Ugh!! Water Well contractors...
/ Ugh!! Water Well contractors... #81
Oh I am afraid using inverters, better knows as VFD's for down well pumps is not only recommended these days, but heavily pushed on every unsuspecting homeowner who is out of water and at the mercy of the installer. They use that phrase..."Adjusting the compressor motor speed gives exactly the right amount of cooling at the minimum amount of energy". Only a well pump is centrifugal, not positive displacement like a compressor, and reducing the speed actually increases the amount of energy used for the gallons of water produced. Yet millions are falling for the "energy savings lie" and think the problems inverter's or VFD's cause, as you just touched the tip of the ice burg on, are worth the added expense and short life of a "variable speed pump".
It is true that reducing the speed of a pump also reduces the energy needed to spin the pump and motor. However, using half the energy a variable speed pump has to run ten times as long to pump the same amount of water. The variable speed pump can use up to five times (500%) more energy than a standard full speed, inexpensive, and long lived well pump.
However, "home water use is (NOT) too intermittent to benefit much from a just it time water flow". The idea of the variable speed pump is good for many reasons. Working with a small pressure tank the pump will cycle for small amounts of water. Although, the benefit of "constant pressure" means the pump will never cycle during a long term use of water. A standard full speed pump with a large pressure tank will cycle less when small amounts of water are being used. But even with a large pressure tank system, cycling during long term uses of water can add up to destroy pumps much more quickly than necessary.
Along with being able to use a small pressure tank and "Things like soft start/stop, lower starting current, avoiding startup and shutdown water hammer, and reducing the torque on plumbing", there are many other benefits to a constant pressure well pump system. Out of sheer luck over thirty years ago I discovered a simple control valve can deliver "constant pressure" similar to or even better than a VFD. The difference is the valve is simple, inexpensive, and doesn't have all the problems that go with "electronic pulse width modulation", which is variable speed or VFD.
It is also an amazing fact of physics that when restricting a full speed centrifugal pump with a valve will the amp draw or energy used will reduce almost exactly as much as if you were reducing the pump speed with a VFD. I will try to find a pump horsepower curve to post. It is counter intuitive and hard to understand without a curve.
It seems like the above statement contradicts what you are saying in the second paragraph above about the inefficiency of a vfd driving a pump, but perhaps I'm reading it incorrectly.
/ Ugh!! Water Well contractors... #82
a tiny pressure chamber that adjusts flow to meet demand, without a big pressure tank, and with a more even pressure level.
So that sounds like a built-in CSV, right?
I've noticed, on our Lennox 1.0 ton mini-split, that it takes a long time to shut off when approaching the set temp. Is this a combination of sensing outdoor temp as well as near set point temp and inverter slowing the compressor to keep it running as long as possible? I've read that mini-splits work best (most economical) when running as much as possible so that is what "it" is trying to achieve?
I will let a CSV expert comment on that, but the Grundfos SCALA system runs whenever there is water usage in the house and the system was designed to be variable demand. It supposedly will even detect leaks.
What you describe on your Lennox is the exact behavior you get when the inverter is tapering the compressor output to not overshoot your set indoor temperature. The effect is that, yes, the compressor runs longer, but not at full HP, and using less energy. I would point out that besides the electrical design changes, in an ideal world, the manufacturer also changes how the lubrication and internal cooling are set up, so that lower speed operation doesn't affect the compressor life. So, slapping an inverter on any old compressor is not a recipe for success. The general add-on VFD "rule of thumb" is plus or minus 50% in an AC motor speed will generally work. By design, many systems are able to do well at a factor of 20 of motor speed up/slow down, more if it is a DC motor.
All the best,
Peter
/ Ugh!! Water Well contractors... #83
As to those constant pressure pumps, few if any of the drilling companies in our areas use them. We always felt they was turning the motors too fast & just more gadgets to worry about. We encouraged our customers not to use them. We wanted to drill not pull pumps. Whatever lasted the longest is what we sought after. We liked fat tanks & mostly used well x troll 250. We found the wider the tank the diaphragm/bladder seemed to last longer.
/ Ugh!! Water Well contractors... #84
Maybe I should say it like this...
Everybody knows when restricting a pump a valve "burns energy". If you understand a pump curve you will see that varying the pump speed with a VFD burns almost exactly as much energy as a valve. So, if because of the drop in amps to spin the pump/motor they can say a VFD saves energy, I can also say a valve saves almost as much energy as a VFD. However, anytime you reduce the pump speed or restrict the flow with a valve you are getting fewer gallons per Kw. Again, there is noting more efficient than a full speed pump working at its best efficiency point. Although there are many good reasons for a constant pressure system, saving energy is not one of them.
/ Ugh!! Water Well contractors... #85
All the best,
Peter
They spend a lot of money advertising those variable speed pumps like the SCALA. This is not because they are good for the consumer, but rather because the SCALA s the perfect "fluid" product, as it costs a lot and doesn't last long. On the false pretense of "saving energy" they trick you into the least reliable, shortest lived pump they make. Because of the complicated electronic controls in a VFD like the SCALA, they have an unbelievable failure rate. I hear from the supply houses that they are filling dumpsters with SCALA pumps that have failed. The SCALA has a worse failure rate than the MQ, which has been filling dumpsters for years. I will post a picture.
Let me say this again. Varying the speed of a compressor or any positive displacement pump can save energy. However, varying the speed of a pump with a centrifugal impeller always
causes more energy use per gallon pumped.
/ Ugh!! Water Well contractors... #86
Thanks for expounding on this.
So I guess we could say that a 1/2 HP centrifugal pump running with no head and no restricted output is more efficient than a 1.0 HP pump throttled with a valve to the exact same GPM as the 1/2. Right? A graph where the curves reflect that would be interesting.
/ Ugh!! Water Well contractors... #87
Good for you! Most drillers/pump guys are just the opposite, preferring to push the VFD as they make a LOT more money that way.
The WX250 is good, but that 44 gallon tank only holds 10 gallons of water. It is not that the larger diameter tanks last longer, but cycling on and off destroys the diaphragm in any pressure tank. The bladder or diaphragm in a tank goes up and down with each pump cycle. This is like bending a wire back and forth until it breaks. Eliminate the cycling by adding a Cycle Stop Valve to a traditional pressure tank system and the pump, tank, and everything else will last much longer.
/ Ugh!! Water Well contractors... #88
That is absolutely correct! But it is the same thing with a VFD. Restricting or slowing a 1HP pump down until it only uses 0.5HP energy would only be producing about 0.1HP worth of water. Varying the pump speed of a 1HP down to 1/2HP uses at least 500% more energy than a 1/2HP pump running at full speed. But they will show you amp meter drop from 9 amps to 4.5 amps and say you are saving 50% energy. However, running the pump slow enough to use 50% energy means it will have to run 10 times as long to produce the gallons needed. A centrifugal pump acts completely different than a compressor when varying the speed, and that is what confuses people into purchasing a VFD well pump when it is the worst thing they can do.
/ Ugh!! Water Well contractors... #89
I was kinda thinking the energy input should equal energy output with the corresponding losses factored in.
/ Ugh!! Water Well contractors... #90
Yes, they will. It is a fundamental law of physics. (Conservation of energy)
Not everything that is written is accurate...
Pump efficiencies can have rather high non-linearities in energy/volume water pumped (work), centrifugal pumps especially so. (E.g. centrifugal pump at 1 rpm is never going to pump water into any sort of head or resistance, but a positive displacement pump will meter the flow.)
All the best,
Peter
/ Ugh!! Water Well contractors... #91
Wow! I've been using one of these Grundfos pumps for 20 years and have found it to a great, trouble-free pump. My boneyard is full of old cast iron jet pumps.
/ Ugh!! Water Well contractors... #92
What is the deal with water well contractors? I'm getting to the point I'd rather have all my teeth pulled without Novocain, then have to deal with another well person. No shows, poor service, deceitful, the list goes on.
The first time I ever needed my well serviced, I had a guy show up with starched pants, silver tips on his boots and smelling like a french *****. Turned out he was a bail bondsman; his brother was the actual well guy who showed late in the evening. He temporarily got me water (repaired a split drop pipe), but I could never get him out to finish replacing the pipe.
A year or so later, I got a guy out to replace the pipe, but he didn't actually have enough pipe, so some of the better original sections (which still weren't that good) had to be re-used.
The last guy was the worst. I never met a guy that got himself so twisted up in his own lies. Long story short, he replaced a 1.5HP pump with a 5HP pump that would overdraw the well in about 5 minutes of run time. His solution was to add a pump protector cut-out to cut the pump off each time the pump ran dry.
My latest predicament started almost two weeks ago, when we noticed our pressure was starting to drop. I did some troubleshooting and found the pump is drawing about half the amps and suspect either the pump has an issue or there's another split pipe. I called the well guy that everyone recommends (he's actually pretty good) and told them my issue. They said they could get to it, but it would be a few days. No problem, I can limp along a few days. It's good service to take care of those in dire need, if someone says they can get by a few days. It's now turned into almost 2 weeks and I can no longer limp along, no water pressure today. Tried calling them again and no answer now.
It's actually put me in a pretty bad position. I have an elderly parent staying with us in an in-law apartment without water, we have goat kids being born so we're hauling water from a neighbors and I was supposed to head out of town Friday.
I should change careers and start a well business.
Well contractors simply don't replace 1.5 hp pumps with 5 hp pumps. A 5hp pump is a very serious pump capable of pumping 500 plus feet of elevation.
This would be equivalent to a mechanic installing a 454 V8 into your Chevrolet to replace a 1.5 liter 4 banger. It just doesn't happen.
/ Ugh!! Water Well contractors... #93
Grundfos makes really good jet pumps. But they have only been making the SCALA a few years, and the MQ hasn't been around that long either. Which pump do you have?
/ Ugh!! Water Well contractors... #94
You have to check the pump curve. This curve shows a pump drawing 10 HP load and producing 100 GPM. But when you slow the pump down with a VFD until it only requires 2HP energy, it is only pumping 8 GPM. The pump is much less efficient when the speed is reduced.
However, you should notice this same pump drops from 10HP to 3.25HP by simply restricting the flow with a valve like the CSV. The point being that a VFD is only a couple percent more than a control valve, and the control valve will cost much less and make the motor last longer instead of shorter like a VFD.
  • Grundfos supplied curve.pdf
/ Ugh!! Water Well contractors... #95
Sorry, I'll have to look that up. I moved the pump out to the well box and it is -31F at the moment and I don't want to open the well box to look.
I found it cheaper and easier on the pump to push water rather than pull water and the house is much quieter with that pump out of the house. Fairly certain it is the 1hp, 115volt MQ.
/ Ugh!! Water Well contractors... #96
Interesting graph! Thanks for posting.
a VFD is only a couple percent more than a control valve What do you mean by this statement? Does this show on the graph?
/ Ugh!! Water Well contractors... #97
Yes! It shows on any pump curve with a horsepower section. The curve I posted has the points marked at 1.96HP for the VFD and 3.25HP without varying the speed and simply using a CSV. Most people do not realize a 10HP centrifugal pump will drop down to only use 3.25HP worth of energy when restricted with a valve. Most people falsely think restricting with a valve will make a pump work harder. In reality the natural drop in horsepower of a centrifugal pump when restricted with a valve is only a few percent different than when slowing the RPM with a VFD.
/ Ugh!! Water Well contractors... #98
I have a Grundfos book from 2000 and it doesn't show the MQ. I guess they could have been around for 20 years, as time seems to fly by as I get older. But if you have an MQ that old it is the only one that has lasted that long. Most are short lived. Just search for MQ and you will find countless sad stories from people who have had a lot of problems.
/ Ugh!! Water Well contractors... #99
So did you mean "a couple horsepower" rather than "a couple percent" difference between VFD and CSV at the reduced flow?
/ Ugh!! Water Well contractors... #100
It depends on the particular pump and where you look on the curve. At low flow most pumps are 7% tp 10% different between variable speed and a simple valve. At high flow the control valve is usually 3% to 5% better. Overall the difference is probably only "a couple percent". I was using a 10HP just to make the numbers easy. It would certainly not be much difference with a 1HP pump.
2013 John Deere 7200R Tractor (A66285)
2013 John Deere...
Moffet Forklift (A65579)
Moffet Forklift...
12ft. 28 Gauge R Panels (A65640)
12ft. 28 Gauge R...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
2016 Freightliner Columbia 120 Glider Truck, VIN # 3ALXA7CG9GDGZ6492 (A65563)
2016 Freightliner...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
