Steering wheel knob placement
/ Steering wheel knob placement #1
Kimocuda
None
Just curious, those using a steering wheel knob on your subcompact tractor, what location have you found it to be the most useful / comfortable, etc. I'm getting ready to install one and figure several of you many have useful insight. Also, it's for a BX and I'm right handed. TIA
/ Steering wheel knob placement #2
I place mine at 12 o'clock. I seem to have the most leverage in that position and its neutral enough to use either hand.
/ Steering wheel knob placement #3
Where does you right hand normally rest on steering wheel....To me that would be logical position... But my SCUT has power steering so I don't need any knob....
/ Steering wheel knob placement #4
Most newer tractors have hydrostatic power steering and the steering wheel will not remain in the same position. Your profile does not show what tractor you have so it's unknown if you have such a tractor. You can still put a knob on, just be aware that it will not remain at the same position.
/ Steering wheel knob placement #6
This has been my experience, put it on and with a hydro steering system it will move around, but still very useful to have especially when doing loader work.
/ Steering wheel knob placement #8
As mentioned, the steering wheel does not remain aligned with the wheels...
Which is why I put on 2 suicide knobs, opposite from each other.
I can always find a comfortable position and the unused knob has never been in the way on my MX6000.
//Terry
/ Steering wheel knob placement #10
Yes it does, OP stated it's a BX compact and it has hydrostatic steering (most all Kubota's do) so it DON'T matter where he puts it as it will always be in a different place anyway.
/ Steering wheel knob placement #11
//Terry
Not a bad idea, I may try that as well.
/ Steering wheel knob placement #12
I had one on my Deere 2305 years ago. I like to keep an eye on the work so I would loose the knob while tilling and looking backwards, then I would have to hunt for that "disappearing knob" when I came to the end of the row.
/ Steering wheel knob placement #13
My BX24 has two on it, as they do move around, and therefore one is always in a convenient position. I never bang or bump them... go with two!
/ Steering wheel knob placement #15
AS others already covered....doesnt matter it wont stay with true powersteering. Only works on power assist where there is still a mechanical linkage.
I dont ever have any issues with just one. By the time it locates itself to the other side that arm was ready for a rest anyway.
I would think if I had two knobs...the unused knob would constantly be banging my elbow as I turn or getting hung up on my coat
/ Steering wheel knob placement #16
When we were kids we called those steering wheel knobs “Brodie Knobs” because they were used for going into a sideways sliding stop on dirt roads, called a Brodie. Not sure where the rerm came from.
/ Steering wheel knob placement #17
When doing a lot of loader and logging work a lot of time is spent "positioning" the tractor. Jigging back and forth which requires a lot of steering wheel spinning. This is where a steering knob is very helpful. But as already stated it never stays in the same place on a hydro style steering. I have never found this a big problem once I got used to it.
If you wonder whether you have this type watch the brand in the centre of the wheel. For me the K for Kubota constantly changes position
/ Steering wheel knob placement #19
I recall them being called "suicide knobs".
That's what I've always heard them called too, not sure why.
I remember having a helluva time finding one that fit my tractor, the autoparts store ones seemed to be made for wheels that were considerably thicker than those on a tractor, and it wouldn't stay in place. Finally found one on Amazon that fit well.
I agree with LD1, 2 knobs would just get in the way.
/ Steering wheel knob placement #20
With the tires and steering wheel set up straight ahead, I put mine on at the ten o'clock position. With hydrostatic steering it is supposed to move around - and it can if I force it, but I usually find that it back at same ten o'clock position.
Having two wouldn't help me, just be in the way. But I sure do use it a lot.
Don't overthink this. It's easy to change.
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
FUEL TANK (A68842)
FUEL TANK (A68842)
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2019 JOHN DEERE 750K LGP CRAWLER DOZER (A65056)
2019 JOHN DEERE...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
