some work to do on it.
I don't understand this. How does a metal roof float when each panel is nailed to the roof the full length of the panel.The flashing for the vents,yeah iI am going to address that it will have to be an adhesive seal. You do not screw things thru a standing seam metal roof. They are supposed to float.
In our previous house I laid Laminate Flooring in the kitchen/dining area. Was told to not fasten it down and to always leave a slight gap at the walls so it could "float". When I was done I moved the cabinets in and filled them with a hundred pounds of kitchen products. Moved the kitchen stove in. Moved the dishwasher in. Moved the Refrigerator in. Dining table and chairs. All setting on the "floating" floor...... Floating, right.....![]()
True, but I think having a durable and permanent, weather-sealed roofing protrusion is more important than each roofing panel being 100% floating. My roof definitely does some pings and pops on a cool evening after a sizzling summer day. But 32 foot long panels will do that; no problem.You do not screw things thru a standing seam metal roof. They are supposed to float.
I'll take your word for it that this is happening. Watching the video, it looks like he nailed each panel into place just as tight as it was possible with that nail gun. How much movement do you get in 12 inches, I have no idea.They are clipped and nailed on the edges and are supposed to move freely in the middle for thermal movement. There are several types of clips that hold the panels to the roof. Some basically let it float up and down the roof with expansion and some are fixed. I don’t know which ones we’re used on mine. But the center of the pan is supposed to float free. That is why you get oil canning on some roofs.
